#41
On Thu, 23 Jun 2005 21:27:25 UTC, Don Johnstone
wrote: Now here's a question. Given the answer above why when the wing drops at the start of a take off run (winch or aero-tow) does everyone almost without exception try and lift the downgoing wing with aileron? Define "drops". How do you keep your wings level on the takeoff run? Ian -- |
#42
I'll bite Ian
I suspect that keeping the wing off the ground with aileron in the initial part of the ground run works because with the tailwheel/ skid on the deck the effects of adverse yaw & secondary effect roll are negated. There is no way on Gods earth that the rudder of the Nimbus is going to accelerate a dropping wing at the beginning of the ground run. Personally I thing the rudder of the Nimbus is there because us pilot types wouldnt but an hairyplane without one ![]() Ian |
#43
OK. For the wing drop I take the recovery action for
that. Spinning is more than stalling with the wing down or indeed with wing drop. A spin involves the aircraft autorotating with yaw, roll and pitch movement. I suppose you could say that if there significant yaw present then that needs to be stopped. I think the important point is that the angle of attack needs to be reduced. If that can be achieved by use of the elevator then that is all that is required. I am not sure that I can explain satisfactorily in words, but I could definitely demonstrate the difference. At 22:24 23 June 2005, Ian Johnston wrote: On Thu, 23 Jun 2005 21:27:25 UTC, Don Johnstone wrote: The answer is again simple and goes to recognition. A stall with wing drop is just that and provided action is taken to solve that problem, unstall the wing, the a spin will be prevented. A spin is the result of failure at the first step for whatever reason. Everyone properly trained will know the difference. OK, so how would you described the difference. How far does the wing have to drop before /you/ use spin recovery rather than stall recovery? I'm genuinely interested: it's not supposed to be a trick question in any way. Ian |
#44
On Thu, 23 Jun 2005 16:34:41 -0500, Bob Johnson
wrote: Has anyone mentioned the yaw string on these wide birds? What's it doing during incipient diving vs. spinning? During lots of spin training flights (that include spiral dives to show the difference) I *never* looked at the yaw string. Even in a big bird the diffrence between a dive and a stall/spin is easy to detect (and recover) if you have a little experience in this glider and halfways correct spin training. Frankly spoken, pulling the stick back hard enough to break off the wings shows that the pilot was lacking the most basic skills to fly that bird. Bye Andreas |
#45
On 23 Jun 2005 21:27:25 GMT, Don Johnstone
wrote: Now here's a question. Given the answer above why when the wing drops at the start of a take off run (winch or aero-tow) does everyone almost without exception try and lift the downgoing wing with aileron? .... because it works in 99 percent of the cases? Bye Andreas |
#46
At 02:06 24 June 2005, Andreas Maurer wrote:
On Thu, 23 Jun 2005 16:34:41 -0500, Bob Johnson wrote: Frankly spoken, pulling the stick back hard enough to break off the wings shows that the pilot was lacking the most basic skills to fly that bird. well, possibly, but having got to the position where you could either go through Vd or pull back what would YOU do? |
#47
![]() Bob Johnson: pulling the stick back hard enough to break the wings shows pilot .. lacking .. skills to fly that bird. Robert William wrote: having got to the position where you could either go through Vd or pull back what would YOU do? Is, 'Not getting into that position', an allowed response? Jon. |
#48
Ian Johnston wrote:
In real life, on the final turn, you have approximately 0.3 seconds to answer this question ... I've always wondered about those "final turn spins". Yes, I know they happen. I'm wondering nonetheless. It has been hammered in my heat right from day one to watch that approach speed and to stay coordinated on approach. Tolerance on the slow side: None. We won't let a student solo before we are absolutely, positively sure he can and will acomplish this. And when he gets his license, this will have become second nature to him (just as not pulling back in a spin). I'm not a great pilot and I'm making mistakes all the time. I can think of a lot of ways how I could loose my life in a glider. But I'm absolutely, positively sure that stalling/spinning in the final turn will *not* be one of them. Stefan |
#49
Ian Johnston wrote:
In real life, on the final turn, you have approximately 0.3 seconds to answer this question ... I've always wondered about those "final turn spins". Yes, I know they happen. I'm wondering nonetheless. It has been hammered into my head right from day one to watch that approach speed and to stay coordinated on approach. Tolerance on the slow side: None. We won't let a student solo before we are absolutely, positively sure he can and will acomplish this. And when he gets his license, this will have become second nature to him (just as not pulling back in a spin). I'm not a great pilot and I'm making mistakes all the time. I can think of a lot of ways how I could loose my life in a glider. But I'm absolutely, positively sure that stalling/spinning in the final turn will *not* be one of them. Stefan |
#50
Don Johnstone writes
The answer is again simple and goes to recognition. I think that was the point of the BGA's question ![]() A stall with wing drop is just that and provided action is taken to solve that problem, unstall the wing, the a spin will be prevented. A spin is the result of failure at the first step for whatever reason. Everyone properly trained will know the difference. I know the theoretical and practical difference between a spin and a stall with or without a wing drop, and understand the difference in recovery for each. However, The BGA Instructor's Course question asked: "The offical recovery from a stall with wing drop is different from the official recovery from a spin. At what point do you, personally, transition from one to the other?" At what point do you NOT put the stick forward to reduce AoA and alleviate the stall and instead centre the controls then kick a boot full of opposite rudder in to stop the spin? Assuming no flaps, that is... Or is the question, and the suggestion that you transit from one recovery procedure through to the other at some definite point in time, intrinsically wrong? Should it be, "What is the difference between a stall with wing drop and a fully developed spin?" I have thought about this and decided that if I ever get to the point where I do get to a fully developed spin at final turn height I am going to spin in, rather that than tent peg half way through the recovery. Presumably working on the grounds that impacting at the lower, stable velocity of a spin is going to hurt less than doing so at the higher, increasing velocity of the initial part of the recovering dive? I can appreciate the sense in that argument, though personally I doubt I could accept the inevitability of the impact without putting up a struggle and trying to recover despite the futility of the situation. My philosophy teaches recognition of the approach of the problem so it can be prevented and this is still not given sufficient emphasis in training. It was in mine. Repeatedly hammered into me through graphic description and demonstration by a number of different instructors throughout the period of my training. Yes train people to recover from fully developed spins but if you do the job right and train so that they recognise the approach and take the correct preventative action they will never need to recover from a spin. Though that overlooks the other essential advantage of spin training. It teaches familiarity and confidence with the aircraft in unusual and discomforting attitudes, which, IMHO, makes you far less likely to panic and make a potentially bad situation terminally worse if you ever find yourself there, whether through fault of your own or otherwise. Besides which, as one of my favourite instructors was once quoted as saying when asked why he had spun on a certain occasion; "Well, it's just about one of the most exiting things you can do in a glider". That is, of course, unless the glider concerned is a Fox ![]() -- Bill Gribble http://www.scapegoatsanon.demon.co.uk - Learn from the mistakes of others. - You won't live long enough to make all of them yourself. |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
bush rules! | Be Kind | Military Aviation | 53 | February 14th 04 04:26 PM |
AmeriFlight Crash | C J Campbell | Piloting | 5 | December 1st 03 02:13 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
