What is best: a round or square chute? Do they differ in time to open? Are
previous experience or training jumps with a square chute mandatory? Is a static line better - if so why? (we have a packer at our club that has recommended square chutes, but apparently two training jumps are mandatory - we are based in South Africa) Sven EY |
I don't think you will find that there are any emergency
prachutes with square canopies, they are all round. The criteria for emergency parachutes is that they should open whatever the attitude of the person using them. Square parachutes while offering more control when open require the wearer to be in a stable position when the chute is deployed, they are therefore less reliable when deployed in anything other than a stable attitude. The Irvin EB** series were reputed to be the fastest opening chutes in the world at one time and they certainly use round canopies (I24). Maybe they still are, I hope so cos that is what I have. At 20:30 05 April 2005, Sven Olivier wrote: What is best: a round or square chute? Do they differ in time to open? Are previous experience or training jumps with a square chute mandatory? Is a static line better - if so why? (we have a packer at our club that has recommended square chutes, but apparently two training jumps are mandatory - we are based in South Africa) Sven EY |
Don Johnstone wrote:
I don't think you will find that there are any emergency prachutes with square canopies, they are all round. I know a number of glider pilots who have them, all experienced skydivers. I believe they use square reserve canopies, which apparently open every bit as quickly as round ones. When asked, the general response is that they feel safer under a square chute... |
prachutes with square canopies, they are all round. Not true. Both Relative Workshop and Strong make emergency rigs that will accept square reserve canopies, and will sell them to you if you convince them you know what you are talking about when you ask for one. They're the only kind I use. Square parachutes while offering more control when open require the wearer to be in a stable position when the chute is deployed, they are therefore less reliable when deployed in anything other than a stable attitude. Not true. Square emergency parachutes are used with freebags (they won't even have a bridle attach point), which allow deployment even if the pilot chute or bridle entangles with the body of the jumper due to an unstable opening. The same is not true of rounds, which are thus more prone to 'horseshoe' malfunctions. Picture what that looks like - if you really want to. The Irvin EB** series were reputed to be the fastest opening chutes in the world at one time and they certainly use round canopies (I24). Maybe they still are, I hope so cos that is what I have. The primary factor affecting the speed of opening (assuming such variables as airspeed, altitude, etc. are kept constant) is the volume of air required to inflate the canopy. Square canopies need less air to inflate, as they are smaller. The can be made smaller since they generate lift, not just drag. Because of this, squares inflate much quicker than rounds designed to carry the same loads - so quickly in fact that all modern squares (other than those used for BASE jumping from VERY low altitude - about 600 ft or less) are equipped with sliders to slow the opening to something only a little faster than rounds. Square sport canopies often have sliders that slow the opening enough to make it 'comfortable' but the emergency parachutes have just enough slider to keep you from breaking your back in a terminal velocity opening. There are actually only two advantages to rounds. The first is cost - old obsolete technology is always cheaper. You can pick up a serviceable round rig for a couple hundred dollars US; a square rig will be newer and more expensive. The second is the reduced need for training. The square parachute is a wing. It must be flown and flared for a landing. Further, for various reasons I will be happy to go into if anyone is interested, it doesn't really fly and flare like a rigid wing. Finding yourself under one with 30 seconds to figure out its flight characteristics and land it in a suboptimal landing area is NOT the hot tip. Much as I dislike rules, I would still recommend a training jump or two for anyone planning to use a square rig without prior experience, as well as briefing from someone who understands both ram-air wing and rigid wing aerodynamics and can prepare you for the differences. Michael |
Thanks for that. It would seem therefore that the standard
conical chute is the only choice for the majority of glider pilots on the grounds that it is likely that we will only ever use it if we have to.As I have already said, if it is good enough for Martin Baker it's good enough for me. I am firmly of the opinion that people who jump out of perfectly serviceable aeroplanes are .........how can I put it.......... lacking in some way. :-) At 21:30 06 April 2005, Michael wrote: I don't think you will find that there are any emergency prachutes with square canopies, they are all round. Not true. Both Relative Workshop and Strong make emergency rigs that will accept square reserve canopies, and will sell them to you if you convince them you know what you are talking about when you ask for one. They're the only kind I use. Square parachutes while offering more control when open require the wearer to be in a stable position when the chute is deployed, they are therefore less reliable when deployed in anything other than a stable attitude. Not true. Square emergency parachutes are used with freebags (they won't even have a bridle attach point), which allow deployment even if the pilot chute or bridle entangles with the body of the jumper due to an unstable opening. The same is not true of rounds, which are thus more prone to 'horseshoe' malfunctions. Picture what that looks like - if you really want to. The Irvin EB** series were reputed to be the fastest opening chutes in the world at one time and they certainly use round canopies (I24). Maybe they still are, I hope so cos that is what I have. The primary factor affecting the speed of opening (assuming such variables as airspeed, altitude, etc. are kept constant) is the volume of air required to inflate the canopy. Square canopies need less air to inflate, as they are smaller. The can be made smaller since they generate lift, not just drag. Because of this, squares inflate much quicker than rounds designed to carry the same loads - so quickly in fact that all modern squares (other than those used for BASE jumping from VERY low altitude - about 600 ft or less) are equipped with sliders to slow the opening to something only a little faster than rounds. Square sport canopies often have sliders that slow the opening enough to make it 'comfortable' but the emergency parachutes have just enough slider to keep you from breaking your back in a terminal velocity opening. There are actually only two advantages to rounds. The first is cost - old obsolete technology is always cheaper. You can pick up a serviceable round rig for a couple hundred dollars US; a square rig will be newer and more expensive. The second is the reduced need for training. The square parachute is a wing. It must be flown and flared for a landing. Further, for various reasons I will be happy to go into if anyone is interested, it doesn't really fly and flare like a rigid wing. Finding yourself under one with 30 seconds to figure out its flight characteristics and land it in a suboptimal landing area is NOT the hot tip. Much as I dislike rules, I would still recommend a training jump or two for anyone planning to use a square rig without prior experience, as well as briefing from someone who understands both ram-air wing and rigid wing aerodynamics and can prepare you for the differences. Michael |
I'd consider installing a ballastic parachute and riding the damaged
glider to the ground surrounded by the cockpit. Charlie "Lite" |
Thanks for that.
You're welcome. It would seem therefore that the standard conical chute is the only choice for the majority of glider pilots on the grounds that it is likely that we will only ever use it if we have to. If by that you mean that you won't train to use your emergency equipment, then you are correct. Stick with the round. Just don't be surprised if it lands you in the hospital. Remember - those maximum loadings are based on a fit man in his 20's wearing boots with ankle support. For a middle aged man wearing tennis shoes, they really ought to be reduced by 30% or so. Not so the weights on squares - they are, if anything, conservative if you know how to land one. I am firmly of the opinion that people who jump out of perfectly serviceable aeroplanes are .........how can I put it.......... lacking in some way. :-) As opposed to the spectacular good sense exhibited by those who fly airplanes that don't even have engines ![]() Glass houses, stones, etc. Michael |
Michael wrote:
If by that you mean that you won't train to use your emergency equipment, then you are correct. Stick with the round. Just don't be surprised if it lands you in the hospital. Remember - those maximum loadings are based on a fit man in his 20's wearing boots with ankle support. For a middle aged man wearing tennis shoes, they really ought to be reduced by 30% or so. I personally know two pilots who had to jump. One broke a leg on landing, the other sprayed an ankle. But believe it or not: Neither of them complained. Stefan |
Michael, I get your point however like many others
I hope that I will never have to use my parachute and if I do I will take my chances. The only thing that I want from it is that it works so how do I judge that? I look at one of the most sucessful canopies there is and think to myself, OK that works I want that one. In my case it is the same canopy that is pressed into the headbox of every MB ejector seat, an Irvin conical, an identical canopy to the one in my pack. I am sure that other canopies are just as good but to my way of thinking, as I never intend to test it I will go with something that will save my life even though I am stupid enough not to get any training in it's use. How do I know the canopy works, take a look at this. http://www.joe-ks.com/Multi_Media/HarrierEjection.htm The pilot was a tad unlucky, he broke his ankle when he landed on his aircraft. I know that the actions of the seat contribute but just look at the rate of descent when the seat clears the cockpit. The seat was actually outside it's required sucess envelope but still the canopy deployed and saved the pilots life. At 19:30 07 April 2005, Michael wrote: Thanks for that. You're welcome. It would seem therefore that the standard conical chute is the only choice for the majority of glider pilots on the grounds that it is likely that we will only ever use it if we have to. If by that you mean that you won't train to use your emergency equipment, then you are correct. Stick with the round. Just don't be surprised if it lands you in the hospital. Remember - those maximum loadings are based on a fit man in his 20's wearing boots with ankle support. For a middle aged man wearing tennis shoes, they really ought to be reduced by 30% or so. Not so the weights on squares - they are, if anything, conservative if you know how to land one. I am firmly of the opinion that people who jump out of perfectly serviceable aeroplanes are .........how can I put it.......... lacking in some way. :-) As opposed to the spectacular good sense exhibited by those who fly airplanes that don't even have engines ![]() Glass houses, stones, etc. Michael |
Emergency Parachute questions | Jay Moreland | Aerobatics | 14 | December 3rd 04 05:46 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
Military jet makes emergency landing at MidAmerica | Otis Willie | Military Aviation | 0 | September 1st 03 02:28 AM |
Emergency landing at Meigs Sunday | Thomas J. Paladino Jr. | Piloting | 22 | August 3rd 03 03:14 PM |
First Emergency (Long Post) | [email protected] | Owning | 14 | July 23rd 03 02:46 AM |
