OLC comment, MOP logging deactivated
Old May 22nd 20, 02:26 AM posted to rec.aviation.soaring
Default OLC comment, MOP logging deactivated
Good day all, before the season start I downloaded the Flarm verion 6.83 and it installed ok.
We just started flying and my declaration is in light grey as the OLC system decla Autocomment: Used Aircraft is FES glider, but MOP logging deactivated.
I looked in my flarm info and the licences present in my flarm include " ENL ".
Any bodie know what this OLC comment refer to
Many Thanks in advance and fly safely
André Pepin Lak 17b fes 21m " DB "
Old May 22nd 20, 03:17 AM posted to rec.aviation.soaring
Dan Daly[_2_]
Hi André - did you do a FES run before T/O for the FLARM to 'see'?
Dan
Old May 22nd 20, 08:56 AM posted to rec.aviation.soaring
JO
Hmm I can clearly see an engine noise run at about 2 hrs into the flight near Williamsburg. I used Seeyou desktop.
Also from OLC FAQs.
1.18 FES aircraft with invalid logger recording, what can I do?
- For aircraft with a too low noise level, for example all aircraft with front electric sustainer (FES), the MOP level must also be recorded.
- Only the MOP2 sensor from LXNAV is approved by the OLC.
Old May 22nd 20, 08:23 PM posted to rec.aviation.soaring
Dave Springford
To expand upon Tim's note:
ENL = Engine Noise Level
MOP = Means of Propulsion
IGC does not allow ENL to be used for electric or Jet engines, they must use MOP sensors.
ENL may be used for gas powered engines. This is not a new change for the IGC, but I think the OLC has just implemented the change in their software.
Many FES owners have been using ENL for years, but it is my understanding that this is no longer allowed by IGC as sufficient proof the FES was not used.
Old May 22nd 20, 10:42 PM posted to rec.aviation.soaring
Tim Newport-Peace[_6_]
use MOP sensors.
software.
used.
It gets better! The LX MOP2 sensor can only be used with specified LXV
Flight Recorders.
Old May 23rd 20, 03:29 PM posted to rec.aviation.soaring
use MOP sensors.
software.
used.
Dave,
Can you point to a current reference for IGC only allowing MOP sensors for
FES please.
SC3C says:
11.2ENL figures –engine on
An ENL of over 700 is expected when the engine is running at climb power.
Over 900 is typical for a two-stroke engine, and over 700 for a
nose mounted 4-stroke. Values of 999 have been recorded with a
two-stroke engine runningat full power, and over 900 for a Forward Electric
System (FES) with the FR close behind it. These high ENLs are
produced for a significant time during a climb and can therefore be
attributed to engine running.
SC3B says:
1.4.2EngineRecordingSystems - General.
Enginerecording is by IGCENL and MOP systems that are designed to
differentiate between conditions of forward thrust from the engine system,
and gliding flight without the use of engine. The low frequency IGC
Environmental Noise Level (ENL) system uses a sensor inside the FR and is
most sensitive to acoustic noise between100and 200Hz. It was originally
designed to record the operation of two-strokepistonengines, but may also
record reasonable ENL numbers with Forward Electric Systems (FES) if the FR
is installed just behind the engine and its retractible propeller (subject
to testing to show this). Where the ENL system does not produce high
enough readings with certain types of engine an d FR installations, either
the FR location must be changed or an additional sensor under the MOP code
must be fitted so that three high MOP numbers are produced in each IGC file
fix line in addition to ENL. Difficult cases for Engine recording are in
1.4.2.2- 1.4.2.5 below, and more detailis in SC3Annex C (SC3C) Chapter 11,
and Chapter 5 of the FR Specification.
Which seems to be saying "Fit a MOP Sensor where ENL is not Satisfactory"
it does not seem to be mandating it in all cases.
Old May 23rd 20, 04:18 PM posted to rec.aviation.soaring
kinsell
use MOP sensors.
software.
used.
Dave,
FES please.
SC3C says:
SC3B says:
Current OLC rules, dated Feb 23, say this:
" Flights, which are performed with motorized gliders, have to be
documented with a recording of the motor's operating time (ENL)..
For aircraft with too low noise level, for example all aircraft with a
front electric sustainer (FES), the MOP level must be recorded in
addition to above."
I just looked at a self-launching twin jet glider, its ENL values during
the launch were only about 100. Wonder if OLC is going to be enforcing
MOP for jets also?
Old May 22nd 20, 08:19 PM posted to rec.aviation.soaring
OLC is now requiring you buy a MOP sensor for electric gliders where previously an ENL sensor was allowed - this is despite, as I understand it, ENL sensors picking up the FES just fine, and being allowed in world competitions.
Without comment bildan Soaring 2 July 1st 11 10:23 AM
A Random Comment birdog[_2_] Piloting 33 June 3rd 10 05:31 AM
jouer gratuit , comment devenir follement riche , jouer au monopolygratuitement en ligne , comment gagner l argent internet , jeux en lignegratuits , jeux gratuits , jouer gratuitement sims , comment devenir riche a, jouer gratuitement , gagner [email protected] Piloting 0 May 12th 09 11:37 AM
Military Command Deactivated Otis Willie Naval Aviation 2 January 10th 06 02:11 PM
No comment Greasy Rider @ invalid.com Simulators 0 December 9th 05 12:21 AM
