Class B bust my fault or the controllers ?
Old May 31st 05, 02:09 AM
Guillermo
wrote in message ...
Guillermo wrote:
"Doug" wrote in message
Uh, If you are on an IFR flight plan, you don't need to hear "cleared
for Class B". At least that is always the way it has worked for me.
If you are in IFR clearance you only got to distinguinsh two classes of
airspace: controlled and uncontrolled. You don't need to worry about
classes of controlled airspace.
Well, you do have to worry about equipage to go above FL 240 (DME) and
above
290 (RVSM).
I'm not planning on going above FL240 in the C172RG that I fly.
I wish I were flying something that could go that high up
What is RVSM?
  #42
Old May 31st 05, 01:06 PM
above
290 (RVSM).
What is RVSM?
Reduced Vertical Separation Minimum. It went into effect in the U.S., Mexico
and Canada this past January 20th, where the former 2,000 feet of vertical
separation above flight level 290 was reduced to 1,000 feet, and you have to
have to have additional approval to operate up there.
  #43
Old May 31st 05, 02:07 PM
Steven P. McNicoll
Mexico
to
Not above FL290, between FL290 and FL410.
  #44
Old May 31st 05, 02:32 PM
Guillermo
ok, so then I'll take the C172RG to FL420 and I'll be OK with no RVSM
link.net...
Mexico
vertical
have
to
  #45
Old May 31st 05, 02:48 PM
Steven P. McNicoll
"Guillermo" wrote in message
Only if you're VFR. If you're IFR you'll have to take the C172RG to FL430.
RVSM ends at FL410 so 2000 feet vertical separation is required for all IFR
aircraft regardless of RVSM capability.
  #46
Old May 31st 05, 06:22 PM
Everett M. Greene
"Guillermo" writes:
in the U.S., Mexico and Canada this past January 20th,
where the former 2,000 feet of vertical separation above
with no RVSM
But then you have to keep your eyes open for low-flying SR-71s!
I believe they're a tad faster than your 172.
Strange limits. You can be cleared to FL410 and above but
how do you get there without the RVSM and DME?
  #47
Old May 31st 05, 07:46 PM
Brad Zeigler
"Everett M. Greene" wrote in message
"Guillermo" writes:
with no RVSM
By climbing through all the altitudes below your clearance altitude.
  #48
Old May 31st 05, 10:22 PM
"Guillermo" writes:
with no RVSM
But, if you are not RVSM compliant, you can't even climb or descend
through the RVSM altitudes unless ATC gives you a dispensation.
  #49
Old May 31st 05, 10:32 PM
Roy Smith
In article , wrote:
"Guillermo" writes:
with no RVSM
Get NASA to give you a lift on one of their shuttle-carrier 747's then
drop you once you're up there. At least that takes care of the
climbing part; I guess you still need to figure out the descending
part.
  #50
Old May 31st 05, 11:57 PM
Jose
.... or you go out over the Pacific ocean. Or is this global?
Jose
The price of freedom is... well... freedom.
Carrying flight gear on the airlines Peter MacPherson Piloting 20 November 25th 04 12:29 AM
World Class: Recent Great News Charles Yeates Soaring 58 March 19th 04 06:58 PM
One Design viability? Stewart Kissel Soaring 41 December 10th 03 03:27 AM
