#41
"lynn" wrote
Not much room for errors at LGA, Reagan, or Orange County. Of course with AA, CAL, DAL, LCC using LGA, and not SWA, you won't hear how dangerous LGA is. Hmmmm...I flew PanAm's shuttle B-727's into LGA and DCA a couple of times a day for quite some time...never had a problem. Then again... we former Naval Aviators received a bit better training in controlling approach speed and touchdown point than the average pilot. :-) Bob Moore |
#42
Was that before they restricted the landing flap setting?
How much difference did that make in distance? I was just a very low time pilot when that was done, understand it was because the 727 would get way behind the power curve, is that true? -- James H. Macklin ATP,CFI,A&P "Bob Moore" wrote in message . 121... | "lynn" wrote | Not much room for errors at LGA, Reagan, or Orange County. Of course | with AA, CAL, DAL, LCC using LGA, and not SWA, you won't hear how | dangerous LGA is. | | Hmmmm...I flew PanAm's shuttle B-727's into LGA and DCA a couple of | times a day for quite some time...never had a problem. Then again... | we former Naval Aviators received a bit better training in controlling | approach speed and touchdown point than the average pilot. :-) | | Bob Moore |
#43
Bob Moore wrote:
Hmmmm...I flew PanAm's shuttle B-727's into LGA and DCA a couple of times a day for quite some time...never had a problem. Then again... we former Naval Aviators received a bit better training in controlling approach speed and touchdown point than the average pilot. :-) Ah, you guys are pussies. The fellows at Midway didn't have a tailhook or net to contain them. G -- Mortimer Schnerd, RN VE |
#44
Flyingmonk wrote:
I thought I heard it was gonna be replaced. I don't remember where I heard it from. Probably an Internet rumor. ![]() I haven't heard anything other than it's to be expanded with additional runways. -- John T http://tknowlogy.com/TknoFlyer http://www.pocketgear.com/products_s...veloperid=4415 Reduce spam. Use Sender Policy Framework: http://spf.pobox.com ____________________ |
#45
![]() "Jim Macklin" wrote in message Yes, if you bounce, but if the approach speed is at 1.2-1.3 snip The transport category jets don't have that problem because they are designed to work differently from the typical GA airplane.. yes, yes, yes...... anyone here [with appropriate experience] who's never had a 727 bounce on them, please raise your hand. Sometimes you find that the airplane never read the book. |
#46
"Jim Macklin" wrote
Was that before they restricted the landing flap setting? How much difference did that make in distance? I was just a very low time pilot when that was done, understand it was because the 727 would get way behind the power curve, is that true? Any restriction in landing flap setting would have been due to noise limitations, not performance. Bob Moore |
#47
![]() Jim Macklin wrote: Was that before they restricted the landing flap setting? The "quiet wing"? |
#48
![]() "John Gaquin" wrote in message ... "Jim Macklin" wrote in message Yes, if you bounce, but if the approach speed is at 1.2-1.3 snip The transport category jets don't have that problem because they are designed to work differently from the typical GA airplane.. yes, yes, yes...... anyone here [with appropriate experience] who's never had a 727 bounce on them, please raise your hand. Sometimes you find that the airplane never read the book. There was a mechanic at my local flight school, he used to fly for the airlines but lost his medical, he said the 727 was a bitch to land well. ---------------------------------- DW |
#49
If I remember correctly, the 727 had a series of landing
accidents because the full flap setting was about 50-60 degrees and if the pilot got too slow, they could not recover. Maximum extension was reduced. Looking on the Internet, I found a further limitation for couple approaches with certain autopilots. Is there any early 727 pilot out there with the facts on the first 727 and any changes in certification re flaps? -- James H. Macklin ATP,CFI,A&P "Bob Moore" wrote in message . 122... | "Jim Macklin" wrote | Was that before they restricted the landing flap setting? | How much difference did that make in distance? I was just a | very low time pilot when that was done, understand it was | because the 727 would get way behind the power curve, is | that true? | | Any restriction in landing flap setting would have been due to | noise limitations, not performance. | | Bob Moore |
#50
"Jim Macklin" wrote
If I remember correctly, the 727 had a series of landing accidents because the full flap setting was about 50-60 degrees and if the pilot got too slow, they could not recover. Maximum extension was reduced. Looking on the Internet, I found a further limitation for couple approaches with certain autopilots. Is there any early 727 pilot out there with the facts on the first 727 and any changes in certification re flaps? Go back to your little airplanes Jim. The following article is from the May-June 1965 issue of the Boeing Airliner. Is that far enough back for you? "Flap Angle One of the factors having the greatest effects on stall and initial buffet speeds is the angle the flaps are set at during flight. The 727 flap angles are given in trailing edge deflections of 0, 2, 5, 15, 25, 30 and 40 degrees. An increase in flap angle increases the camber of the wing so that it will produce the same lift at a lower speed than a smaller flap angle setting would produce. The effect of flap angle on initial buffet and stall can be seen in Figures 2, 3, and 4 for flap angles 0, 15, and 40 degrees. The graphs also present the points where the stick shaker operates and shows the 7 percent margin required by Civil Air Regulations for adequate stall warning. In all cases, except at 30 and 40 degree flaps, initial buffet will occur at a speed higher than the 107 percent stall speed requirement. However, initial buffet is never less than 4 percent above stall speed even at 40° flaps. Since the reference landing speed (Vref) is 130 percent of the stall speed, there is adequate speed margin for landing." Besides flying the line in the -200 series from 1986- 1991, I taught the -100 series back in 1977-78. Yes, there were a couple of early landing accidents attributed to excessive sink rates and the fix was to change the technique that the pilots were using. Would you like a lesson on the flap/speedbrake interaction and the sink rates that it causes? Bob Moore ATP B-707 B-727 L-188 PanAm (retired) |
11 Nov 2003 - Today’s Military, Veteran, War and National Security News | Otis Willie | Military Aviation | 0 | November 11th 03 11:58 PM |
08 Nov 2003 - Today’s Military, Veteran, War and National Security News | Otis Willie | Military Aviation | 0 | November 9th 03 01:51 AM |
Washington Post Article | Tex Houston | Military Aviation | 4 | September 26th 03 03:35 PM |
18 Sep 2003 - Today’s Military, Veteran, War and National Security News | Otis Willie | Military Aviation | 0 | September 19th 03 03:47 AM |
PFC Lynch gets a Bronze Star? | Brian | Military Aviation | 77 | August 2nd 03 11:15 AM |
