#41
On Tue, 30 Aug 2005 11:44:23 -0700, "RST Engineering"
wrote: That wasn't the point, Orval. The original discussion revolved around the tendency of most aircraft tubes to diffuse air through the walls of the tube -- deflate themselves by spontaneous diffusion as it were. THe reason given was that the specification for aircraft tubes uses a material that is obsolete in the real world but still used in the make-believe world of aviation. Somebody brought up the point that Desser (via Michelin?) has come up with a "no leak" tube that is blessed for aviation use. Some of the group on here reported that the "no leak" was in fact just that and a few of the folks plan on switching to that tube at the next opportunity. They are called "Leak Guard". I thought I paid $12, but it was $28 each for 6.00 X 6 tubes through Desser. When installing them you fit the tube into the tire with talcum powder just like a regular ones. Line up the dots, bars, or what ever, toque the bolts in the split rim, Inflate it, deflate it, and re inflate. They aren't completely leak proof, but they hold air much longer than the old tubes. I already mentioned they were only down 4 psi after 6 weeks. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com (You left a B out of your signature line.) Jim |
Tires again (but this time on the tow vehicle) | Papa3 | Soaring | 37 | February 7th 05 02:30 PM |
WTB: Good Set 500 x 5 Wheels, Tires and Brakes | Steve Sharp | Owning | 0 | March 20th 04 04:48 AM |
WTB: Good Set 500 x 5 Wheels, Tires and Brakes | Steve Sharp | Restoration | 0 | March 20th 04 04:48 AM |
Flat Spin | JJ Sinclair | Soaring | 34 | February 10th 04 05:57 PM |
Tire Stiffness & trailer swaying - resolution | chris | Soaring | 6 | October 26th 03 03:50 PM |
