More IFR with VFR GPS questions
Old November 28th 05, 05:45 AM posted to rec.aviation.ifr
Default More IFR with VFR GPS questions
Steve has some classics. I'll never forget the time he argued what I
though of ATC in socal. Apparently, he was arguing that I really did
like it! He also argued that I didn't actually do my 3 night
currency landings during the post-9/11 IFR only time. After I gave him
the name and ATC phone number of the controller who issued me the
multiple IFR releases (since tower asked me to call approach directly
on the land line with my strange request) with immediate clearances for
the visual approach, he refused to call it but still said I made it up.
Classic
-Robert
  #42
Old November 28th 05, 01:02 PM posted to rec.aviation.ifr
Classic
Sounds like you're remembering some odd dream.
  #43
Old November 28th 05, 03:52 PM posted to rec.aviation.ifr
Robert M. Gary wrote:
What if I'm using a ham sandwich?
Can you get those with moving maps now?
  #44
Old November 28th 05, 06:10 PM posted to rec.aviation.ifr
Just to interject a comment here. Use of a handheld to supplement other
instruments, or even to supplement radar vectors, under IFR flight
rules, is what I would call a gray area of FAA rules. On the one hand
it's not really expressly PROHIBITED. But it's not expressly permitted
either. The OFFICIAL word, because of liability and the FAA's history
of wanting things to be certified, is you can't do it. But because
handhelds do function as useful navigation devices quite well, the
UNOFFICIAL rule is, if it works, you can do it.
It's not much different than using a handheld VOR (which exist and do
work) for VOR navigation. But since GPS works so much better, and
almost all aircraft flown IFR have VORs , the subject doesn't get
questioned.
What ATC wants is for you to be able to fly your clearance. Its really
up to you how you do it.
Things would start falling apart though, if there were an accident, and
the accident could be atrributed to incorrect navigation on the part of
the pilot using the handheld device. I am sure the FAA would see a
violation on that. I've seen a few FAA violations after accidents, and
they can violate the pilot, oh yes they can, and do. And they just do
it and you don't have much recourse. They will find some reason.
But so long as you keep your mouth shut, fly your clearance, and don't
cause problems, there is no citation.
The FAA used to publicize that pilots were PROHIBITIED from using
handhelds for navigation. But that has stopped. There seems to a quiet
acceptance that pilots can use them, so long as it doesn't cause
problems. Probably legal for VFR flight, where your primary navigation
is by eyesight anyway. Probably not strictly legal for IFR flight, but
can be used safely if you have the required navigation systems in the
airplane. Probably not a good idea for IFR flight if you don't have the
required, certified navigation system in the airplane.
IFR GPS's are getting inexpensive enough so that it's becoming a moot
point anyway. Why not just get a used King KLN89 and get it certified
and you will have all you legally need to file /G, no questions asked.
Then use your handheld as a backup to that unit, if it fails. And as a
backup to that unit if there is any ambiguity on the integrety of the
signal. If both units don't agree, there is a problem. If one unit
fails and the other doesn't that tells you its the unit and not the
satellites etc. For full safety you need two units anyway. The reason
why most IFR aircraft have two VOR's, not one. Safe IFR flight is all
about having redundancy. A handheld gives good redundancy to a built in
unit.
Stay safe!
  #45
Old November 28th 05, 06:21 PM posted to rec.aviation.ifr
In article . com,
Not so. The AIM specifically endorses the use of handheld GPS as an aid
to situational awareness.
rg
  #46
Old November 28th 05, 06:24 PM posted to rec.aviation.ifr
[] Use of a handheld to supplement other instruments. [...]
Where is this official word (specifically prohibiting use as a supplement)?
Jose
You can choose whom to befriend, but you cannot choose whom to love.
  #47
Old November 28th 05, 06:29 PM posted to rec.aviation.ifr
It's not gray. You are on a vector.
On the one hand
Not correct. The FAA isn't going to list everything you can do to help
yourself stay aware in the cockpit, that would be ridiculous. If
hanging a pencil by a string from the overhead vent helps you fly your
assigned heading then do it. But you still gotta fly the assigned heading.
questioned.
As long as the GPS can keep you on the centerline. Many airways have
intersections with slight turns, some with large turns. This makes it
harder to use a GPS for airways if the GPS doesn't have the airways in
the database.
Right, ATC doesn't get into enforcement. You can very easily, and much
more accurately, fly an NDB approach with a handheld GPS. But it ain't
legal. Same with direct using a handheld. Your beef will be with FSDO.
They don't have to go fishing for a reason. These FSDO guys get out in
the field and visit us in the tower also. They see things and then they
investigate, no accident necessary.
Maybe. Maybe not.
  #48
Old November 28th 05, 07:06 PM posted to rec.aviation.ifr
Yes, in Steven's world, people dream about him.
-Robert
  #49
Old November 28th 05, 09:14 PM posted to rec.aviation.ifr
rg
Which is different than a primary means of navigation.
Ron Lee
  #50
Old November 28th 05, 11:22 PM posted to rec.aviation.ifr
Only with cheese on top :-)
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 0 December 2nd 04 07:00 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 May 1st 04 07:29 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 2 February 2nd 04 11:41 PM
