Hi All,
As I understand the racing rules for 2006, the SSA has decided to mandate ELT installation for all competitors. The ELT must be permanently mounted inside the glider. Personal ELTs will not suffice. This is all complicated by the FAA's decision to obsolete some existing ELT frequencies in the coming years. With the decision made, I wonder if the ruling has been well thought out. The question is how will each contest organizer verify that the ELT installation is actually functional since some gliders are type certificated and others have experimental certification? From an owners perspective, installation could be troublesome since many newer gliders are made of Carbon Fiber which limits installation choices and could lead to some "kludged" installations in experimentally certificated gliders. In discussions with US based glider factory reps, it appears that the European manufacturer's have not uniformly accounted for this rule change in their basic offering. When asked about installed ELT antennas, the response has been Hmm. So the question is how does one retrofit an ELT solution to an existing glider and how does one specify an installation for a new glider? Additionally, how does the SSA insure that the installations done for the 2006 racing season actually work versus merely demonstrating that an "expensive" new box has been permanently mounted inside the fuselage? All thought and feedback appreciated. mhr |
SSA Contest Rules Subcommittee reviewed the action proposed last year
and has revised proposed action for 2006 and forward. Text of rule that will be proposed to the SSA BOD is as follows: ELTs No longer does an ELT have to be TSOed. 6.5.2 When announced by contest organizers prior to the Preferential Entry Deadline, an impact-activated Emergency Locator Transmitter (ELT) is required in every sailplane. This will permit organizers that see fit to require ELT's but not make them mandatory across the board. The minutes of the Fall RC meeting and Draft Rules will be published for review in the next week or so. H Nixon UH SSA Contest Rules Subcommittee chair |
Hi,
This is great news! If I understand correctly, ELTs will only be required if the contest organizers require them. Although I sell ELTs, I was against making them mandatory at all contests because I feared that it would keep many potential new contest pilots from competing due to the high cost. Good Soaring, Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com wrote in message oups.com... SSA Contest Rules Subcommittee reviewed the action proposed last year and has revised proposed action for 2006 and forward. Text of rule that will be proposed to the SSA BOD is as follows: ELTs No longer does an ELT have to be TSOed. 6.5.2 When announced by contest organizers prior to the Preferential Entry Deadline, an impact-activated Emergency Locator Transmitter (ELT) is required in every sailplane. This will permit organizers that see fit to require ELT's but not make them mandatory across the board. The minutes of the Fall RC meeting and Draft Rules will be published for review in the next week or so. H Nixon UH SSA Contest Rules Subcommittee chair |
BE VERY CAREFUL.
If you own a sailplane with a STANDARD AIRWORTHINESS CERTIFICATE, and you choose to install an ELT, it must be one that is TSO'd and the installation must be done in accordance with an STC or a FAA field approval. I have seen and heard about many pilots who have purchased these units from their favorite vendor and stuck it in their glider. If you do not do a legal installation, you may be putting your insurance coverage in jepardy. If the contest committe would abolish the pst and tat and go back to real glider racing ie AST, the hysteria about installing ELTs would go away. We would narrow the search pattern for lost pilots and in most cases increase the odds of having witnessed losses. This would be REAL safety reform. I do believe that installing ELTs in gliders that are flown cross country in general is good and a responsible thing to do. I find it ironic that years ago the SSA went to bat for the "good of soaring pilots in the US" and lobbied the FAA for and exemption to the ELT rule. I quess I should probably shut up and lick my chops in anticipation of all the ELT sales that I am about to be flooded with. (sigh) Rex Mayes Williams Soaring Center |
I must be missing something. ELTs are not required in glider by the
FAA, also flight recorders, GPS systems, CAI 302, Borgelt B500, Ilec SN10, LX 7007, PDA's with software are not required in gliders by the FAA. None of the systems I mentioned are TSO'd. Does this mean STC or FFA field approvals are required for these instruments and my insurance may be in jepardy if I have any of these systems installed by myself or a favorite vendor in a Standard Airworthiness Certificated Glider. I also sell ELT's, they are very inexpensive $183.75. I believe that they are a good idea especially in some of the areas that we typically fly. Richard www.craggyaero.com Rex wrote: BE VERY CAREFUL. If you own a sailplane with a STANDARD AIRWORTHINESS CERTIFICATE, and you choose to install an ELT, it must be one that is TSO'd and the installation must be done in accordance with an STC or a FAA field approval. I have seen and heard about many pilots who have purchased these units from their favorite vendor and stuck it in their glider. If you do not do a legal installation, you may be putting your insurance coverage in jepardy. If the contest committe would abolish the pst and tat and go back to real glider racing ie AST, the hysteria about installing ELTs would go away. We would narrow the search pattern for lost pilots and in most cases increase the odds of having witnessed losses. This would be REAL safety reform. I do believe that installing ELTs in gliders that are flown cross country in general is good and a responsible thing to do. I find it ironic that years ago the SSA went to bat for the "good of soaring pilots in the US" and lobbied the FAA for and exemption to the ELT rule. I quess I should probably shut up and lick my chops in anticipation of all the ELT sales that I am about to be flooded with. (sigh) Rex Mayes Williams Soaring Center |
I'm not sure TSO is a requirement. I have had non-TSO'd equipment installed
in certified aircraft by avionics shops who took care of the 337. I agree that carrying an ELT of some kind is responsible but it grates to see obsolescent equipment mandated by what could be seen as a CYA scenario. To mandate parachutes be worn by the pilot and then mandate the ELT to be fitted to the glider seems nonsensical. In Colorado's rough terrain, it doesn't seem reasonable to me that a parachuting pilot would necessarily land near the wreckage. My plan is to buy a 406Mhz GPS unit that will be attached to my parachute harness. If an outlanding is imminent, I will turn it on. If the landing goes well, I will turn it back off and contact the SAR folks ASAP to say nevermind. I would plan to contact contest managers in advance to state my position and, if they didn't agree, I'd just stick with the OLC. BTW, I just turned my handheld comm to 121.5 and got a strong ELT signal. Since I'm in my home office in suburban metro Denver, It's a fair guess that an aircraft at KAPA 4 miles away has a tripped ELT although there are several glider owners within that range may have ELT's installed. Bill Daniels "Rex" wrote in message oups.com... BE VERY CAREFUL. If you own a sailplane with a STANDARD AIRWORTHINESS CERTIFICATE, and you choose to install an ELT, it must be one that is TSO'd and the installation must be done in accordance with an STC or a FAA field approval. I have seen and heard about many pilots who have purchased these units from their favorite vendor and stuck it in their glider. If you do not do a legal installation, you may be putting your insurance coverage in jepardy. If the contest committe would abolish the pst and tat and go back to real glider racing ie AST, the hysteria about installing ELTs would go away. We would narrow the search pattern for lost pilots and in most cases increase the odds of having witnessed losses. This would be REAL safety reform. I do believe that installing ELTs in gliders that are flown cross country in general is good and a responsible thing to do. I find it ironic that years ago the SSA went to bat for the "good of soaring pilots in the US" and lobbied the FAA for and exemption to the ELT rule. I quess I should probably shut up and lick my chops in anticipation of all the ELT sales that I am about to be flooded with. (sigh) Rex Mayes Williams Soaring Center |
![]() I fly with a 406 MHz PLB on my parachute harness and will probably add a 406 MHz ELT to the glider at some point. The PLB is only useful if I survive a parachute out or a crash and can turn it on and extend the antenna and it can get good sight to a satellite (some require a manual antenna extension, some extend when you pull the tab to turn the PLB on). Bill Daniels wrote: [snip] I agree that carrying an ELT of some kind is responsible but it grates to see obsolescent equipment mandated by what could be seen as a CYA scenario. To mandate parachutes be worn by the pilot and then mandate the ELT to be fitted to the glider seems nonsensical. In Colorado's rough terrain, it doesn't seem reasonable to me that a parachuting pilot would necessarily land near the wreckage. Then have a 406 MHz PLB on your parachute as well. Even without this you are probably going to land within a few miles of the wreckage, and with a 406 MHz PLB in the glider that is still going to help find you. If they find the glider without pilot/parachute it is pretty obvious you bailed out and that helps keep search teams focusing on finding you nearby. My plan is to buy a 406Mhz GPS unit that will be attached to my parachute harness. If an outlanding is imminent, I will turn it on. If the landing goes well, I will turn it back off and contact the SAR folks ASAP to say nevermind. I would plan to contact contest managers in advance to state my position and, if they didn't agree, I'd just stick with the OLC. You can't be serious right? Since when is an outlanding an emergency justifying a PLB/ELT activation? If you are over a forrest etc. and have no other options them by all means try whatever you want. Turning on a PLB prior to an outlanding won't do much unless you extend the antenna. Even if you extended the antenna and got a signal out how do you think you are going to notify CAP or anybody else that it was an "precautionary" activation - not something they may be happy with you doing anyhow. Then don't even get me started about the distraction of trying to activate this and the antenna flopping around in the cockpit while you are trying to land. BTW, I just turned my handheld comm to 121.5 and got a strong ELT signal. Since I'm in my home office in suburban metro Denver, It's a fair guess that an aircraft at KAPA 4 miles away has a tripped ELT although there are several glider owners within that range may have ELT's installed. 121.5 is full of noise, a 406 MHz signal is going to get more attention. And since they know exactly who you are from the signal you can expect followup. As for those cheap few hundred dollar 121.5 ELTs, given the much better performance of 406 MHz ELTs/PLBs and I don't see why people are bothering with the 121.5 units. Darryl Ramm 6DX |
Hi Hank,
Thanks for the feedback. Your reply was illuminating but still leaves many questions unanswered. While having the option to mandate ELTs sounds promising, what contest organizer will not require ELTs knowing that the option exists as part of the rules. By making this part of the rules, the situation exists that each contest organizer will require them to mitigate potential liability. If another tragedy does occur, the contest organizer that did not require ELTs will surely be sued. Hence, who will not require them to preclude or limit liability issues? So, if we assume that ELTs will be required by all contest managers, the potential competitor is still faced with installation issues, arising primarily form antenna location and effectiveness; and the contest manager is still faced with assurance issues that each installation meets the intent of the rules and operates as required. The bottom line is that we now have a rule that presents problems for both the contest pilot (how do I install an operable system?) and the contest organizer (it would be foolish not to mandate ELT usage for liability protection but how do I know that the systems actually work?) While the intent and spirit of the rule is admirable, it seems that the implementation of this rule has not been well thought through. As usual, all feedback and discussion appreciated. mhr |
Part of the research on this was a poll of contest managers and CD's
who worked during 2005. On the subject of making mandatory 10 of 28 favored this. Of those saying no to mandatory, 12 said yes to making it available by organizer option. 6 said no to either option. This guidance, in addition to the Poll response, was considered in the decision to make the option available to organizers as a part of the rules without requiring a waiver. I'm not convinced all organizers will require them- far from it. Nor do I think they are sure to be sued since they will not be the cause of the accident. That said,I sincerely hope none of them has to answer the question "Why did you not require this safety device when it could have helped save a life?" As a long time racer, and member of the rules committee, I personally can't see how to make any case for not requiring them. That said, I am in the minority on this and support the half way approach as what is to go forward. Have one friend missing for one night and you will understand. As to the assertion that this has not been thought through, this is simply not the case. You may not agree with the result, but I can assure you this has been considered with great care and in consideration of the opinions of many. Respectfully UH |
magneto installation help | Dick | Home Built | 5 | February 10th 05 03:02 PM |
Skycraft Landing Light Installation Pix | Jay Honeck | Owning | 5 | February 6th 05 02:05 PM |
Great deals on avionics installation kits and tools | Randy Cooper | Aviation Marketplace | 0 | January 14th 05 04:07 AM |
Equipment Installation | Stan Prevost | Owning | 0 | November 16th 04 05:28 PM |
Buying an L-2 | Robert M. Gary | Piloting | 13 | May 25th 04 04:03 AM |
