Dne sobota, 11. april 2020 12.02.19 UTC+2 je oseba jld napisala:
The propulsion efficiency has much more direct effect than pylon drag. In fact, for Takeoff and climb performance, the overall glider drag has secondary effect compared to aircraft weight and available thrust. Without fuselage interference and opportunities for larger props, the pylon mounted motor provides a significant efficiency advantage. This has a direct effect on climb performance in terms of climb rate and altitude gain. Running large battery packs, beside running cooler, also provides better energy efficiency and installing large batteries in the wing reduces overall structure weight and provides better flying handling characteristics due to CG. FES is a nice solution, especially for retrofit of existing gliders. For a brand new design, there are opportunities for better optimizations. Is GP at the optimum, probably not (yet:-), but they have certainly made good design decisions for both teh glider and the propulsion. Actually efficiency of glider in powered mode is quite important: 1.Efficiency of FES powered glider in powered mode is the same as in glide mode. FES powered glider, L/D 50 and 500kg T.O.W, minimum sink 0,5m/s: -required thrust for level flight; 500kg/50=10kg which is 100N -another 100N is required for climb rate 0,5m/s; 200N -another 100N is required for climb rate 1,0m/s; 300N -another 100N is required for climb rate 1,5m/s; 400N -another 100N is required for climb rate 2,0m/s; 500N -another 100N is required for climb rate 2,5m/s; 600N -another 100N is required for climb rate 3,0m/s; 700N 2.Efficiency of most powered gliders with retractable systems is about half (or even worse) of the efficiency as glider. Note that pylon drag with its big pulley or motor on top is still there even if propeller is rotating ![]() Pylon powered glider, with pylon extended, L/D 25 and 500kg T.O.W, minimum sink 1,0m/s: -required thrust for level flight; 500/25=20kg which is 200N -another 200N for climb rate 1m/s; 400N -another 200N for climb rate 2m/s; 600N -another 200N for climb rate 3m/s; 800N Efficiency of propeller not depends just on its diameter but also how much thrust such propeller should create. Even with smaller propeller diameter is possible to achieve good efficiency when required thrust is smaller, for instance during level flight or more shallow climb rates and this is typical use of FES. As you can see above, with FES required thrust for climb rate 1m/s is 300N, while with pylon for 1m/s is required 400N. This seems to be possible to offset with higher efficiency of bigger propeller, but bigger propeller requires higher torque. With direct drive electric motors higher torque can be achieved only with bigger motor diameter, but this means even more drag. With more drag it would be required also more thrust from propeller, which means higher power, higher energy consumption, bigger battery packs, more weight. Another possibility is to install motor in the fuselage and transfer power with belts to pylon, but there are quite high loses in efficiency, more that most engineers imagine and so not in equation. Diameter of upper pulley is usually bigger than lower pulley, due to reduction ratio, which is not helpful from drag viewpoint. And number of propeller blades do not affect much to its efficiency. It is only helpful if prop loading it very high but is also possible to increase chord of propeller blades to some extent. So 700N for FES with 1m prop diameter or 800N with 1,4m (or bigger) retractable system to climb 3m/s, seems to be in advantage of pylon due to better prop efficiency. However, when you put all factors into equation, result is almost the same. However, in the range of lower power settings FES is much more efficient (100N vs 200N). In case of FES self-launch, I feel much safer on critical altitudes till 50m, as in case of motor failure there is still available pure glider efficiency to perform a turn back if required. With retractable systems you end up flying a brick, where you can hardly afford turning back without risk of spin entry. Another big FES advantage is non problematic starting of engine above non landable terrain. With retractable systems you should never try to start engine without landing field below, as in case that engine do not start and cannot be retracted for any reason, you end up flying a brick. Clearly propeller clearance is advantage of pylon, but with pylon there are more problems related to take-off in side-wind conditions. With FES there is much better rudder efficiency. It is hard to compare FES with retractable systems, as they are very different in also in flying style, and all pilots will prefer one over another. I believe that in next months there will be more information about LAK17C FES. |
Luka Žnidaršič wrote on 4/11/2020 1:14 AM:
Note that at LAK17C max power is 30kW. With such power climb performance are very good as there is no pylon drag. The pylon mount allows a much greater choice in propellers, allowing it to significantly exceed an FES in efficiency. The GP15, for example, uses a three blade propeller, and the blade shape is not constrained by the shape of the nose, or the need for low drag when the motor is stopped. The pylon is a single, streamlined strut that will produce almost insignificant drag at climb speeds, even when accounting for the open doors. I base that claim on how well my ASH 26 E thermals with the engine partially retracted for cooling, a much dirtier object than the GP15 pylon. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 |
On Saturday, 11 April 2020 11:51:57 UTC-6, Eric Greenwell wrote:
Luka Žnidaršič wrote on 4/11/2020 1:14 AM: Note that at LAK17C max power is 30kW. With such power climb performance are very good as there is no pylon drag. The pylon mount allows a much greater choice in propellers, allowing it to significantly exceed an FES in efficiency. The GP15, for example, uses a three blade propeller, and the blade shape is not constrained by the shape of the nose, or the need for low drag when the motor is stopped. The pylon is a single, streamlined strut that will produce almost insignificant drag at climb speeds, even when accounting for the open doors. I base that claim on how well my ASH 26 E thermals with the engine partially retracted for cooling, a much dirtier object than the GP15 pylon. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 While classified as a CLass 2 Hang Glider, this machine fits the objectives you defined https://www.youtube.com/watch?v=G3qfW3ydZuY&t=178s Yes they are ridiculously expensive |
I don't pretend to be a techie on the subject of self-launch gliders, but I do have some personal experience to offer. I went to Lithuania in October 2018 to test fly and then buy a LAK17b Mini FES.
The demo Mini was not ready for flying when I arrived, so I made two flights in a LAK17B FES in 18 meter configuration that had been modified with a higher wheel gear and the more powerful generation III battery pak to give it self-launch capability. I believe this is the same FES system that is now being supplied with the new Lak17C FES. I had never flown a motor glider before, but I found launching the LAK17B to be dead simple: twist the power knob to 4500 RPM, keep the tail wheel on the ground until lift off is achieved and then follow a launch trajectory that seemed to me to be very similar to my aero tow experience. I made multiple engine starts and stops in the air to get the hang of the propeller docking system and then landed. On the final day I flew the Mini from the same relatively short paved runway. The take off was much the same, except a bit quicker. Baltic fall weather did not offer any thermals but I found the Mini to be exceptionally responsive and easy to fly – even nicer than my LS-6, which has the reputation of being a very friendly glider. The reason for my Lithuania visit was to determine whether the Mini had good xcountry capabilities, a notable problem with many 13.5 meter ships. When I pushed her, she did not fall out of the sky, but held her own. I later learned that the Mini has recorded several flights in excess of 700 kilometers – good enough for me. I also spent a day touring the LAK factory. I was impressed with the well-equipped and organized factory floor and the obvious professionalism of the 50-odd employees. The place had the feeling of a hard working but friendly family. LAK has been building gliders for 50 years, and it showed. My Mini has been delivered, but I've not flown it yet. Still working my way through the FAA certification process. I'll write a report when I've had some initial flight experience, but meanwhile, here's a cover piece I wrote for Soaring in February 2019: http://front-electric-sustainer.com/...ary%202019.pdf |
Any opinions on the Taurus Electro? Side-by-side, pylon, self-launch, trailer option for solar array charging, etc. They claim the profile of the cockpit/fuselage acts like a lifting body.
I saw one in Robert Mudd's shop at Moriarty.* It appeared to be will
constructed and very roomy, but I think it's considered an ultra light sailplane.* I'm not saying there's anything wrong with that, but it's my opinion, and only my opinion, that it would be more of a floater than a runner.* But it would be nice to cut the tow rope, so to speak. On 4/13/2020 10:37 AM, Duster wrote: Any opinions on the Taurus Electro? Side-by-side, pylon, self-launch, trailer option for solar array charging, etc. They claim the profile of the cockpit/fuselage acts like a lifting body. -- Dan, 5J |
Duster wrote on 4/13/2020 9:37 AM:
Any opinions on the Taurus Electro? Side-by-side, pylon, self-launch, trailer option for solar array charging, etc. They claim the profile of the cockpit/fuselage acts like a lifting body. There at least one of them in the US, so contact them for experienced advice. I believe the 2020 SSA convention had a presentation on it, and perhaps there was an article in Soaring Magazine. There is also at least one gas engine Taurus in the country, another source for info. I've seen both of the referenced gliders fly at Parowan, the pilots and passengers seemed to enjoy the experience. I do envy the ability to taxi upright. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 |
El lunes, 13 de abril de 2020, 13:37:18 (UTC-3), Duster escribió:
Any opinions on the Taurus Electro? Side-by-side, pylon, self-launch, trailer option for solar array charging, etc. They claim the profile of the cockpit/fuselage acts like a lifting body. Very good motor, controller and battery pack. I flew once a taurus with the I.C. engine, very comfy and fun to share with some one at your side. But if you like competitive soaring, is out of the question. |
Taurus is a nice glider. Very roomy, nice side by side configuration when flying with friends or for instruction.
It is very well build. Typical WL with 2 pilots is 38-40 kg/m2 The cruise performance is similar to lightly loaded standard class. The climb performance is more like a heavy loaded standard. It would be an excellent 2 seater with a wing more specifically designed for soaring.With modern 18m wings would make it a fantastic 2 seater. I know the 503 version. I have never flown the electro but it has too limited battery capacity for my need. It would need at least 10 kwh batteries for comfortable operation. |
On Monday, April 13, 2020 at 2:42:54 PM UTC-7, jld wrote:
Taurus is a nice glider. Very roomy, nice side by side configuration when flying with friends or for instruction. It is very well build. Typical WL with 2 pilots is 38-40 kg/m2 The cruise performance is similar to lightly loaded standard class. The climb performance is more like a heavy loaded standard. It would be an excellent 2 seater with a wing more specifically designed for soaring.With modern 18m wings would make it a fantastic 2 seater. I know the 503 version. I have never flown the electro but it has too limited battery capacity for my need. It would need at least 10 kwh batteries for comfortable operation. Electric gliders won't cut it when you have to motor a was to the lift, like at Williams. Once, Jim Leedy and I motored from KRLD to Mt. Rainier in his Taifun to get to the wave lift. Tom |
Jump starting solo motor glider with automobile 12 volt starter | [email protected] | Soaring | 2 | April 2nd 15 07:25 PM |
America Wills Justice as Freedom for Our Stays The Rightardstates 'No Public Option! No Public Option!' | Daryl | Naval Aviation | 0 | May 14th 12 04:40 AM |
Electric Duct Fan (EDF) Self-Launch Glider? | CLewis95 | Soaring | 26 | January 20th 11 06:27 PM |
Electric Glider | Mal | Soaring | 20 | November 2nd 05 10:46 PM |
Toronto Area Glider Pilot Ground School starting Tuesday September 20 | Ulf | Soaring | 0 | September 11th 05 04:59 PM |
