#41
Matt Barrow wrote:
wrote in message news ![]() ted wrote: The only issue (or flaw) that has come to my attention is the risk of radio interference on the GPS civilian frequency. The replacement GPS satellites are being designed with a second civilian frequency to address this problem. How long will that take to populate the entire constellation? If necessary to facilitate commercial avaition, not nearly as long as you think. I guess to make that work we'll need to know how long I think it will be and then the percentage reduction you think will be applied to what I think. |
#42
Matt Barrow wrote:
wrote in message news:Z_4Hf.33790$JT.747@fed1read06... Matt Barrow wrote: How so? There isn't a newer version because the FAA does not like to admit when they do incorrect planning. If those old documents were valid some VORs would already be shutdown. Though VORs have some use in the near term, I can't see them being viable beyond a "few" years. No matter how old or crummy VORs are compared to GPS, GPS still has a continuity and integrity issue for sole-means en route navigation in a non-radar domestic airspace environment. Until the FAA, with some agreement from the other ICAO members, hammer that one out, VOR will continue to be the primary en route nav aid for domestic airspace. The FAA criteria worked out by an FAA/Industry rulemaking group for the new performance-based RNAV (RNP) IAPs just went into effect last June and has as one of its fundamental premises the failure of GPS during the performance-based RNAV (RNP) IAP and requires conventional nav aids for the missed approach or, where terrain requires continued RNP for the missed approach, then the aircraft must have at least one IRU to sustain acceptable RNP levels during the critical phase of the missed approach. Note the new KPSP RNAV (RNP) IAPs do not require RNP for the missed approach; they track to TRM VOR using Level 1 RNAV missed approach criteria until reaching TRM (Level 1 is the same criteria used for plain-old RNAV (GPS) IAPs). Note the KSUN RNAV (RNP) IAP requires RNP because of terrain and the lack of VOR. |
#43
"ted" wrote:
The only issue (or flaw) that has come to my attention is the risk of radio interference on the GPS civilian frequency. The replacement GPS satellites are being designed with a second civilian frequency to address this problem. http://www.dot.gov/affairs/1998/dot5598.htm http://www.aero.org/news/newsitems/g...on-041398.html http://geodesy.geology.ohio-state.ed...09/gpsfre.html http://igscb.jpl.nasa.gov/mail/igsma.../msg00316.html http://clinton6.nara.gov/1998/03/199...an-signal.html Ted, the second civil frequency on the Block IIRM satellites (known as L2C) is not operational. I have no idea when it will be operational. Look at the phase-out date for VORs in the 1999 FRP. I don't recall the date but I would guess that we are close to it now. Plus L2C is not in an approved protected frequency band for aviation (ARNS) so the FAA will not allow it for aviation. Ron Lee |
#44
"Matt Barrow" wrote:
wrote in message news ![]() ted wrote: The only issue (or flaw) that has come to my attention is the risk of radio interference on the GPS civilian frequency. The replacement GPS satellites are being designed with a second civilian frequency to address this problem. How long will that take to populate the entire constellation? If necessary to facilitate commercial avaition, not nearly as long as you think. If you launch three satellites per year then about 24/3 = 8 years. Ron Lee |
#45
Don't use outdated FRPs. Do you have a newer version? The 2005 version is he http://www.navcen.uscg.gov/Default.htm I have not read it yet. Ron Lee |
#46
From the 2005 FRP
A reduction in the VOR population (only) is expected to begin in 2010. The proposed reduction will transition from today’s VOR services to a minimum operational network (MON). The MON will support IFR operations at the busiest airports and serve as an independent civilian backup navigation source to GPS and GPS/WAAS in the NAS. Section 3.2 discusses the transition in more detail. The FAA plans to sustain existing DME service to support en route navigation, and to install additional low-power DMEs to support Instrument Landing System precision approaches as recommended by the Commercial Aviation Safety Team. The FAA may also need to expand the DME network to provide a redundant RNAV capability for terminal area operations at major airports and to provide continuous coverage for RNAV operations at en route altitudes." Conclusion: The "phase OUT" is no longer the plan. Some undefined and certainly changeable "phase DOWN" is the current plan. Ron Lee |
#47
![]() "Ron Lee" wrote in message ... "ted" wrote: The only issue (or flaw) that has come to my attention is the risk of radio interference on the GPS civilian frequency. The replacement GPS satellites are being designed with a second civilian frequency to address this problem. http://www.dot.gov/affairs/1998/dot5598.htm http://www.aero.org/news/newsitems/g...on-041398.html http://geodesy.geology.ohio-state.ed...09/gpsfre.html http://igscb.jpl.nasa.gov/mail/igsma.../msg00316.html http://clinton6.nara.gov/1998/03/199...an-signal.html Ted, the second civil frequency on the Block IIRM satellites (known as L2C) is not operational. I have no idea when it will be operational. Look at the phase-out date for VORs in the 1999 FRP. I don't recall the date but I would guess that we are close to it now. I suggest there was never any doubt that VORs would NOT be totally eliminated. That NDBs will completely disappear is fairly certain, but not likewise for VORs. Already SatNav approaches are the majority (I suspect). Perhaps the biggest factor to making GPS the primary navagation method is how badly channeling all traffic over a VOR, along airways, in cluttered space such as along the Atlantic coastal area (NY,Philly, DC...). The lack of precision for VOR navigation is a another factor. In the 1999 paper, the baseline for shutting down VORs was 2005, and now it's 2010. In any case, VORs make a good backup, but only that (comparatively speaking). I'd originally mentioned their being phased out/dpwn over a "few" years. Depending on ones definition of "few", and mine is 10-20, I suspect that being unable to perform WAAS grade approaches will be akin to the inability to do much IFR nav NORDO. In sum, it's not a matter of IF, but of WHEN. There are liekly going to be more stumbles and pratfalls along the way, but eventually the technical solutions will become "primary". |
#48
![]() wrote in message news:%_hHf.33984$JT.6861@fed1read06... Matt Barrow wrote: wrote in message news:Z_4Hf.33790$JT.747@fed1read06... Matt Barrow wrote: How so? There isn't a newer version because the FAA does not like to admit when they do incorrect planning. If those old documents were valid some VORs would already be shutdown. Though VORs have some use in the near term, I can't see them being viable beyond a "few" years. No matter how old or crummy VORs are compared to GPS, GPS still has a continuity and integrity issue for sole-means en route navigation in a non-radar domestic airspace environment. WAAS solves the integrity issue. I'm not sure what you mean by "continuity issue" |
#49
ted wrote:
wrote in message news:%_hHf.33984$JT.6861@fed1read06... Matt Barrow wrote: wrote in message news:Z_4Hf.33790$JT.747@fed1read06... Matt Barrow wrote: How so? There isn't a newer version because the FAA does not like to admit when they do incorrect planning. If those old documents were valid some VORs would already be shutdown. Though VORs have some use in the near term, I can't see them being viable beyond a "few" years. No matter how old or crummy VORs are compared to GPS, GPS still has a continuity and integrity issue for sole-means en route navigation in a non-radar domestic airspace environment. WAAS solves the integrity issue. I'm not sure what you mean by "continuity issue" Continuity means the reliability of the primary GPS sats themselves. They can have a sat failure or, more likely, jamming. |
#50
![]() -----Original Message----- From: ] Posted At: Sunday, February 12, 2006 5:53 AM Posted To: rec.aviation.ifr Conversation: GNS430 on the Airway Subject: GNS430 on the Airway ted wrote: wrote in message news:%_hHf.33984$JT.6861@fed1read06... ....clipped for brevity... [Jim Carter] Continuity means the reliability of the primary GPS sats themselves. They can have a sat failure or, more likely, jamming. [Jim Carter] Unless control of the satellite management system can be achieved, and the entire constellation interrupted, wouldn't jamming be a localized event based on the radiation pattern and power of the jamming transmitter? And to continue jamming wouldn't the transmitter have to stay active, making it a pretty easy target for any of several modern weapons systems that don't rely on GPS for navigation? |
Odd clearance -- airway given twice | Roy Smith | Instrument Flight Rules | 15 | September 20th 05 03:32 PM |
GNS430 Installation | Wayne Sweet | Home Built | 0 | October 3rd 04 04:39 AM |
B-RNAV with GNS430 | Daniel Hofer | Instrument Flight Rules | 1 | September 1st 04 04:12 PM |
Wanted: Blank Datacard Garmin GNS430 | Marco Leon | Piloting | 4 | August 31st 04 06:20 PM |
Wanted: Blank Datacard Garmin GNS430 | Marco Leon | Owning | 3 | August 31st 04 03:33 PM |
