Nasa Icing courses
Old January 8th 06, 10:44 AM posted to rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
Default Nasa Icing courses
"Sylvain" wrote in message
t...
you said, and I quote:
"...a primary student's knowledge of icing need not extend
much further than "don't fly when freezing rain is forecast"..."
That was the specific statement of yours with which I do disagree.
Your reply illustrated no such disagreement. My statement and yours are not
mutually exclusive.
I did illustrate my point with a very specific and real life
example where a primary student's knowledge of icing DOES indeed
need to extend further than don't fly when freezing rain is
forecast.
I never said that it doesn't.
Don't be so defensive, I was not attacking your beloved
windows operating system! :-)
I am of the opinion that no operating system is "beloved". Operating
systems are a stupid way to waste an emotion like love. How that pertains
to this thread at all, I have no idea.
Pete
  #42
Old January 8th 06, 01:45 PM posted to rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
Default Engine Making Metal (Was: Nasa Icing courses)
Mary and I fly more than anyone at the airport, and we just barely put
200 hours on last year.
Really? I would have thought you put far more than that on, per year.
200 hours per year is a LOT of flying, if you're not either (a) retired, or
(b) getting paid to do it.
It's the equivalent of flying from Iowa to Michigan -- and back -- every
week.
Or, put another way, it's four 1-hour hamburger flights per week, every
week, all year long...
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
  #43
Old January 8th 06, 01:47 PM posted to rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
Start with the throttle 1/2 open, zero rpm to 1800 with no
oil pressure. Etc.
I aim to keep RPMs at 1000 (or less) from start-up to run-up. (My A&P
showed me that 1000 RPM is too low to kick up stones, so being patient and
taxiing slowly really saves your prop.)
What do you think causes a problem like Ray's, Jim? It just seems to, I
don't know -- random.
Jay Honeck
Iowa City, IA
Pathfinder N56993
  #44
Old January 8th 06, 01:51 PM posted to rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
And mechanical failures should have simple explanations, no? WHY did
one of the cam lobes fail? Why didn't ALL of the cam lobes fail?
Timeless issue. www.aviationconsumer.com has hours of reading on the
subject. The common factor is infrequent flying.
I suppose the *real* issue should be: Why do camshafts work at all? When
you sit down and rationally analyze what is happening inside your engine,
the danged thing should just throw itself to pieces in the first ten minutes
of operation.
Yet, most of them don't.
Some, however, like Ray's engine, do -- and in very peculiar ways. (Just
ONE cam lobe went bad?)
Why?
Jay Honeck
Iowa City, IA
Pathfinder N56993
  #45
Old January 8th 06, 02:38 PM posted to rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
I wonder if there is any statistical evidence on this issue regarding
incidences per region?
Are planes out here in the desert SW less prone to this?
Just wondering out loud...
That would be an interesting study. It might tell how much of a factor
condensation is.
  #46
Old January 8th 06, 02:41 PM posted to rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
Why?
Could it be a bad part? Nah!!! Lycosarus never makes a bad part! Not!
  #47
Old January 8th 06, 02:43 PM posted to rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
Is this slightly low Jay? 1/2 hour each way? My hamburger runs are
minimum 1 hour each way, which would reduce it to 2 hamburger flights per
week.
You are right, 200 hours a year is an awful lot of flying. You had me
curious for me, how much in a year I fly, and it was as follows:
2001 11.7
2002 49.5
2003 142.2
2004 192.9
2005 126.4
2006 4.0
I try to fly once a week at minimum myself and no less then one hour air
time when I fly.
I was told ground runs is one of the worst things you can do to an airplane
engine, as it was designed for sustained high RPM operations, not ground
run RPMS.
Allen
  #48
Old January 8th 06, 04:10 PM posted to rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
run RPMS.
You know, I've heard that since Day One of ownership, too, but ya just
gotta wonder if it's not yet another "old wive's tale", like so many of
these "tried and true" things. How does the engine know the
difference between ground runs at, say 2000 RPM (run-up speed on our
plane) and an extended descent? Is *that* "bad" for the engine, too?
Doesn't running it for 30 minutes on the ground circulate the oil, and
prevent corrosion? Can't you get oil temps up to 150 or better (I
know, 180 is optimal, but...) with a ground run? Isn't that better
than letting it sit and rot till spring?
I fly too often for this to really matter, but I always wonder if it's
a real issue or not? Kinda like "shock cooling" and "pulling the prop
through" before starting on a cold day... And Marvel Mystery oil,
while we're at it...
Jay Honeck
Iowa City, IA
Pathfinder N56993
  #49
Old January 8th 06, 04:16 PM posted to rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
of operation.
Why?
I wonder if this was the first cam lobe to actually fail. Have they all
been measured and determined to be within spec?
Mark Hansen, PP-ASEL, Instrument Airplane
Sacramento, CA
  #50
Old January 8th 06, 04:35 PM posted to rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
Strictly my opinion -
Your bad lobe is one of the cam lobes that operates two lifters, so it,
or its companion will be the first to go in a marginal lubrication
situation. The lobes depend on oil thrown from the crankshaft cheeks -
some thing that I don't think happens for a couple of minutes after a
cool start - especially with a cold engine.
It isn't a question of how quickly does the oil pump get oil get to the
cam bearings as journal bearings will retain enough oil to allow them
to be starved for a minute or two and oil gets there in a few seconds
anyway.
More critical though is how quickly does the crankcase develop that
general fog/spray of oil to finally lubricate all the miscellaneous
(and expensive) surfaces such as cam lobes and cylinder bores. The cam
is at the top of the engine & the lobes are the last thing to get lube.
Possibly if the crank is turning too slow, gravity is such that thrown
blobs of oil can't even make it to the lobes until the oil; gets really
thin. Remember that a new engine will inherently have considerably
less oil leakage from the bearings.
That's why preheat is so important to a Lycoming engine. It isn't as
though it is someting that should be done (usually). It is something
that must be done religiously every time (especially with summer weight
oil) as once cam surfaces are scratched, failure isn't far away. The
longer an engine has been sitting, the more the need for preheat. The
newer the engine, the more the need for preheat too. When and how
much? Who knows.
Also - thick oil reduces the flow demand of the engine, and more of it
will simply blow over the relief valve. Oil that is bypassed this way
has no access to the heat of the engine. Oil warmup will be slow even
if the CHT is getting into an operating range.
My guess is that there was a cold start or summer oil combination
somewhere in its history although you indicated you always preheated.
Or maybe the cam which is supposed to be case hardened isn't as hard as
it should be. You might check the cam hardness with a new file on
another lobe. It should not be able to bite into it. If it does, get
a hardness test done on it.
Nasa Icing courses Jim Burns Piloting 96 February 1st 06 04:16 AM
Nasa Icing courses Jim Burns Owning 108 February 1st 06 04:16 AM
ASRS/ASAP reporting systems - how confidential? Tim Epstein Piloting 7 August 4th 05 05:20 PM
NASA Icing Course [email protected] Piloting 3 December 28th 04 05:18 PM
FAA letter on flight into known icing C J Campbell Instrument Flight Rules 78 December 22nd 03 07:44 PM
