A couple of questions about IPC
Old February 10th 06, 10:10 PM posted to rec.aviation.ifr
Default A couple of questions about IPC
- IMC conditions
- Pilot flying is not IMC current
- Pilot flying is sole manipulator of the controls, and thus logs PIC
- Pilot not flying is acting PIC (required because the pilot flying
is
not IMC current) and so logs PIC
There is no provision for the pilot acting as PIC to log PIC in this
case. Only the flying pilot would be able to log PIC. The only way you
can log PIC is per 61.51(e). In this case the guy serving as PIC does
not meet the requirements of a "required crew member" since the
aircraft is legal to fly IFR with just one pilot (the fact that that
pilot isn't qualified doesn't change that).
-Robert
  #42
Old February 10th 06, 10:20 PM posted to rec.aviation.ifr
On 02/10/06 14:10, Robert M. Gary wrote:
- IMC conditions
is
-Robert
Yes, I see that, and that certainly seems to be the consensus of everyone
offering help here. So, I will conform ;-)
I just have a different interpretation of 61.51 (e) (1) (iii), because
in my opinion, the pilot not flying is required under the FARs due to
the fact that the pilot flying isn't current for IMC.
I've tried pretty hard to make my case and no ones buying it, so I'll
concede that my interpretation is incorrect.
It was a lot of fun discussing it in any event ;-)
Mark Hansen, PP-ASEL, Instrument Airplane
Cal Aggie Flying Farmers
Sacramento, CA
  #43
Old February 10th 06, 10:43 PM posted to rec.aviation.ifr
- IMC conditions
is
Actually, the pilot serving as PIC *is* a "required pilot" under the
regulations that apply to the flight; and being required *by those
regulations* is what 61.51e1iii talks about. It's the *other* pilot (the
sole manipulator) who isn't required under the regulations that apply to the
flight in question.
--Gary
  #44
Old February 10th 06, 10:48 PM posted to rec.aviation.ifr
"Mark Hansen" wrote in message
No need to change your view just because you're in the minority.
Yup, you're right about that. I don't see how that could be disputed.
The question is why you'd think that the regs require the *other* pilot to
be there. Remember, 61.51e1iii only applies if the regs require there to be
*more than one pilot* for the particular flight.
The fact that the handful of people who happened to chime in here disagree
with you is no reason to concede error! On the other hand, the *reasons*
we've put forth may well be grounds for you to do so.
--Gary
  #45
Old February 10th 06, 10:54 PM posted to rec.aviation.ifr
- IMC conditions
is
flight in question.
But I guess the pilot not flying (in this case), although a required
crew member as per 61.51 (e)(1)(iii), cannot log his time as PIC *if*
the pilot flying logs his time as PIC as per 61.51 (e)(1)(i).
Is that right?
--Gary
Sacramento, CA
  #46
Old February 10th 06, 10:56 PM posted to rec.aviation.ifr
Actually, the pilot serving as PIC *is* a "required pilot" under the regulations that apply to the flight;
If that were true with regard to 61.51(e) then this pilot would be able
to log PIC. However, I cannot see how you can say he meets that
requirement...
61.51(e)...
(iii) Except for a recreational pilot, is acting as pilot in command of
an^M
aircraft on which more than one pilot is required under the type^M
certification of the aircraft or the regulations under which the flight
is^M
conducted.^M
How can you say this operation requires multiple crew members??
-Robert
  #47
Old February 10th 06, 10:58 PM posted to rec.aviation.ifr
Don't back down just because you're being bullied. However, the
question not, "is this pilot required" but "does this operation require
MORE THAN ONE pilot"
61.51(e)...
an^M
is^M
conducted.^M
  #48
Old February 10th 06, 11:10 PM posted to rec.aviation.ifr
I'm not asserting that the pilot flying (PF) is required by regs to be there.
I think the regs entitle the PF to log PIC as per 61.51 (e)(1)(i).
Where I'm getting lost is that if the pilot-not-flying (PNF) must act as
PIC (because someone must act as PIC, and the PF cannot due to IMC currency),
why his time cannot be logged as PIC.
I think the answer is that acting as PIC doesn't mean you can also log PIC.
But ... 61.51 (e)(1)(iii) seems to tell me that because the PNF is required
to be there, he can log his time as PIC.
Let me state 61.51 (e)(1)(iii) in a way that I think makes my point:
"is acting as pilot in command of an aircraft on which more than one pilot
is required by the regulations under which the flight is conducted."
But ... I think what you're saying is that only one crew member is required
because if the PNF was alone, the flight would be legal (assuming he started
flying). I guess I was getting hung up on the premise that the PF not being
IMC current caused the 2nd crew member to be required.
Do you see why I presumed the 2nd crew member was required?
And I know you're going to a lot of effort here, and I really appreciate
it.
--Gary
Sacramento, CA
  #49
Old February 10th 06, 11:20 PM posted to rec.aviation.ifr
everyone
to be there. Remember, 61.51e1iii only applies if the regs require there
to be *more than one pilot* for the particular flight.
there.
Ok, good. No disagreement so far.
No disagreement there either.
currency),
PIC.
Right. More specifically, 61.51e1iii says you can log PIC time *only* under
three specified conditions (and *being* PIC is *not* one of those
conditions).
required
No, that's not what 61.51e1iii says. How do you interpret it that way?
pilot
Yes, that's what 61.51e1iii says. But how does that make your point?
required
started
flying).
Yes. The PIC is the only required pilot in the IMC/IFR scenario.
You're right that the second pilot is required. But the first one isn't!
Yes, and I agree with you on that. But 61.51e1iii only applies if the first
pilot is *also* required. That is, 61.51e1iii only applies if *more than
one* pilot is required for the flight.
--Gary
  #50
Old February 10th 06, 11:24 PM posted to rec.aviation.ifr
to log PIC.
Not at all. Why do you say that? Being a required pilot does not entitle you
to log PIC time; that's not one of the three specified conditions in
61.51e1.
requirement...
61.51(e)...
an^M
is^M
conducted.^M
I *didn't* say that. In fact, I repeatedly said the opposite.
--Gary
OK, I'm off... Simon Robbins Rotorcraft 15 March 14th 05 12:44 AM
Does FAA respond to FAQ questions? Robert M. Gary Piloting 0 July 6th 04 10:22 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 1 January 2nd 04 09:02 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 2nd 03 03:07 AM
Accelerated spin questions John Harper Aerobatics 7 August 15th 03 07:08 PM
