#41
James Robinson wrote:
Cub Driver wrote: ThomasH wrote: It almost sounds as if you would be believing that Airbus is French. :-) It is, for all practical purposes. There would be no Airbus without France; it's located in Toulouse; and France is the largest stakeholder. Not true. The Toulouse plant may be where final assembly is done, and where the operating headquarters of Airbus is located, but there are a number of other manufacturing plants, and France is not the largest stakeholder. The company is 20% owned by British Aerospace, with the remaining 80% owned by EADS. According to the following site, the ownership or EADS is: http://www.reports.eads.net/2004/ar_...c_b3_3_3_0.php - 30.2% Daimler Chrysler - 15.1% Government of France - 15.1% Lagardère (A French corporation) - 5.5% Government of Spain - 33.2% Publicly held shares Therefore, the French government only owns about 12% of airbus, and is not the largest shareholder. Why should that interest anyone? What those figures do show is that French ownership is in the range 24.16 to 50.72 %, depending on what portion of the "Publicly held shares" are in French hands. Even at the minimum limit of 24 %, French participation is still bigger than that of any other country, as far as one can tell from those numbers. So which country has a larger stake than France according to you ? CV |
#42
![]() Robert M. Gary wrote: Joe, You sound like an EXCELLENT advocate for having the ability to dump fuel too!!! -Robert Robert, Why are you in such a hurry to dump fuel? Doing that starts to limit your time / options available for trouble shooting the problem and diverting to another airport. The first two memory items on any emergency checklist a 1. FLY THE AIRPLANE 2. DON'T HURRY Dumping fuel violates #2. Besides, IF you really need to land in a hurry, the A320 can do that at any weight. These guys took off for NY with a full load of passengers. That means that they had a lot of fuel onboard and a heavy takeoff weight. To land at that weight would have required a much higher landing speed. Since they had the hydraulics (green system) turned off to the nosewheel steering system, (per emergency checklist) this also reduced their braking ability because this same hydraulic system also controls the #1 engine reverse, and normal braking, i.e. antiskid assisted braking. BJ A320 Capt. |
#43
One consideration would be the potential for a fuel dump system
malfunciton... What would you be asking if an A320 had gone kersplash in the ocean because of a fuel loss from a dump system that it didn't need? -- Geoff the sea hawk at wow way d0t com remove spaces and make the obvious substitutions to reply by mail Spell checking is left as an excercise for the reader. "Robert M. Gary" wrote in message oups.com... Does anyone have any insight into why the A320 isn't able to dump fuel. What factors would go into such a design compromise? -Robert |
#44
CV wrote:
- 30.2% Daimler Chrysler - 15.1% Government of France - 15.1% Lagardère (A French corporation) - 5.5% Government of Spain - 33.2% Publicly held shares So which country has a larger stake than France according to you ? What percentage of Daimler Chrisler is USA owned? ;-) Why should that interest anyone? Exactly. Stefan |
#45
![]() "jbaloun" wrote I did not say there would not be an environmental impact, just that the fuel dumped in flight is likely oxidized and would not stay in the air or land on the ground in the form of raw fuel. I think you are making a mistake, in you use of "oxidized" in this case. "Oxidized" is combining it with oxygen chemically, as in "burning". In this case, there is no combining chemically, but only vaporization, as in evaporating. In both cases, no fuel reaches the ground. -- Jim in NC |
#46
CV wrote:
James Robinson wrote: Cub Driver wrote: ThomasH wrote: It almost sounds as if you would be believing that Airbus is French. It is, for all practical purposes. There would be no Airbus without France; it's located in Toulouse; and France is the largest stakeholder. Not true. The Toulouse plant may be where final assembly is done, and where the operating headquarters of Airbus is located, but there are a number of other manufacturing plants, and France is not the largest stakeholder. The company is 20% owned by British Aerospace, with the remaining 80% owned by EADS. According to the following site, the ownership or EADS is: http://www.reports.eads.net/2004/ar_...c_b3_3_3_0.php - 30.2% Daimler Chrysler - 15.1% Government of France - 15.1% Lagardère (A French corporation) - 5.5% Government of Spain - 33.2% Publicly held shares Therefore, the French government only owns about 12% of airbus, and is not the largest shareholder. Why should that interest anyone? Someone made an incorrect statement, I was simply correcting it. What those figures do show is that French ownership is in the range 24.16 to 50.72%, depending on what portion of the "Publicly held shares" are in French hands. Even at the minimum limit of 24%, French participation is still bigger than that of any other country, as far as one can tell from those numbers. So which country has a larger stake than France according to you ? No country, but there are larger stakeholders. The poster had suggested that France, as in the country, was the largest stakeholder (he didn't say "the French" or "French shareholders") Daimler Chrysler is the largest stakeholder, and British Aerospace is also larger than the French Government. |
#47
Yossarian:
so they went for lower landing weight to get shorter stopping distance. And to reduce the size of any potential fireball afterwards. |
#48
On 2005-09-28, Capt. Geoffry Thorpe The wrote:
What would you be asking if an A320 had gone kersplash in the ocean because of a fuel loss from a dump system that it didn't need? Well, what navigational error caused an A320 to be going over the ocean in the first place! (Does anyone fly trans-oceanic A320 flights?) -- Dylan Smith, Castletown, Isle of Man Flying: http://www.dylansmith.net Frontier Elite Universe: http://www.alioth.net "Maintain thine airspeed, lest the ground come up and smite thee" |
#49
On 2005-09-28, CV wrote:
Even at the minimum limit of 24 %, French participation is still bigger than that of any other country, as far as one can tell from those numbers. Since when was Daimler-Chrysler a French company? -- Dylan Smith, Castletown, Isle of Man Flying: http://www.dylansmith.net Frontier Elite Universe: http://www.alioth.net "Maintain thine airspeed, lest the ground come up and smite thee" |
#50
I guess I'm just following the subsidies. ![]() |
Time, running out of fuel and fuel gauges | Dylan Smith | Piloting | 29 | February 3rd 08 07:04 PM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
About French cowards. | Michael Smith | Military Aviation | 45 | October 22nd 03 03:15 PM |
Ungrateful Americans Unworthy of the French | The Black Monk | Military Aviation | 62 | October 16th 03 08:05 AM |
