Why do jets leave a white trail behind them.
Old January 20th 06, 03:22 AM posted to rec.aviation.piloting
Default Why do jets leave a white trail behind them.
"Morgans" wrote in message
To the other person that said there is not enough left over H to make
water with the O in the air, sorry, incorrect. Water and heat are two
byproducts of combustion. I wish I remembered enough chemistry to balance
the equation. No, I don't! g
HnCm + (n/4 + m)O2 = (n/2)H2O + mCO2
where n and m are the number of H and C atoms in your fuel molecule.
Geoff
the sea hawk at wow way d0t com
Spell checking is left as an excercise for the reader.
  #42
Old January 20th 06, 03:34 AM posted to rec.aviation.piloting
"Matt Whiting" wrote in message
If jet fuel is full of water, how do you get it to burn? When I took
chemistry, hydrocarbon fuels contained .... drum roll please ... carbon
and hydrogen. No water of any level of significance.
For it to burn, there must be oxygen present, right? And hydrogen and
oxygen give you what?
  #43
Old January 20th 06, 07:59 AM posted to rec.aviation.piloting
I did not mean to say that the entire tank was heated [poor
choice of words on my part] but they do heat the area near
the fuel pickup/screen or use PRIST.
James H. Macklin
ATP,CFI,A&P
some support
"Bob Moore" wrote in message
. 121...
| "Morgans" wrote
| "Jim Macklin"
wrote in
| message news:kbWzf.66479$QW2.33865@dukeread08...
| Most jet aircraft have heated fuel tanks and or use
PRIST.
| The fuel control units are heated by engine oil or
electric
| elements so the screens stay ice free.
| Yes, I do know all of that, but do smaller jet fueled
planes
| (Malibu and smaller) have heated tanks?
| I don't know about the Malibu, but the large jet
transports that I
| have flown, B-707, B-727, certainly did not have heated
fuel tanks.
| Yep, the fuel filters had a heating capability using bleed
air from
| the engine compressors.....flightcrew controlled. At
higher Mach
| numbers (.80+), the temperature ram rise at the wing
leading edge
| kept the fuel from waxing under most circumstances.
| Bob Moore
  #44
Old January 20th 06, 08:34 AM posted to rec.aviation.piloting
AliR,
if you want some fun, look under chemtrails, too. But don't believe
what you read, please.
Thomas Borchert (EDDH)
  #45
Old January 20th 06, 10:43 AM posted to rec.aviation.piloting
On Thu, 19 Jan 2006 20:47:25 -0000, Skywise
Well, they must have been doing this since at least WWII, if not
sooner, as I regularly see footage of WWII bombers making trails
over Europe on various cable/sat documentary channels.
Before the bombers there were the fighters in the Battle of Britain.
Really crazy-quilt vapor trails.
-- all the best, Dan Ford
email: usenet AT danford DOT net
Warbird's Forum: www.warbirdforum.com
Piper Cub Forum: www.pipercubforum.com
In Search of Lost Time: www.readingproust.com
  #46
Old January 20th 06, 10:46 AM posted to rec.aviation.piloting
On Thu, 19 Jan 2006 18:31:45 -0500, "Morgans"
Jet fuel, kerosene, diesel fuel, are all hygroscopic. That means that they
have an affinity for absorbing water. Great amounts of it. If they absorb
enough, then it will not burn.
I suppose that's how algae(?) gets to grow in fuel tanks? A friend has
a boat with one diesel tank that's full of gunk; he can't get it out.
And I recall that years ago Pease Air Force Base nearby was bedeviled
by stuff growing in some of its jet-fuel tanks.
  #47
Old January 20th 06, 11:15 AM posted to rec.aviation.piloting
Hint: the oxygen doesn't come from the fuel. Hence the fuel isn't full
of oxygen. The fuel is full of hydrogen. That is only half of what you
need to make water.
Matt
  #48
Old January 20th 06, 01:34 PM posted to rec.aviation.piloting
PRIST is a chemical used to kill fungus in kerosene based
fuels and also prevents ice formation. It is pre-blended in
some jet fuel or added at the pump nozzle. It has to be
mixed with the fuel, not just poured in the tank.
It is poisonous. http://csdinc.org/prist/
James H. Macklin
ATP,CFI,A&P
some support
"Cub Driver" usenet AT danford DOT net wrote in message
news | On Thu, 19 Jan 2006 18:31:45 -0500, "Morgans"
it. If they absorb
A friend has
get it out.
was bedeviled
  #49
Old January 20th 06, 03:02 PM posted to rec.aviation.piloting
Darkwing wrote:
Here is the deal on "chemtrails". Ever notice on a nice day with no low,
medium or high clouds that jets also leave no vapor trails? Why?
Because it's too hard to hide them on clear days!
-m
## Mark T. Dame
## VP, Product Development
## MFM Software, Inc. (http://www.mfm.com/)
"Artificial intelligence researchers were, at times, paradoxically
regarded as both the elite and the "lunatic fringe" of computer
science."
-- Artificial Intelligence Using C, Herbert Schildt
  #50
Old January 20th 06, 05:42 PM posted to rec.aviation.piloting
You guys really need a refresher course in chemistry. When hydrocarbons
burn, the Hydrogen atoms are split off of the carbon. The hydrogen then
combines with Oxygen forming water. The carbon combines with Oxygen to form
CO2. All of this creates lots of heat. There is no "unclaimed" hydrogen.
Also, normal fuel is NOT hydroscopic. Water and fuel don't mix. That's why
you drain it out of the sumps. The water occurs in fuel tanks from
condensation from air in the tanks. It then settles to the bottom of the
tank, as it is heavier than fuel. If there is any significant amount of
water in the fuel, you've got very BIG problems (either your trying to burn
pure water, or you've got frozen fuel lines).
As a side note, some aircraft engines have used water injection as a method
to increase power output during takeoffs.
Mike Schumann
Combustion leaves some hydrogen unclaimed, and the oxygen is really happy
to claim it, and when it combines two H's, and one O, you get water.
Weren't awake during that day of chemistry, were you, Matt? g
Boeing Boondoggle Larry Dighera Military Aviation 77 September 15th 04 02:39 AM
Flying the Santa Fe Trail Story: long JJS Piloting 19 April 9th 04 02:02 AM
FS: 1986 "Fighting Jets" Hardcover Edition Book J.R. Sinclair Military Aviation 3 January 22nd 04 05:01 PM
FS: 1986 "Fighting Jets" Hardcover Edition Book J.R. Sinclair Military Aviation 0 December 2nd 03 05:10 AM
FS: 1986 "Fighting Jets" Hardcover Edition Book Jim Sinclair Aviation Marketplace 0 September 8th 03 07:43 AM
