On Sat, 25 Mar 2006 16:56:43 GMT, Shmaryahu b. Chanoch
wrote: The History Channel recently had a piece on the F14. I did not realize that plane came out of the F111 program. Nor that it could track 24 enemy targets, engaging up to 6 at a time (and at long range). The question is whether we still need an platform that can do long range combat. We have dropped the AAAM (AIM-155) which was to be a replacement for the Phoenix (AIM-54) (http://www.globalsecurity.org/milita...tions/aaam.htm) Nor do we have a radar equal to what was on the F14. Also they commented on how the F14 was a better platform than the F15 (which had some real survivability) Any insights? The F-14 was probably the first operational system with reliable track-while-scan capability. (I'm sure the Luftwaffe had something similar during 1943, but it didn't reach full production....nahhhh.) The ability to track targets while still searching for others was a significant advantage. IIRC, they demonstrated the six-target engagement capability and successfully splashed all six independently flown drones. The real threat that the F-14 was designed for was the ASM's of the Soviet bombers--systems like Kitchen and Kelt. That threat is no longer very high on the priority list. Today we've got more force integration with AWACs (or similar) doing the long range detection and target allocation for the interceptors. That offloads a requirement for some sensors capability from the fighter to the larger platform. One could also make the argument that a follow-on to AIM-54 isn't required--threat is gone and the fact that the system was never used in combat during its life cycle would indicate that other weapons would have a higher priority for budget $$. As for the F-14 as "a better platform than the F-15"--you would have to caveat that with some mission parameters. Both aircraft have been very good and each has some corners of the operational envelope in which it is superior. Ed Rasimus Fighter Pilot (USAF-Ret) "When Thunder Rolled" www.thunderchief.org www.thundertales.blogspot.com |
The F14 had great legs (fuel/range), and a very powerful radar (good for
very long range detection and burning through ECM). The track/lock while scan was a major improvement, as were the AIM-54 missiles. However, the 6 missile engagement was more of a publicity student than a reality. It was only tried once, and only four missile hit. One malfunctioned, and another targeted a drone that malfunctioned and so it never hit (BTW, the 38 second test cost $154,000 per second!!). The Tomcat couldn't carry 6 missiles and still normally land back on a carrier. With even 4 Pheonixes reducing fuel levels at landing to critical when doing carrier ops. So typically they only carried two. And even then, pilots lamented the drag/weight restrictions that the massive missiles imposed when they were carried. Granted though, the Pheonix gave a fire-and-forget capability that was unrivaled for 20 years, and no other AAM can come close to matching its range (other than the Mig-31 copy of it). I would say that the Russians took the threat of the F14 very seriously (as witnessed by their naval bomber/missile developments). So it ultimately did what it was designed to do by putting fear into the hearts of potential enemies and protecting US (and allied) forces by sheer intimidation. It does have a perfect, if limited, combat record (not including questionable Iranian records). However, as Ed mentions, comparing it to the F15 is comparing apples to oranges. For much of its career the F14 had engines with inadequate thrust and a nasty tendancy to stall, so it was inferior in the dogfight. The Eagle benefited from better funding, and had some really nifty avionics. As witnessed by its superior NCTR performance in the Gulf War (i.e., it could better identify hostile vs. friendly planes at BVR distances). Also, the Eagle has a kill record of around 100 - 0. So any hypothetical comparison you make (to the 14, or Su27, or even F22) has to bear in mind that very impressive, real-life, perfect combat record. The Eagle has certainly done everything it has been asked to do, and proven that it can beat every A-A opponent it has faced in war. As far as radar equivalent, I would wager that the V2 radars in some F15Cs, and the radars in the F18E/Fs, and definitely the radar in the F22, are superior to that in the F14, even if brute power is different. Plus, as Ed said, AWACS plays a central role in most combat situations, so an ultra-long range fighter radar is not necessary. That's my two cents with the caveat that this is arm-chair speculation from an arm-chair flyer. |
"TV" wrote:
:As far as radar equivalent, I would wager that the V2 radars in some F15Cs, :and the radars in the F18E/Fs, and definitely the radar in the F22, are :superior to that in the F14, even if brute power is different. Plus, as Ed :said, AWACS plays a central role in most combat situations, so an ultra-long :range fighter radar is not necessary. Actually, the F-15 is lagging in radar (there is a plan to upgrade some of them to cover the slide right in JSF delivery, I gather). The radar on the Super Hornet is probably slightly better (in some regards) than that on the F-22, not being constrained by the 'stealth' design. As for the complementing missiles, the Slammer has a shorter range but a MUCH larger 'no escape' cone than the Phoenix. It's lighter and an aircraft of a given capacity can carry more of them. -- "Millions for defense, but not one cent for tribute." -- Charles Pinckney |
guys have been talking about the eagle and the tomcat as dogfighters -
either one have been really ever vaunted as good turning jets. they are bvr platforms. the hornet and viper can easily defeat both the eagle and tomcat in practically any turning engagement aesa radars in elmendorf based eagles are very, very good... |
![]() wrote in message ups.com... guys have been talking about the eagle and the tomcat as dogfighters - either one have been really ever vaunted as good turning jets. they are bvr platforms. the hornet and viper can easily defeat both the eagle and tomcat in practically any turning engagement The numbers I ran across indicate that the sustained turn rate of the F-15C is just about the same as that of the F/A-18E, and not that far off from that of the F/A-18C. All apparently reside in the high teens arena in that regard. Brooks aesa radars in elmendorf based eagles are very, very good... |
![]() wrote in message ups.com... guys have been talking about the eagle and the tomcat as dogfighters - either one have been really ever vaunted as good turning jets. they are bvr platforms. the hornet and viper can easily defeat both the eagle and tomcat in practically any turning engagement aesa radars in elmendorf based eagles are very, very good... Spoken from cockpit experience? I thought not. I grant that both aircraft are more difficult to fly well in the "knife fight in a phone booth" environment (particularly so when compared to the point-and-pull Hornet). Easily defeated? Hardly. R / John |
i have less than 300 hrs in the hornet, and my comments about beating
the eagle in bfm are from my experience only. on my squadron the eagle is generally regarded as a poor turning platform and i tend to agree. you need to remember sustained turn performance is but one measure of fighter capability. |
Does the F18's radar have the same tracking capability as the F14? I feelwe
are doing a disservice to the Navy by retiring this plane. This is heartbreaking. -JC "Fred J. McCall" wrote in message news ![]() "TV" wrote: :As far as radar equivalent, I would wager that the V2 radars in some F15Cs, :and the radars in the F18E/Fs, and definitely the radar in the F22, are :superior to that in the F14, even if brute power is different. Plus, as Ed :said, AWACS plays a central role in most combat situations, so an ultra-long :range fighter radar is not necessary. Actually, the F-15 is lagging in radar (there is a plan to upgrade some of them to cover the slide right in JSF delivery, I gather). The radar on the Super Hornet is probably slightly better (in some regards) than that on the F-22, not being constrained by the 'stealth' design. As for the complementing missiles, the Slammer has a shorter range but a MUCH larger 'no escape' cone than the Phoenix. It's lighter and an aircraft of a given capacity can carry more of them. -- "Millions for defense, but not one cent for tribute." -- Charles Pinckney |
"John C" wrote in a broken top-posting, which
I have corrected: :"Fred J. McCall" wrote in message :news ![]() : : :As far as radar equivalent, I would wager that the V2 radars in some F15Cs, : :and the radars in the F18E/Fs, and definitely the radar in the F22, are : :superior to that in the F14, even if brute power is different. Plus, as Ed : :said, AWACS plays a central role in most combat situations, so an ultra-long : :range fighter radar is not necessary. : : Actually, the F-15 is lagging in radar (there is a plan to upgrade : some of them to cover the slide right in JSF delivery, I gather). The : radar on the Super Hornet is probably slightly better (in some : regards) than that on the F-22, not being constrained by the 'stealth' : design. : : As for the complementing missiles, the Slammer has a shorter range but : a MUCH larger 'no escape' cone than the Phoenix. It's lighter and an : aircraft of a given capacity can carry more of them. : ![]() Define what you mean. :I feelwe :are doing a disservice to the Navy by retiring this plane. This is :heartbreaking. The Navy are the ones that accelerated its retirement. It's simply too expensive to maintain and operate, given its age. -- "Millions for defense, but not one cent for tribute." -- Charles Pinckney |
