First Soaring Experience
Old September 1st 05, 10:19 PM
Don Hammer
I always thought it was great fun taking my professional pilot friends
up in a glider for the first time. They find out their feet are used
for more than going back and taking a leak.
I fly power for transportation and gliders to really experience
flying. Nothing like circling in a thermal with a gaggle of hawks.
Once you get it in your mind that in most cases you can find some
place to safely land, you'll relax and have a ball. Realizing that
many glass ships have a glide ratio in the range of 35:1 to 53:1,
finding a landing place from 1000 AGL in most parts of the country is
not especially hard.
Get the rating -you'll be a better pilot for the effort.
Old September 1st 05, 10:35 PM
Stefan
You're scaring me. A glider pilot knows *always* where he will safely
land should the lift disappear. (And safely means with the glider
intact.) This is basic cross country tactics and essential for a long
life. Easy in some areas, some planning required in others.
Stefan
Old September 2nd 05, 09:07 PM
Don Hammer
Stefan
Didn't mean to imply that. In the years of glider flying I've done
there has never been a time I couldn't find a safe landing spot from
where I was, cross country or otherwise. I can't say that if the prop
stops in the light aircraft I fly I would be able say the same.
Look at it this way - In a Cessna, on a standard 3 degree glide slope
or VASI, you won't make the airport from the outer marker without the
engine. Try it some time. When I'm in a light aircraft I'm always
tooking for a landing spot under me.
When flying a high performance glider, at any reasonable altitude,
your glide will take you to places you can't see, but yes you plan,
but you don't have to be obsessive about it. Can you get in a place
where you can't land? Sure. I once was on a flight test of an ASH-25.
We towed to 10K AGL on a cold day with little or no lift. We flew
over 50 miles from the airport and returned. Total flight time was 1
hour 55 min. With zero lift from 10K we had over a 100 mile circle to
find a safe spot to land. In my area, I'm sure that includes at least
a hundred airports or strips and at least 10 times as many farmer's
fields. Did I spend any mental time worring about finding a landing
spot? I think not, but I sure as hell enjoyed myself.
Old September 2nd 05, 09:24 PM
Stefan
Thst's how I handle it (and I guess, most of us do): In a glider, I have
always an option to safely land without any damage to the glider. In a
powered plane, I have always an option to do a survivable crash.
As I said, this depends on where you're flying. In the mountains, you
better be *very* obsessive about it, or you'll find yourself in a very
uncomfortable situation sooner than you've expected. There are
"outlanding field directories" for the Alps, and I have the known
landing options marked on my map. Plus, in the Alps, we do our landing
options calculations with only half the nominal L/D ratio, which
translates to roughly 1:20 for a standard 15m glider. Believe me, even
with this conservative approach, it can get pretty uncomfortable when
you hit an unexpected downdraft.
Stefan
Old September 2nd 05, 12:23 AM
Brian
Yeah I forgot the mention The Blanik is sort of the VW Bus of Gliders.
When you start flying the 35:1 Fiberglass gliders you find out what
Smooth and quiet really with nice light controls.
Brian
Old September 1st 05, 06:29 PM
Gene Seibel
Great write up. I did the glider thing last year and it's awesome.
Gene Seibel
Tales of Flight - http://pad39a.com/gene/tales.html
Because I fly, I envy no one.
Great Britain - soaring weather forecasts Jack Glendening Soaring 4 August 3rd 05 08:40 AM
Introducing NJ's Newest Soaring Club! Jim Buckridge Piloting 2 February 22nd 05 04:07 PM
Soaring Seminar - March 19th - ChicagoLand Glider Council ContestID67 Soaring 4 January 6th 05 11:28 PM
Possible future legal problems with "SOARING" Bob Thompson Soaring 3 September 26th 04 11:48 AM
January/February 2004 issue of Southern California Soaring is on-line [email protected] Soaring 8 January 4th 04 09:37 PM
