Class B busted...My problem or the controller's ?
Old May 29th 05, 03:48 AM
Steven P. McNicoll
"Jose" wrote in message
I knew somebody would say that. You'd hear it on the other radio.
No you wouldn't. A stuck mike blocks the frequency.
It might even be the other radio that's causing the problem. i.e. you're
operating split, the copilot is on ground with the stuck mike, and you are
on tower. You take off to do pattern work. Tower tell you to turn off
all your radios. The pilot hears it, the copilot (of course) does not.
The tower isn't going to do that.
  #42
Old May 29th 05, 04:16 AM
Jose
It doesn't block the other frequency.
Maybe your tower won't do that.
Jose
The price of freedom is... well... freedom.
  #43
Old May 29th 05, 04:22 AM
Steven P. McNicoll
m...
It only broadcasts on one frequency.
No tower will.
  #44
Old May 29th 05, 04:31 AM
Jose
Right. The stuck mike is on ground, monitored by the co-pilot operating
split. The other radio is on tower, monitored by the pilot.
Happened at DXR.
Jose
  #45
Old May 29th 05, 04:50 AM
Steven P. McNicoll
m...
Now you're catching on.
Happened at DXR.
Perhaps, but DXR tower didn't tell everyone to turn off all their radios.
  #46
Old May 29th 05, 05:00 AM
Steven P. McNicoll
"Larry Dighera" wrote in message
While the ultimate responsibility for complying with FARs lies with
the PIC, it is my understanding that ATC is mandated by FAAO 7110.65*
to coordinate transit into/through the airspace of other facilities.
Radar controllers are required to coordinate with the control tower for
transit authorization when providing radar traffic advisory service to an
aircraft that will enter a Class D surface area. That's not the situation
here.
  #47
Old May 29th 05, 05:11 AM
Steven P. McNicoll
I think what Antoņio was asking for was a regulation to support the notion
that a pilot can or must refuse an ATC instruction just because compliance
would violate the FARs. That is, what regulation says that other
regulations take precedence over 91.123b (which requires compliance with
ATC instructions, except if there's an emergency need to deviate)? As far
as I can tell, there's no such regulation (although AIM 4-4-1a,b and
4-4-6c are at least tangentially relevant).
From FAA Order 7110.65:
"Pilots are required to abide by CFRs or other applicable regulations
regardless of the application of any procedure or minima in this order."
http://www.faa.gov/atpubs/ATC/Chp2/atc0201.html#2-1-1
  #48
Old May 29th 05, 05:21 AM
Jose
No, just the offending aircraft.
Jose
  #49
Old May 29th 05, 05:23 AM
Steven P. McNicoll
Not that either.
  #50
Old May 29th 05, 05:25 AM
Jose
Not that either.
You were there? I was.
Jose
Sports class tasking [email protected] Soaring 12 April 25th 05 01:32 PM
Class III vs. Class II medical G. Sylvester Piloting 11 February 8th 05 06:41 PM
One Design viability? Stewart Kissel Soaring 41 December 10th 03 03:27 AM
RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) Snowbird Owning 77 December 3rd 03 09:10 PM
Copyright Š2004-2025 AviationBanter.
