Gear Warning
Old November 17th 05, 06:04 PM posted to rec.aviation.soaring
Default Gear Warning
I had an old dragon of a schoolteacher who used to bark at us
eight-year old kids and, if we misbehaved, would rap us over the
knuckles with a wooden ruler (this was in the old days!).
Her voice would probably do the trick! Failing which, how about a
mechanism to rap you over the knuckles while the schoolmaam berates
your stupidity?
Wives tend not to use voice commands so much as "the look".
  #42
Old November 17th 05, 06:15 PM posted to rec.aviation.soaring
Stanford Korwin wrote:
No one, as far as I know, has ever been hurt while
landing wheel-up - but there have been a number of
injuries to those losing control while trying to lower
the u/c at the last minute.
It seems a very rare event, at least in the US, as I don't remember any.
Perhaps some US pilots can offer examples. I do know a number of people
that have landed wheel up, of course. I can remember an incident where a
gear up landing at a small airstrip blocked the runway long enough to
making it difficult for the other landing gliders to do so safely.
Another incident that blocked a runway triggered an accident - no
injuries, fortunately, but the landing glider was damaged.
So, my experience is it's generally better to have the pilot get the
gear down, though I would hesitate to say anything on the radio if the
glider was already close to the ground. Certainly letting a pilot land
gear up on a wide grass runway, which would not be blocked and causes no
damage to glider, is the safest procedure. Narrow paved runways may tilt
the safety judgment in the other direction.
Eric Greenwell
Washington State
USA
  #43
Old November 17th 05, 06:39 PM posted to rec.aviation.soaring
Agree with Eric on this. I have flown at several UK sites and many US
sites. The landing options at UK sites are usually such that a
disabled glider is not a hazard to others. In US several sites only
have one paved or dirt runway available and a disabled glider can make
landing hazardous for all competitors that finish soon after. Parowan
would be a good example of that.
I have fitted gear warning in both my std class gliders. In over 2000
hours it has never gone off unexpectedly, but I intend to put the gear
down if it ever does. 2 weekends ago I had a call from another
finisher while I was on a close in base leg. He asked if my gear was
down. I had plenty of time to verify it was and to have put it down if
it wasn't. Keep calling me! I'll decide if I have time to put it down
or accept a gear up landing.
Andy
  #44
Old November 17th 05, 07:16 PM posted to rec.aviation.soaring
Eric Greenwell
Washington State
USA
I've looked at the aftermath of a few two seater gear-up landings. The
posterior of the rear seat occupant got perilously close to the highly
abrasive runway surface before it stopped grinding away the bottom of the
fuselage. Not all gear-up's may be benign.
Bill Daniels
  #45
Old November 17th 05, 07:31 PM posted to rec.aviation.soaring
Default Gear Warning - changing hands.
When I flew the PA18, PA25, and DR400 and DR300 I had my right hand on the
stick, and left hand on the throttle. With the Robins I had to change
hands to trim or set the flaps. With all of them the tow release was set
for the left hand.
When I learnt to power fly after many years gliding, I found the Tomahawk
and Cessna 150 series unhandy and difficult because I had to use my left
hand on a yoke. It was the combination of a yoke and the left hand which
made it difficult for me, after so many years with a stick in the right
hand. Are there any single pilot aircraft regularly flown with the left
hand?
There have been a number of cases where gliders (usually an ASW19) has been
seen trying to land with the brakes firmly shut and the wheel going up and
down; correct hand wrong lever.
W.J. (Bill) Dean (U.K.).
Remove "ic" to reply.
"Bill Daniels" wrote in message
I don't quite buy all of this.
Airplane pilots land with their left hand on the yoke and right hand on
the throttle. When they shift to gliders, they land with their right
hand on the stick and left on the spoiler. In other words, a well
trailed pilot can land with either hand on the flight controls.
If you can't fly with either hand, you are limited. If you can, then
shifting hands to extend the gear shouldn't be a problem.
A possible thought here is that a throttle will stay where it is when you
let go - that's what friction locks are for. A spoiler will either suck
open or slam shut forcing the pilot to keep a hand on the control. Seems
like we should ask the designers to take a look at this.
Bill Daniels
  #46
Old November 17th 05, 07:59 PM posted to rec.aviation.soaring
The Cirrus and Lancair Columbia lines both have left hand side sticks.
for the left hand.
hand?
Bill Daniels
  #47
Old November 17th 05, 08:32 PM posted to rec.aviation.soaring
Default Gear Warning - downwind checks.
In short, No.
One of the biggest controversies in U.K. clubs is about whether to do or not
to do downwind checks. Some clubs insist, some clubs think it is rubbish.
So far as I know, none of the professional national coaches employed by the
BGA to train instructors has ever called for downwind checks.
To my certain knowledge this includes Bill Scull, Chris Rollings, Brian
Spreckley, G. Dale, many others. However, when they came across a
candidate who had been trained to use downwind checks they did not actually
insist on a change.
The BGA Instructors' Manual in Chapter 4 - CHECK LISTS is 3 pages and has
this on page 4.3: -
"Pre-landing checks.
"The use of UFSTAL, WULF and other variations on the theme is inappropriate
on the downwind leg of the circuit. The pilot is better off flying the
glider correctly, in the right place, and looking out. The use of a
pre-landing check prior to joining the circuit (a pre-circuit check as
opposed to a down-wind check) is mentioned also in chapter 14."
Chapter 14 - CIRCUIT PLANNING (PART ONE) is 6 pages of text and 4 of
illustrations and has this on page 14.6: -
Under "Before going to the high key area", 7 bullet points, with the last
one: -
"make a positive decision to join the circuit to land, and plan to arrive at
the high key area between 700ft. to 800ft.
prepare for landing by;
doing pre-circuit checks, if appropriate
making sure the straps are tight and deciding on a suitable approach
speed. In gliders so equipped, dump any water ballast and lower the
undercarriage
continuing to fly the glider at normal speed (i.e. best glide angle),
but speeding up appropriately in any sink."
On page 14-10 under "Advice to Instructors",
4th of 7 items, "Downwind",
"Don't confuse the demonstration by introducing pre-landing checks as such.
It's all there anyway, and the pre-landing checks should be carried out
before starting the circuit. Reciting a mnemonic on the downwind leg is
inappropriate, and in any case, being able to recite a check shouldn't be
confused with an ability to plan a circuit."
I understand that frequently if someone lands wheel up, when asked if they
did pre-landing checks they say "oh, yes!". The point of course is that
those who are taught pre-landing checks are flying training gliders with a
fixed wheel, and so they are used to saying the check item but doing
nothing.
"Gary Emerson" wrote in message
et...
In the current, Fifteenth Edition of Laws and Rules for Glider Pilots of
April 2005 published by the BGA
http://www.gliding.co.uk/bgainfo/doc...ion15final.pdf
in Part 3 Recommended Practices RP26 on page 58 states: -
"UNDERCARRIAGE WARNING SYSTEMS
"RP26. The fitting of systems that warn the pilot of a glider that the
undercarriage is not lowered during the landing approach IS NOT
RECOMMENDED. This is because if such a system is fitted and is
activated then the pilot is likely to attempt to lower the undercarriage
during the final stages of landing. This could result in mishandling
the aircraft, so causing an accident.
"It is also recommended that if the glider is seen on the approach
wheel-up, no attempt is made to warn that pilot, using radio or other
means, for the same reason. The pilot should be allowed to land
wheels-up."
I understand that this recommendation was made after accidents where the
warning was considered to be the cause.
So does the BGA recommend to use a pre-landing checklist where the
spoilers are checked? If the spoilers are checked early in the pattern
then the logic regarding gear warning systems is not very logical.
  #48
Old November 17th 05, 09:56 PM posted to rec.aviation.soaring
nothing.
Perhaps, if they had a gear up warning system, it would have alerted
them to the put the gear down, and avoided the gear up landing. I find
having the buzzer screech at me is a good training aid, and I redouble
my efforts to avoid it in the future.
The people I know that have landed gear up had 100's (or more) of hours
in the glider they landed gear up, so it seems they were used to "doing
something". The gear up landings I'm familiar with almost always
involved some distraction so that the checks were not done, or the pilot
grabbed the wrong handle, or the gear was down for the whole flight and
raised for landing. Also, the pre-landing checks I was taught did not
involve the gear, flaps, or ballast, as the ASK 13 had none of these,
and I suspect many (most?) US pilots were trained that way. All this
leads me to believe the situation you suggest is a rare one.
Personally, the 3 times my gear up warning saved me, I had 200, 1000,
and 1500 hours in various retractable gear gliders. All involved
distraction.
Eric Greenwell
Washington State
USA
  #49
Old November 17th 05, 10:02 PM posted to rec.aviation.soaring
I agree that they are pre-landing checks, not downwind
checks, and should be carried out prior to joining
the circuit.
At 19:36 17 November 2005, W.J. \bill\ Dean \u.K.\.
In short, No.
checks.
Rollings, Brian
came across a
insist on a change.
is 3 pages and has
this on page 4.3: -
'Pre-landing checks.
'The use of UFSTAL, WULF and other variations on the
The use of a
check as
chapter 14.'
of text and 4 of
Under 'Before going to the high key area', 7 bullet
one: -
'make a positive decision to join the circuit to land,
and lower the
undercarriage
best glide angle),
but speeding up appropriately in any sink.'
On page 14-10 under 'Advice to Instructors',
4th of 7 items, 'Downwind',
'Don't confuse the demonstration by introducing pre-landing
checks as such.
be carried out
confused with an ability to plan a circuit.'
did pre-landing checks they say 'oh, yes!'. The point
of course is that
item but doing
nothing.
Remove 'ic' to reply.
'Gary Emerson' wrote in message
et...
'UNDERCARRIAGE WARNING SYSTEMS
'RP26. The fitting of systems that warn the pilot
IS NOT
fitted and is
the undercarriage
in mishandling
'It is also recommended that if the glider is seen
on the approach
radio or other
allowed to land
wheels-up.'
accidents where the
where the
very logical.
  #50
Old November 17th 05, 10:55 PM posted to rec.aviation.soaring
At 21:18 16 November 2005, Nigel Pocock wrote:
One problem with a recorded voice is that it sounds
like background radio chatter and your brain filters
it out (or at least mine does)
Our CFI discovered this the hard way in our brand new
DG1000. luckily landed on soft grass so no damage.
Incidentally the BGA in the UK does not reccomend an
undercarriage warning buzzer.
I know of two accidents causing injury, one serious,
caused by a malfunctioning u/c warning system..
I was taught to look at the u/c lever before going
for the airbrakes and after 3000 hours it hasn't failed.........
yet.
Jet engines vs. leaf blowers 01-- Zero One Soaring 6 September 8th 05 02:59 AM
Gear Warning Switches on a Mosquito scooter Soaring 6 March 9th 05 02:15 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 2 November 24th 03 06:23 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 07:24 AM
gear warning plus K.P. Termaat Soaring 0 September 8th 03 09:33 AM
