#41
![]() "Corky Scott" wrote in message ... Speaking of difficult to handle twins. In 1939, the Martin Co. responded to a request for a high speed medium twin engined bomber with a submission that was named the "Marauder" and designated the 26th such commissioned design, or B-26. Martin assigned a young aerodynamics engineer to the task of designing the airplane. The same guy (Ted Smith ?) who designed the Rockwell/AeroCommander series, now called the Twin Commander. |
#42
![]() "Corky Scott" wrote in message ... The reason for this was due less to the robust construction of the bomber or it's flight characteristics than to the Luftwaffe's orders to concentrate on the heavy bombers at the expense of all other operations. When the heavies were up, it was usually because the weather favored visual bombing. That being the case, all other bombers were usually also flying missions. The Luftwaffe did not have the numbers to respond to each and every type of enemy incursion, so they concentrated on the heavies. So the Marauders kind of drew a bye when they flew on bombing missions. They even got lucky with the AA artillery because most of it was removed from the fronts to surround the cities in defense against the heavy bomber attacks. But the missions were not a piece of cake as any B-26 combat veteran can tell you, there was plenty enough AAA still around to make missions harrowing. And IIRC, the B-26 drew mostly low level attack missions which drew all sorts of fire, most of it more accurate than the high level bombing!?!? |
#43
Corky Scott wrote:
Many of the training flights involved takeoff at max gross. At that weight during takeoff, the loss of an engine or having the prop slip to flat pitch was disasterous. The bomber rolled into the dead engine virtually instantaneously and pitched into Tampa Bay, or impacted the ground upside down. "One a day in Tampa Bay" became the bitter refrain. Martin provided instructions for recovery from an engine failure. The Army had it's own standard procedure, however, and refused to make a type-specific exception. Eventually the accident rate forced them to change to the procedure recommended by Martin, and the accident rate went down to one typical for twins. The Army never did like type-specific training, however, and retired all the 26s as soon as it could. My father worked on the Martin assembly line in Baltimore. My mother worked there in the accounting department. She says that you wouldn't think it possible that they could lose something the size of one of "those big flying boats" (as she calls them), but, according to her, they did. George Patterson Why do men's hearts beat faster, knees get weak, throats become dry, and they think irrationally when a woman wears leather clothing? Because she smells like a new truck. |
#44
![]() "George Patterson" wrote My father worked on the Martin assembly line in Baltimore. My mother worked there in the accounting department. She says that you wouldn't think it possible that they could lose something the size of one of "those big flying boats" (as she calls them), but, according to her, they did. Nah, they didn't lose it! Someone stole it, one piece at a time, and took it out of the plant in their lunch bucket. ;-o -- Jim in NC |
#45
![]() "Larry Dighera" wrote in message ... On Wed, 01 Jun 2005 18:22:00 GMT, "Mike Rapoport" wrote in t:: Any twin can be banked into the dead engine and controlled, it is only a matter of airspeed. At low altitude, that becomes problematic. Airspeed and altitude are really the same thing in this arena...energy. Low, slow and in a high drag configuration is what you don't want. If memory serves, the Aerostar has only one hydraulic pump and won't climb with the gear down. Have you any idea which engine powers the hydraulic pump? I don't remember but I think that it is mentioned in the Aerostar section of the Used Aircraft Guide which, unfortunately, is not at hand. Basically, as Michael points out there are conditions where any twin can climb on one engine and conditions where they can't (this isn't really true for Part 25 certified twins) and different airplanes have different "weaknesses". Some have minimial power, some can't climb with the gear down, some with gear and flaps. The reason for all this is that manufacturers keep increasing the gross weight until performance is marginal. MU-2 weak points are slow gear retraction, big flaps and a wide gap between Vr and Vyse (about 50kts). Mike MU-2. |
#46
George Patterson writes:
wrote: It sounds like once the aircraft gets near that point, there isn't much you could do. Chop power to the operating engine. Yeah, I see why that works. I also see why people might not always remember to do it at the right moment. Yes, loss of some more power is *clearly* better than loss of control, when I'm calmly thinking about it at my desk. But in the cockpit, when I've already lost half my power and am having trouble dealing with it, I can see why people get it wrong now and then. -- David Dyer-Bennet, , http://www.dd-b.net/dd-b/ RKBA: http://noguns-nomoney.com/ http://www.dd-b.net/carry/ Pics: http://dd-b.lighthunters.net/ http://www.dd-b.net/dd-b/SnapshotAlbum/ Dragaera/Steven Brust: http://dragaera.info/ |
#47
On Wed, 01 Jun 2005 15:03:52 GMT, "Mike Rapoport"
wrote: wrote in message roups.com... An engine loss in a Garrett powered aircraft such as the Swearingen or MU-2 would be quite noticeable at any power setting. The Negative Torque Sensor (NTS) on the Garrett TPE331's will dump oil pressure from the prop dome when the engine flames out. The spring load on the prop will drive the prop to a high pitch, lower drag configuration, but does not feather the prop. The pilot must manually perform this task. I have been told that in a MU-2 with a four bladed prop, should an engine quit and the NTS fail, a minimun turn of 90 degress will occur before the pilot gets the prop feathered. The NTS should be checked every engine start and is a no go item should it not test properly. The Searingen Metro, like th MU-2, is a handful of airplane with 2 pilots and 2 engines. One pilot and one engine? ew....... G. Lee It is not quite as bad as all that. NTS failures on takeoff are saveable at least in the simulator but immediate feathering is required. The airplane will not yaw or roll 90 deg. I have experienced (in the simulator) NTS failures on takeoff in the Turbo Commander (TPE-331 powered) and agree that it was saveable in this airplane. I have also experienced uncommanded thrust reverser deployments in Citation Bravo Simulator and found this to be at least as much a handful as the NTS failure. Both simulators were at Flight Safety International and were full motion machines. Klein |
#48
Morgans wrote:
Nah, they didn't lose it! Someone stole it, one piece at a time, and took it out of the plant in their lunch bucket. ;-o So, somewhere out there there's an entire Martin Mars hidden away? I guess it'll show up at Fantasy of Flight sooner or later. :-) George Patterson Why do men's hearts beat faster, knees get weak, throats become dry, and they think irrationally when a woman wears leather clothing? Because she smells like a new truck. |
#49
"George Patterson" wrote in message
news:I4une.4992$Sl5.2242@trndny08... snippage "My father worked on the Martin assembly line in Baltimore." Hence the B26's other nickname: "The Baltimore Wh*re" ;O) Jay Beckman PP-ASEL Chandler, AZ |
#50
![]() "George Patterson" wrote So, somewhere out there there's an entire Martin Mars hidden away? I guess it'll show up at Fantasy of Flight sooner or later. :-) Right. Problem is, it will take a while longer than they originally thought. Seems the culprit didn't think it through, quite enough. The thieves are now having to put the parts back together. Problem is, that it is hard to reassemble a prop from all of the 6"" x 8" x 10" chunks that fit in the lunch boxes. That's just the prop. How about the engine case, and tires? g Thanks George. You're a great straight man! -- Jim in NC |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
Tactical Air Control Party Airmen Help Ground Forces | Otis Willie | Military Aviation | 0 | January 22nd 04 02:20 AM |
How much could I get for these back issues? | Aaron Smith | Home Built | 8 | December 15th 03 12:07 PM |
Flight Simulator 2004 Control Issues | SouthBayGuy | Simulators | 22 | November 26th 03 04:31 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
