What would you do in this situation? You're on the GPS-22 into Ellenville,
NY (http://204.108.4.16/d-tpp/0508/09390G22.PDF), planning to land straight-in. Note the high MDA (1800 AGL). There's no weather reporting at your destination, but several nearby airports are saying anywhere from 2-1/2 to 4 mile visibility. For the sake of argument, assume it's 2-1/2 miles where you are. There's scattered CU at about 4000, but you're below that already. It's daytime, winds are light out of the south. You're 2 miles from YARNN at the MDA and have good ground contact ahead and to both sides. You can also see the ridgeline east of the final approach course which is represented by the 1850 elevation marker. What you don't see is the runway, or any of the other things called out in 91.175(c)(3). You know from experience that this is a difficult airport to spot even in good VFR because it blends in with the surrounding terrain. You were cleared for the approach at Kingston VOR, and are long out of radar and radio contact with ATC. If you stay at the MDA (as 91.175(c) requires), it's unlikely you will ever see the runway, as it will quickly disappear under the nose of the airplane. Your GPS is providing you VNAV guidance, and you are already above the synthetic glide slope. You're well above the minimums for a contact approach, but since you're out of radio contact, you can't ask for one; your current clearance is for the GPS-22. Continuing your descent below the MDA, but staying above the VNAV glideslope it technically not legal, but seems like a "no harm, no foul" kind of violation. What would you do? |
On Sat, 13 Aug 2005 20:53:16 -0400, Roy Smith wrote:
If you stay at the MDA (as 91.175(c) requires), it's unlikely you will ever see the runway, as it will quickly disappear under the nose of the airplane. Your GPS is providing you VNAV guidance, and you are already above the synthetic glide slope. You're well above the minimums for a contact approach, but since you're out of radio contact, you can't ask for one; your current clearance is for the GPS-22. Continuing your descent below the MDA, but staying above the VNAV glideslope it technically not legal, but seems like a "no harm, no foul" kind of violation. If it was me, I would not descend below MDA. I would descend to MDA, overfly the runway and join the landing pattern to land. I looked at airnav.com but it didn't give the pattern altitude. I am not familiar with the terrain, but the picture at airnav.com made it seem like it would be a rather easy airport to spot being it's an open spot in the forest of trees. Allen |
In article , Roy Smith
wrote: What would you do in this situation? ... If you stay at the MDA (as 91.175(c) requires), it's unlikely you will ever see the runway, as it will quickly disappear under the nose of the airplane. Your GPS is providing you VNAV guidance, and you are already above the synthetic glide slope. You're well above the minimums for a contact approach, but since you're out of radio contact, you can't ask for one; your current clearance is for the GPS-22. Continuing your descent below the MDA, but staying above the VNAV glideslope it technically not legal, but seems like a "no harm, no foul" kind of violation. What would you do? I wouldn't descent below MDA, no. That seems like a very bad idea. I WOULD continue the approach to the MAP, though, rather than bailing on it early. Yes, the runway will quickly disappear under the nose, but note that the circling MDA and the straight-in MDA are the same. Level off at 2080, and you'll likely see the runway before the MAP. Descend as you circle to the right (since it notes no circling east of the runway), and you should have plenty of room to set yourself up for a nice landing. Even a normal traffic pattern altitude should keep you well above the obstacles on the west side. Nothing says you can't circle right back to the "straight-in" runway; sometimes, that's the only way you can do it, and this seems like one of those cases. Hope that helps. -- Garner R. Miller ATP/CFII/MEI Clifton Park, NY =USA= |
What would you do in this situation? You're on the GPS-22 into Ellenville, NY (http://204.108.4.16/d-tpp/0508/09390G22.PDF), planning to land straight-in. Note the high MDA (1800 AGL). There's no weather reporting at your destination, but several nearby airports are saying anywhere from 2-1/2 to 4 mile visibility. For the sake of argument, assume it's 2-1/2 miles where you are. There's scattered CU at about 4000, but you're below that already. It's daytime, winds are light out of the south. You're 2 miles from YARNN at the MDA and have good ground contact ahead and to both sides. You can also see the ridgeline east of the final approach course which is represented by the 1850 elevation marker. What you don't see is the runway, or any of the other things called out in 91.175(c)(3). You know from experience that this is a difficult airport to spot even in good VFR because it blends in with the surrounding terrain. You were cleared for the approach at Kingston VOR, and are long out of radar and radio contact with ATC. If you stay at the MDA (as 91.175(c) requires), it's unlikely you will ever see the runway, as it will quickly disappear under the nose of the airplane. Your GPS is providing you VNAV guidance, and you are already above the synthetic glide slope. You're well above the minimums for a contact approach, but since you're out of radio contact, you can't ask for one; your current clearance is for the GPS-22. Continuing your descent below the MDA, but staying above the VNAV glideslope it technically not legal, but seems like a "no harm, no foul" kind of violation. What would you do? I would not go below MDA. If I had the airport in sight at YARNN, I would probably do a circle-to-land on 22 (or possibly 4 depending on the winds). So far as a contact approach, I thought you had to have reported visibility at the destination airport of 1+miles in order to be cleared. I don't see that N89 has weather reporting. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
![]() "Roy Smith" wrote in message ... What would you do in this situation? You're on the GPS-22 into Ellenville, NY (http://204.108.4.16/d-tpp/0508/09390G22.PDF), planning to land straight-in. Note the high MDA (1800 AGL). There's no weather reporting at your destination, but several nearby airports are saying anywhere from 2-1/2 to 4 mile visibility. For the sake of argument, assume it's 2-1/2 miles where you are. There's scattered CU at about 4000, but you're below that already. It's daytime, winds are light out of the south. You're 2 miles from YARNN at the MDA and have good ground contact ahead and to both sides. You can also see the ridgeline east of the final approach course which is represented by the 1850 elevation marker. What you don't see is the runway, or any of the other things called out in 91.175(c)(3). You know from experience that this is a difficult airport to spot even in good VFR because it blends in with the surrounding terrain. You were cleared for the approach at Kingston VOR, and are long out of radar and radio contact with ATC. If you stay at the MDA (as 91.175(c) requires), it's unlikely you will ever see the runway, as it will quickly disappear under the nose of the airplane. Your GPS is providing you VNAV guidance, and you are already above the synthetic glide slope. You're well above the minimums for a contact approach, but since you're out of radio contact, you can't ask for one; your current clearance is for the GPS-22. Continuing your descent below the MDA, but staying above the VNAV glideslope it technically not legal, but seems like a "no harm, no foul" kind of violation. A contact approach isn't available anyway as there is no weather reporting. |
Nope. Not going below MDA. Go to the MAP, look for the runway. If I'm
concerned that it would go under the nose, I might fly a hair right to put it to my left so I could see it. Then circle to land as appropriate. I don't know why the MDA is what it is, and on approach is not the place to bet your life on speculation. Jose -- Quantum Mechanics is like this: God =does= play dice with the universe, except there's no God, and there's no dice. And maybe there's no universe. for Email, make the obvious change in the address. |
Roy Smith wrote:
What would you do? Go missed. Climb and re-establish radio contact. Re-do the approach and while still in contact with approach, request a contact approach.. or cancel IFR and request a special VFR clearance. Dave |
![]() "Dave S" wrote in message nk.net... Go missed. Climb and re-establish radio contact. Re-do the approach and while still in contact with approach, request a contact approach.. or cancel IFR and request a special VFR clearance. Roy said there's no weather reporting at this location. That rules out a contact approach and SVFR. |
In article et,
"Steven P. McNicoll" wrote: "Dave S" wrote in message nk.net... Go missed. Climb and re-establish radio contact. Re-do the approach and while still in contact with approach, request a contact approach.. or cancel IFR and request a special VFR clearance. Roy said there's no weather reporting at this location. That rules out a contact approach and SVFR. Yes, I know both the Contact and SVFR were unavailable. On the other hand, people were flying around VFR. I know my original statement of "assume it's 2-1/2 miles where you are" eliminated VFR from the list of legal alternatives, but for all I know, it really was 3 or 4 miles. I could have gone missed, gotten back in contact with ATC, cancelled IFR, and then proceeded back to the airport VFR. But that seems totally pointless. What if I hadn't asked you to assume it was 2-1/2 miles? The rest stays the same, ATIS at several airports in the area reporting variously 2-1/2, 3, and 4 miles. Lacking an official report, the best I can say is "an honest evaluation of flight visibility by the pilot could have reasonably been said to be 3 miles". |
![]() "Roy Smith" wrote in message ... Yes, I know both the Contact and SVFR were unavailable. On the other hand, people were flying around VFR. I know my original statement of "assume it's 2-1/2 miles where you are" eliminated VFR from the list of legal alternatives, but for all I know, it really was 3 or 4 miles. I could have gone missed, gotten back in contact with ATC, cancelled IFR, and then proceeded back to the airport VFR. But that seems totally pointless. What if I hadn't asked you to assume it was 2-1/2 miles? The rest stays the same, ATIS at several airports in the area reporting variously 2-1/2, 3, and 4 miles. Lacking an official report, the best I can say is "an honest evaluation of flight visibility by the pilot could have reasonably been said to be 3 miles". Are you asking what's legal or what's wise? Assuming the former, as long as you have at least three miles visibility and remain at least 500 feet below, 1000 feet above, and 2000 feet lateral clearance from all clouds I'd say you can legally land. FAR 91.175 would no longer apply as you're no longer operating under IFR. |
ASW19b best descent rate on approach (full airbrakes) | Robert Sharpe | Soaring | 1 | April 30th 05 11:41 AM |
descent below minimums | hsm | Instrument Flight Rules | 82 | January 11th 05 06:33 PM |
BRS and descent rate | Roger Long | Piloting | 21 | May 7th 04 05:34 PM |
Avoiding Shock Cooling in Quick Descent | O. Sami Saydjari | Owning | 32 | January 21st 04 04:32 AM |
Minimum rate of climb or descent | Aaron Kahn | Instrument Flight Rules | 3 | July 25th 03 03:22 PM |
