Lancaster California: Another Fatal Cirrus Crash
Old January 12th 06, 06:22 PM posted to rec.aviation.piloting
Default Lancaster California: Another Fatal Cirrus Crashof
wrote)
I went on a 1 hour CFI demo in a SR22-GTS last summer and was thoroughly
impressed with the plane. I discussed the plane's accident history witht
the demo pilot and his take (like most I think) is that it's generally
unfamiliarity with the plane aggravated by low-time/inexperienced pilots
that's been the root of most of these accidents.
I thought a Cirrus demo pilot died in a Cirrus a year or two ago. Not the
test pilot in '99, but a factory designated demo safety pilot rep - whatever
they're called.
Montblack
  #42
Old January 12th 06, 09:25 PM posted to rec.aviation.piloting
whatever
they're called.
I hadn't heard of that - Hmmm...if so, that wouldn't be very good PR
would it?
Wooly
  #43
Old January 12th 06, 10:25 PM posted to rec.aviation.piloting
cpu wrote:
I did not try engine fail practice in Cirrus. However, every pilot
knows during initial climb out if engine fail, you have to lower the
noise IMMEDIATELY ON ANY SEL AIRCRAFT.
Again, baloney. The plane will stay at the trimmed airspeed until it
hits the ground. You may want to push the nose over to hit a certain
spot but it is not necessary to keep the plane in the air.
Countless such take off crash
cases not limit to Cirrus. You can go to AOPA's Air Safety Foundation
to read on the training material about how to do during take off engine
fail. I believe while that SR-20 turned crosswind, he did not reach
800 feet AGL.... you have only seconds to choice a landing spot even
if you lower the nose correctly.
From 800 feet??? I thought you were talking close to the ground. When
I had my 182 I needed 450 feet to return to the runway I took off from,
landing opposite direction. From 800 feet I will make a pattern of it
and land the same way I took off.
I don't understand what do you mean
"a lot of time", basically, you don't have "a lot of time".
That of course is a relative term but from 800 feet you will have over a
minute before you hit the ground.
That is
also proved by the witness of the crash. (from engine quit to crash
only took a few seconds).
The only way to hit the ground within a few seconds from 800 feet is to
roll the plane over and aim it straight at the ground.
You probably did that 85 kt well-trimmed power loss in higher altitude
(in a practice area). I don't think you did this in 500 feet AGL,
didn't you? (otherwise you won't say you will have "plenty" of time).
The amount of time it takes to go from 800 AGL to 0 AGL is the same as
from 2000 AGL to 1200 AGL.
  #44
Old January 12th 06, 10:28 PM posted to rec.aviation.piloting
Maule Driver wrote:
First, my
experience suggests that on some a/c, the nose will immediately seek
trim speed and the nose will fall.
What aircraft does not seek its trimmed airspeed?
  #45
Old January 12th 06, 11:25 PM posted to rec.aviation.piloting
None that I know of. I just didn't want to argue the point.
But now that you brought it up, do *all* a/c seek the same rim speed if
the engine quits versus full climb power? I assume so but honestly
don't know for sure (e.g. does a T-tail respond a bit differently than a
'convential' tail)
Newps wrote:
Maule Driver wrote:
my experience suggests that on some a/c, the nose will immediately seek
  #46
Old January 12th 06, 11:30 PM posted to rec.aviation.piloting
Well, it will seek it's trim speed but hands-off, most if not all
aircraft will overshoot it a bit before finding it in the case of sudden
power loss. But agree with the point less stridently taken.
  #47
Old January 12th 06, 11:35 PM posted to rec.aviation.piloting
The airplane will pitch to its trimmed speed. Always. How can it not?
'convential' tail)
Newps wrote:
seek trim speed and the nose will fall.
  #49
Old January 13th 06, 01:08 AM posted to rec.aviation.piloting
"Maule Driver" wrote
The Cirrus is a pretty hot ship it seems. It's not about glass, it's
about wing loading.
AND the lack of drag to slow it down, once it is pointed back down, IMHO.
  #50
Old January 13th 06, 01:11 AM posted to rec.aviation.piloting
But how quickly will it do so? Will some designs do so, more rapidly than
others?
Not arguing, just asking.
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 03:55 AM
Cirrus SR20 Fatal Crash in SC Richard Kaplan Piloting 24 April 22nd 04 10:47 AM
