#41
The AIM presents the FAA's current official definition of "known icing
conditions". So any case law decided on the basis of prior explicit or implicit definitions is no longer applicable. Well, that might be true if the AIM were regulatory. It's not. (unless the feds want it to be). Jose -- You can choose whom to befriend, but you cannot choose whom to love. for Email, make the obvious change in the address. |
#42
"Jay Somerset" wrote in message
... A bit of a distortion. The phrase in the regulations is "known icing conditions". A forecast that mentions icing satisfies this as the conditions (leading to potential) icing are indeed known -- if you have read the forecast -- and you are required by regulations to obtain all relevant information for the flight which includes a weather forecast. Many pilots try to parse the requirement as "known-icing conditions" whereas the FAA has defined it to mean "known icing-conditions" -- a subtle but inportant difference when it comes to defending oneself against a certificate action. A forecast of icing constitutes "known icing-conditions." What you say appears to have been true in the past, but not currently. As noted earlier in this thread, the FAA now defines the terms as follows: "Forecast Icing Conditions--Environmental conditions expected by a National Weather Service or an FAA-approved weather provider to be conducive to the formation of in-flight icing on aircraft." "Known Icing Conditions--Atmospheric conditions in which the formation of ice is observed or detected in flight." (AIM 7-1-23, http://www.faa.gov/atpubs/aim/Chap7/aim0701.html#7-1-23) --Gary |
#43
AIM is non-regulatory advisory and does not constitute law.
FAA says that in the preamble to the AIM "Gary Drescher" wrote in message . .. | "George Patterson" wrote in message | news:_Qpof.17301$Jz6.14963@trnddc06... | Bob Gardner wrote: | | Gary, the most recent case was in 2005. That's what George was linking | to. | | No, that's the date of the article. The most recent ruling on the forecast | icing issue was about 12 years ago. There were earlier ones as well. If, | however, the AIM is in conflict with case law (and it is), the AIM is | wrong. | | The AIM presents the FAA's current official definition of "known icing | conditions". So any case law decided on the basis of prior explicit or | implicit definitions is no longer applicable. | | --Gary | | |
#44
"Jose" wrote in message
.. . The AIM presents the FAA's current official definition of "known icing conditions". So any case law decided on the basis of prior explicit or implicit definitions is no longer applicable. Well, that might be true if the AIM were regulatory. It's not. The AIM doesn't set forth regulations, but its subtitle is "Official Guide to Basic Flight Information and ATC Procedures"; and it states in the preface that it presents information that the FAA wants pilots use to understand and interpret the regulations. There's no way the FAA could get away with officially telling pilots to use a given explicit definition, and then prosecuting them for complying. But of course I'm willing to entertain evidence that I'm wrong about that. Is there any documented example of a successful enforcement action taken against a pilot for using a definition in the then-current AIM rather than using some other, unpublished definition that the FAA proposes instead? --Gary |
#45
away with officially telling pilots to use a given explicit definition, and then prosecuting them for complying. That is a statement of faith. It is a faith I do not have. I don't know if there's any evidence yet of being prosecuted for obeying the AIM. Jose -- You can choose whom to befriend, but you cannot choose whom to love. for Email, make the obvious change in the address. |
#46
Gary Drescher wrote:
The AIM doesn't set forth regulations, but its subtitle is "Official Guide to Basic Flight Information and ATC Procedures"; and it states in the preface that it presents information that the FAA wants pilots use to understand and interpret the regulations. There's no way the FAA could get away with officially telling pilots to use a given explicit definition, and then prosecuting them for complying. There's every way. In the first place, case law trumps everything. In the second place, the Federal administrative court system has an explicit policy that any government agency has the last word in interpreting its own regulations. The only time the court will rule against the FAA is when the FAA attempts to interpret a regulation in a fashion that is different from an earlier interpretation. In other words, the FAA can't violate a pilot for doing something one way and then violate another pilot for doing just the opposite. Other than that, the FAA can interpret the regulations any way they see fit. George Patterson Coffee is only a way of stealing time that should by rights belong to your slightly older self. |
#47
Maybe, but I really doubt it unless my problem resulted in an accident
or maybe a "deal" for the controller if I had to make a descent that they couldn't clear quickly enough. Even though I've flown in northeast winters for 28 years and tend to "take a look" even if icing is a possibility, I've only once ever gotten into anything I'd call trouble. Even then, I didn't need to declare, I just needed a block altitude clearance so I could descend until I could maintain altitude. Fortunately, I reached the equilibrium altitude prior to reaching ground elevation. :-) So what you're saying is that you're lucky to be alive. |
#48
... There's no way the FAA could get away with officially telling pilots to use a given explicit definition, and then prosecuting them for complying. That is a statement of faith. It is a faith I do not have. I wouldn't call it faith. There are some violations of due process that are so blatantly absurd that (empirically) they can't survive judicial review (except when there's a powerful vested interest involved; but that's not the case when it comes to busting a random private pilot for flying into icing conditions). I don't know if there's any evidence yet of being prosecuted for obeying the AIM. I'd say that until and unless some such evidence comes to light, the a priori likelihood of such an event is so low that it's not worth taking the possibility seriously. --Gary |
#49
news:K0rof.16285$Ea6.4779@trnddc08... Gary Drescher wrote: The AIM doesn't set forth regulations, but its subtitle is "Official Guide to Basic Flight Information and ATC Procedures"; and it states in the preface that it presents information that the FAA wants pilots use to understand and interpret the regulations. There's no way the FAA could get away with officially telling pilots to use a given explicit definition, and then prosecuting them for complying. There's every way. In the first place, case law trumps everything. No it doesn't. But even if it did, case law is grounded in existing regulations and official documents that elaborate those regulations. And if those change, then the prior case law is simply no longer addressing the current situation. In the second place, the Federal administrative court system has an explicit policy that any government agency has the last word in interpreting its own regulations. The only time the court will rule against the FAA is when the FAA attempts to interpret a regulation in a fashion that is different from an earlier interpretation. In other words, the FAA can't violate a pilot for doing something one way and then violate another pilot for doing just the opposite. Other than that, the FAA can interpret the regulations any way they see fit. George, what evidence do you have that that's the sole basis on which an administrative court will overrule the FAA? In particular, what evidence is there that other forms of blatant violation of due process are not also grounds for overturning an FAA verdict? (Officially instructing pilots to do something, and then busting them for complying, is as flagrant a violation of due process as one can imagine.) --Gary |
#50
George, what evidence do you have that that's the sole basis on which an administrative court will overrule the FAA? Sorry, I meant the appeals court. Recent cases mentioned in Yodice's column in AOPA Pilot. To quote, we have "But the FAA appealed the NTSB's decision to the Court of Appeals, which held that the NTSB must defer to the FAA's interpretation" and "you can expect that the NTSB will be bound to defer to the FAA's interpretation of your conduct as a violation of the FAR, unless you are prepared to show the FAA's interpretation to be arbitrary, capricious, or illegal." This was added to the legal statutes in 1994. George Patterson Coffee is only a way of stealing time that should by rights belong to your slightly older self. |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
Have you ever... | Jay Honeck | Piloting | 229 | May 6th 05 08:26 PM |
Known Icing requirements | Jeffrey Ross | Owning | 1 | November 20th 04 03:01 AM |
Interesting. Life history of John Lear (Bill's son) | Big John | Piloting | 7 | September 20th 04 05:24 PM |
Wife agrees to go flying | Corky Scott | Piloting | 29 | October 2nd 03 06:55 PM |
