#41
Daryl wrote:
Superfloats are able to do it... ...less complex tailwheels (fully steerable), I wonder if one has to get a tail wheel check out for this thing. :) |
#42
Gig:
It is the sound that matters. A or An. Use an in place of a when it precedes a vowel sound, not just a vowel. That means it's "an honor" (the h is silent), but "a UFO" (because it's pronounced yoo eff oh). This was what I was taught also: a UFO, an Unidentified Flying Object. |
#43
The ability to land in rough water is limited by the hull strength.
Pontoon type floats have struts and the struts can break. Hull type aircraft such as a Lake use the hull itself to land on, no struts. Although you CAN break anything, usually hull type aircraft can land on the incoming wave's backside (the worst spot), hit and not breakup HARDER than can pontoon aircraft. Of course it depends on the plane. Larger planes tend to do better. But even the Beavers and such can break a strut. Usually when the waves start whitecapping, 15knot winds or so, small GA planes can no longer land safely on whitecapping waves. But there are waves and there are other waves, it all depends. Like Pete said, high wings tend to be able to get into docks better because their wings clear the docks. Low wing planes usually wont clear, so you can't get the fuselage up next to the dock. |
#44
Yeah, the part I liked best was climbing over the cowl to the right float
when the pax seats were full. Seth "Robert M. Gary" wrote in message ups.com... I always found preflight to be an acrobatic routine. There is a lot of rigging all over the place on a float plane. -Robert |
#45
On 6 Dec 2005 02:58:43 -0800, "Doug"
wrote in . com:: Usually when the waves start whitecapping, 15knot winds or so, small GA planes can no longer land safely on whitecapping waves. But there are waves and there are other waves, it all depends. In the channel between Santa Barbara and the Channel Islands the swells can often be 20' to 30' feet without whitecaps! |
#46
"Doug" wrote in message
ups.com... The ability to land in rough water is limited by the hull strength. Yes, that too. But control on the water surface is at least as important as not breaking something. The hull design also affects the forces experienced; a shallow hull decelerates more quickly, transmitting higher forces to the airframe. Sheer strength is always a factor, of course...but that's true of every aspect of aircraft design. It's often not primary, and I disagree that it is here. Hulls intended for rough water operation are designed with a steeper "V". |
#47
"Larry Dighera" wrote in message
... In the channel between Santa Barbara and the Channel Islands the swells can often be 20' to 30' feet without whitecaps! Swells are given that name specifically because they are different from what is generally considered a wave. In particular, they are usually farther apart (and often higher). Not that I have personal experience -- I try to stay away from waterways with swells -- but my understanding is that landing a seaplane in swells is similar to ditching procedures. That is, try to land parallel to the swell, not across it. It's an entirely different technique from normal landings on waves. Pete |
#48
On Tue, 6 Dec 2005 10:03:22 -0800, "Peter Duniho"
wrote in :: "Larry Dighera" wrote in message .. . In the channel between Santa Barbara and the Channel Islands the swells can often be 20' to 30' feet without whitecaps! Swells are given that name specifically because they are different from what is generally considered a wave. In particular, they are usually farther apart (and often higher). It was the early '70s when one of my father's partners invited me for a cruise on his 24' sail boat to Anacapa Island off the Ventura, California coast. The trip over was pleasant, but the next morning on the way back was really something. It was foggy with visibility about 1/4 mile. The sea was like I had never experienced before, and I had recently crewed on a Newport Beach to Encinada race in which several boats were dismasted/run aground, and we were healed over so far that the Genoa was dragging in the water, but no one could get on deck to reef it in. The swells in the channel were so high, that one moment you were on the crest and couldn't see the water around the boat, and the next moment you were in a trough so deep that you could only see the sky directly overhead. I couldn't believe it! If one had broken over us, that would have been it for sure. I have a much healthier respect for the sea now. Not that I have personal experience -- I try to stay away from waterways with swells -- but my understanding is that landing a seaplane in swells is similar to ditching procedures. That is, try to land parallel to the swell, not across it. That would have been the only practical way to land, but I doubt the swells were far enough apart to prevent digging a wing in. It's an entirely different technique from normal landings on waves. Would you aim for a trough or a crest? |
#49
Yes, deep and sharp (highly angled) V's tend to cushion the landing
somewhat. Also helps if the are concave. On my plane and all the other pontoon type aircraft that I know of, the first thing that will break is a strut. The breakpoint varies, sometimes it's the vertical strut, sometimes the horizontal (on my plane it is known to be the vertical strut). The Lakes don't have struts and since the fuselage is also the hull, it IS stronger and can take more. But.... when Lakes breakup (there is a video), it is CATASTROPHIC, they really come apart. On my aiplane, usually if one strut breaks you can limp in to shore. If both front struts break, and the broken part doesn't settle on the fitting (they break at the lower fitting), you are hosed. You will go over frontwards, maybe not capsize, but the plane can no longer taxi, the prop cuts the floats etc. Bad scene. But sometimes the broken piece settles on the fitting and you can limp to shore even with 2 or more struts broken. The biggest problem is judging just how big and steep a wave you can land on, also depends on how close together they are. There isn't any helpful info in the POH, that I've ever seen. And it IS a problem. Especially with straight floats. They can't circle forever and have to go ahead and land. In this respect the amphib gives you the option of landing on land. So then pilots try and land close to shore to take advantage of the lee of the trees and run into the associated hazards of wind shear and landing close to shore, running into rocks etc. If those waves look too big, and if in doubt, don't. Pretty easy to break a strut. The hulls themselves seem to take it fine, seldom dent a hull from landing on a wave, at least not that I have heard of or seen. Probably possible though. You might just loosen rivets, I suspect. Landing on big swells in another matter altogether. I am talking about waves that you see on a typical lake, maybe one foot high and 20 to 75' apart. Ocean swells are MUCH further apart and can be much larger. But even the big planes made to land on the ocean, Grummans and the other Navy WWII one (can't remember its id), can get into waves and swells they can't handle. |
#50
... Would you aim for a trough or a crest? I would aim for the crest, for the same issue you already mentioned: the risk of catching a wing. I hope never to have to test the knowledge. Landing on swells seems unreasonably tricky to me. ![]() Pete |
FA: (One Day Left) - 6 BOOKS - FAR, AIM, IFR, AOPA, P-47, Seaplanes... | Josh | Aviation Marketplace | 0 | November 13th 04 01:23 PM |
FA: 6 AVIATION FLYING BOOKS - FAR, AIM, IFR, AOPA, P-47, Seaplanes... | Nemo | Aviation Marketplace | 0 | November 7th 04 08:11 PM |
Question about Seaplanes | Sami | Aviation Marketplace | 11 | September 23rd 04 02:04 AM |
Jet Seaplanes??? | Roy Smith | General Aviation | 7 | August 23rd 04 11:29 AM |
Seaplanes and insurance | Robert M. Gary | Piloting | 1 | August 1st 03 05:55 PM |
