#41
"Ron Rosenfeld" wrote in message
... You are skipping over the part of the regulation which states that the "point at which the turn may be commenced" is up to the pilot. No, I'm not skipping that at all. I'm simply pointing out that if the pilot is permitted to degenerate the entire thing down to just the reversal itself, how is it that logic doesn't also show that the pilot can degenerate the entire thing down to the final turn to the final approach course? After all, ALL of the elements of the "reversal" are at the pilot's discretion. A 90 degree left turn is "the same" as a 270 degree right turn. If a 270 degree right turn is allowed, then a 90 degree left turn is too. There is no MINIMUM length of an outbound leg. And no specific direction of the turn. There is only a maximum length. Depending on where you start the turn, correct. You can begin your turn (or course reversal if you will), immediately. And the type of turn is entirely at the pilot's discretion. So rather than flying a 270 degree right turn, the pilot can choose a 90 degree left turn. But if you do not see that, then further discussion here is pointless. Ahh, yes...the old "terminate the thread with an ad hominem" tactic. There is certainly nothing wrong with returning to the outbound course after Seal Beach, flying outbound for some length that you determine you want to; and then executing a 45° turn on the charted side, so long as you remain within the mileage limit. But it is not the only valid, legal method of executing the procedure. I never said it was. Pete |
#42
"Lakeview Bill" wrote in message
. .. I have to take issue with your statement: "Seems to be relatively clear that if the entire procedure includes a PT, unless you're being radar vectored or on a labeled NoPT segment, you are required to fly it." But take another look at what the AIM actually says: "A procedure turn is the maneuver prescribed when it is necessary to perform a course reversal..." As I read this, it is saying: If a course reversal IS required, it must be done via a procedure turn. If a course reversal IS NOT required, a procedure turn IS NOT required. .It appears that the intention is to specify the METHOD THAT MUST BE USED if a course reversal is required, not to require a procedure turn under all circumstances... You're right to want to look at the requirement in the context of the preceding sentence (Pete made that point too earlier in the thread). But let's look at the succeeding sentence as well. Here are all three: AIM 5-4-9a: "A procedure turn is the maneuver prescribed when it is necessary to perform a course reversal to establish the aircraft inbound on an intermediate or final approach course. The procedure turn or hold in lieu of procedure turn is a required maneuver. The procedure turn is not required when the symbol 'No PT' is shown, when RADAR VECTORING to the final approach course is provided, when conducting a timed approach, or when the procedure turn is not authorized." When the third sentence lists conditions under which the PT is "not required", it obviously means that you are not required to perform the course reversal at all; it does *not* mean that you may perform the course reversal, but need not use the PT method. And the requirement spoken of in the third sentence is clearly the same one as the requirement spoken of in the second sentence; that is, the second sentence asserts the requirement, and the third sentence gives exceptions to the requirement. Therefore, the second sentence, like the third sentence, is referring to a requirement to perform a course reversal (and to do so via a PT), rather than just referring to a requirement to execute a PT *if* you reverse course. (And therefore the first sentence is just explaining a rationale for prescribing a procedure turn, without yet addressing the mandatory nature of the prescription, which is not asserted until the second sentence.) --Gary |
#43
![]() "Peter Duniho" wrote in message ... I agree with your instructor. AFAIK, there is NEVER a requirement to make a procedure turn. Legal Counsel has issued an opinion, see below. Kris Nov. 28, 1994 Mr. Tom Young, Chairman Charting and Instrument Procedures Committee Air Line Pilots Association 535 Herndon Parkway Herndon, VA 22070 Dear Mr. Young This is a clarification of our response to your letter of August 23, 1993. In that letter you requested an interpretation of Section 91.175 of the Federal Aviation Regulation (FAR) (14 CFR Section 91.175). You address the necessity of executing a complete Standard Instrument Approach Procedure (SIAP) in a non-radar environment while operating under Instrument Flight Rules (IFR). Our response assumes that each of the specific scenarios you pose speaks to a flight conducted under IFR in a non-radar environment. Section 91.175(a) provides that unless otherwise authorized by the Administrator, when an instrument letdown to a civil airport is necessary, each person operating an aircraft, except a military aircraft of the United States, shall use a standard instrument approach procedure prescribed for the airport in Part 97. First you ask whether an arriving aircraft must begin the SIAP at a published Initial Approach Fix (IAF). A pilot must begin a SIAP at the IAF as defined in Part 97. Descent gradients, communication, and obstruction clearance, as set forth in the U.S. Standard for Terminal Instrument Approach Procedures (TERPs), cannot be assured if the entire procedure is not flown. You also ask whether a Distance Measuring Equipment (DME) arc initial approach segment can be substituted for a published IAF along any portion of the published arc. A DME arc cannot be substituted for a published IAF along a portion of the published arc. If a feeder route to an IAF is part of the published approach procedure, it is considered a mandatory part of the approach. Finally, you ask whether a course reversal segment is optional "when one of the conditions of FAR section 91.175(j) is not present." Section 91.175(j) states that in the case of a radar vector to a final approach course or fix, a timed approach from a holding fix, or an approach for which the procedures specifies "no procedure turn," no pilot may make a procedure turn unless cleared to do so by ATC. Section 97.3(p) defines a procedure turn, in part, as a maneuver prescribed when it is necessary to reverse direction to establish the aircraft on a intermediate or final approach course. A SIAP may or may not prescribe a procedure turn based on the application of certain criteria contained in the TERPs. However, if a SIAP does contain a procedure turn and ATC has cleared a pilot to execute the SIAP, the pilot must make the procedure turn when one of the conditions of Section 91.175(j) is not present. If you have any questions regarding this matter, please contact Patricia R. Lane, Manager, Airspace and Air Traffic Law Branch, at (202) 267-3491. Sincerely, /s/ Patricia R. Lane for Donald P. Byrne Assistant Chief Counsel Regulations Division |
#44
"point at which the turn may be commenced" is up to the pilot. No, I'm not skipping that at all. I'm simply pointing out that if the pilot is permitted to degenerate the entire thing down to just the reversal itself, how is it that logic doesn't also show that the pilot can degenerate the entire thing down to the final turn to the final approach course? After all, ALL of the elements of the "reversal" are at the pilot's discretion. A 90 degree left turn is "the same" as a 270 degree right turn. If a 270 degree right turn is allowed, then a 90 degree left turn is too. The difference between the 90 degree left turn and all of the variations of the procedure turn (even with a zero-length outbound leg) is that all those variations have you *established* on the final approach course *prior* to reaching the FAF. In this sense the 90 degree left turn is not equal to the 270 right turn. To me this seems the conceptual basis for the fact that the regs require the procedure turn when it often doesn't "seem" that it should be necessary. Now if you happen to be coming from a direction where you *are* already aligned on the final approach course and at the proper altitude prior to reaching the FAF, I would agree that it doesn't make sense to do the PT (though it may still be technically required by the regs). The basis *I* use for skipping the turn in this case is: 1) I am flying a hold-in-lieu-of-procedure turn, plus 2) I am established in the hold by virtue of being established (+/- 10 degrees) on the inbound course prior to reaching the holding point (the FAF). Ok, its a stretch, but that's how I look at it! Cheers, John Clonts Temple, Texas |
#45
On Mon, 06 Jun 2005 16:53:15 GMT, "Lakeview Bill"
wrote: I have to take issue with your statement: Fair enough, I'm willing to learn - education is always ongoing. But take another look at what the AIM actually says: "A procedure turn is the maneuver prescribed when it is necessary to perform a course reversal..." As I read this, it is saying: If a course reversal IS required, it must be done via a procedure turn. If a course reversal IS NOT required, a procedure turn IS NOT required. .It appears that the intention is to specify the METHOD THAT MUST BE USED if a course reversal is required, not to require a procedure turn under all circumstances... But they specifically enumerate the conditions when procedure turns are not required, the list being vectors to final, NoPT segment, timed approaches, or when not authorized. So, "pilots shall execute the entire procedure commencing at an IAF". If the entire procedure, which therefore only starts when crossing the IAF, requires a procedure turn because you're not covered under the exceptions, it seems that by not executing a procedure turn (in the case of a straight-in crossing a racetrack to the barb side would suffice), you're not in fact flying the entire procedure as required, you're flying it as if you got vectors to final just because you were generally lined up on the inbound course while crossing the collocated IAF/FAF and have elected not to fly the intermediate segment of the approach, going right to just flying the FAF-MAP segment, right? |
#46
And now I have to take issue with myself...
This has nothing to do with nothing, but just for grins, I cranked up the Garmin trainer and flew the KPWK (Chicago/Palwaukee) ILS 16 approach from several different directions. Coming from the south, the Garmin, as expected, flew the teardrop procedure turn. Coming from the north, flying the 160 radial toward the OBK VOR (the IAF), when the Garmin reached the VOR, it reversed course and flew 340 outbound, flew the teardrop procedure turn, and flew back toward OBK. So, it would appear that, at least as far as Garmin is concerned, that the procedure turn must be flown no matter what. Live and learn... "Peter Clark" wrote in message ... On Mon, 06 Jun 2005 16:53:15 GMT, "Lakeview Bill" wrote: I have to take issue with your statement: Fair enough, I'm willing to learn - education is always ongoing. But take another look at what the AIM actually says: "A procedure turn is the maneuver prescribed when it is necessary to perform a course reversal..." As I read this, it is saying: If a course reversal IS required, it must be done via a procedure turn. If a course reversal IS NOT required, a procedure turn IS NOT required. .It appears that the intention is to specify the METHOD THAT MUST BE USED if a course reversal is required, not to require a procedure turn under all circumstances... But they specifically enumerate the conditions when procedure turns are not required, the list being vectors to final, NoPT segment, timed approaches, or when not authorized. So, "pilots shall execute the entire procedure commencing at an IAF". If the entire procedure, which therefore only starts when crossing the IAF, requires a procedure turn because you're not covered under the exceptions, it seems that by not executing a procedure turn (in the case of a straight-in crossing a racetrack to the barb side would suffice), you're not in fact flying the entire procedure as required, you're flying it as if you got vectors to final just because you were generally lined up on the inbound course while crossing the collocated IAF/FAF and have elected not to fly the intermediate segment of the approach, going right to just flying the FAF-MAP segment, right? |
#47
![]() Lakeview Bill wrote: And now I have to take issue with myself... This has nothing to do with nothing, but just for grins, I cranked up the Garmin trainer and flew the KPWK (Chicago/Palwaukee) ILS 16 approach from several different directions. Coming from the south, the Garmin, as expected, flew the teardrop procedure turn. Coming from the north, flying the 160 radial toward the OBK VOR (the IAF), when the Garmin reached the VOR, it reversed course and flew 340 outbound, flew the teardrop procedure turn, and flew back toward OBK. So, it would appear that, at least as far as Garmin is concerned, that the procedure turn must be flown no matter what. Live and learn... As someone who was involved in a previous life with the FAA's groping with course reversal issues, and now a user of Garmin's fine panel mount products, my hat is off to Garmin's implementations with a lot of this RNAV stuff...far beyond when a course reversal is required. |
#48
I'd like to know what some of the freight dogs do. They fly into
smaller airports without radar coverage, so they are flying full approaches. Dollars to doughnuts they aren't going to be wasting any time going around in useless circles. The rules have to make sense. Pattern entries, intercepting tracks, entering holds all call for the smoothest, least amount of manuevering that works. There HAS to be a rhyme and reason in the regs, and, in spite of all the moaning and groaning, there usually is. When there isn't you get a rule that isn't being followed. Sometime later that rule is changed to adopt the sensible procedures. I don't even think the regs require useless procedure turns and holds when you are already on course. But some of you seem to be fixated on it for some inane reason (instructor superiority/student confusion complex?). It is a required manuever for a COURSE REVERSAL. It's not a required manuever if you are already on course. Ditch the rhetoric and useless redundancy. Fly the plane like it's supposed to be flown, safely and efficiently. Don't make up your own procedures, follow the charted approach. But use some common sense. If YOUR instructor told you it was necessary, don't just blindly pass that misinformation along to the next generation of pilots. Get rid of the obsolete and useless, latch onto the efficient and reasonable. Fly the airplane, not the regs. |
#49
I agree completely with the sense of your post. In your own flying,
for this purpose how do you define "on course"? +/- 10 degrees? 30? 45? 90? -- Cheers, John Clonts Temple, Texas N7NZ |
#50
![]() "John Clonts" wrote in message ps.com... I agree completely with the sense of your post. In your own flying, for this purpose how do you define "on course"? +/- 10 degrees? 30? 45? 90? Don't forget altitude too! |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
Sports class tasking | [email protected] | Soaring | 12 | April 25th 05 01:32 PM |
Agent86's List of Misconceptions of FAA Procedures Zero for 15 Putz!!! | copertopkiller | Military Aviation | 11 | April 20th 04 02:17 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
Instrument Approaches and procedure turns.... | Cecil E. Chapman | Instrument Flight Rules | 58 | September 18th 03 10:40 PM |
