Icing Airmets
Old January 30th 04, 03:04 PM
Mike Rapoport
If you say so John but you never present any evidence or reference to back
up your assertions. Small droplets are not a major icing hazard because
they freeze right at the leading edge..
MU-2
"Tarver Engineering" wrote in message
ink.net...
"Bob Gardner" wrote in message
news:XKARb.132385$nt4.579289@attbi_s51...
Any time air is accelerated, as it is when passing over a small-radius
surface, its temperature drops...so it is entirely possible to accrete
ice
when the temp is above zero.
first...OAT guage, struts, lower edge of windscreen where there is a
lip
rather than a flush surface, etc. That is also why tail feathers begin
to
accrete ice before the wing's leading edge does.
Bob Gardner
While small radius objects do collect ice better than larger redius
objects,
temperature drop has nothing to do with it. Small radius objects have a
higher "collection efficiency" meaning more of the droplets in their
path
will impact the surface. They have a higher collection efficiency
because
they don't project a "bow wave" as far in front of them as larger. You
NEED
supercooled water for airframe icing.
Not exactly. Small objects and small water lead to the best conditions,
from a statistical standpoint, for gathering ice.
  #43
Old January 30th 04, 03:54 PM
Tarver Engineering
nk.net...
I'll take Brownlee's FAA flight test over you any day, Rapport.
ink.net...
small-radius
accrete
ice
lip
begin
to
Bob Gardner
objects,
a
path
because
You
NEED
  #44
Old January 30th 04, 04:32 PM
Mike Rapoport
Why don't you post some data from Mr. Brownlee then. Or even his opinion.
MU-2
nk.net...
back
ink.net...
small-radius
accrete
ice
a
lip
begin
to
Bob Gardner
objects,
have
a
path
because
You
NEED
conditions,
  #45
Old January 30th 04, 05:19 PM
Tarver Engineering
ink.net...
Call Joe on the telephone and ask him yourself, Rapoport, he is one hell of
a nice guy.
  #46
Old January 30th 04, 05:52 PM
Mike Rapoport
So you really don't have anything that supports your position which
contradicts all published information from all sources.
MU-2
ink.net...
opinion.
of
a nice guy.
  #47
Old January 30th 04, 06:34 PM
Tarver Engineering
nk.net...
All I have is my conversation with Brownlee and his flight test pilot staff.
At the standrdization seminar's conclusion they all gathered around me while
Joe made the small droplet statement and they wanted soemthing from me on
probabilities. The FAA flight test pilot staff that flew the actual flights
of the large droplet study were there. Their conclusion was that the
original assumption of lthe large droplet icing study was completely wrong
and I made the comment that perhaps they could get new funding to study
small droplets; everyone laughed.
I believe the results of the flight test are published, but I am not going
to search it up for you.
ink.net...
opinion.
of
a nice guy.
  #48
Old January 30th 04, 06:47 PM
Tarver Engineering
nk.net...
staff.
while
flights
As an adendum:
Keep in mind that aero engineers have a very difficult time dealing with
their own data and equations being false. As an example, the Law of the
Wall was removed as a regulatory hurdle, once it was pointed out that the
Law is dimensionally without any basis in physical reality; yet some aero
engineering schools still teach the Law of the Wall.
  #49
Old January 30th 04, 07:40 PM
Michael
Icebound wrote
Almost. Icing occurs when a below freezing aircraft encounters supercooled
water. Supercooled water does not exist above 0C.
True, but only partially correct.
Above-freezing water will still freeze and cling to your below-freezing
airframe.
Not at any significant rate. The issue is heat transfer. If the
water is not already at or below the freezing point, then it must shed
excess heat and be cooled to the freezing point, or it will not
freeze. Even if a droplet comes into contact with a subfreezing
surface, most of it will be long gone before it can cool sufficiently.
In fact, the preferred migration of liquid and of
not-condensed water vapour is "from warm to cold". So moisture will
migrate to the below-freezing airframe....
This makes no sense.
you can even get a thin sheet
of ice forming in absolutely clear air, simply from the condensation of
the water vapour. (similar to your glasses fogging when you come inside
from the cold)
This is true, but wholly irrelevant. The accretion rate involved is
so low as not to matter.
Michael
  #50
Old January 30th 04, 08:16 PM
Julian Scarfe
"Roy Smith" wrote in message
When a gas undergoes adiabatic expansion, it gets cooler. There is no
doubt that this happens at the leading edges of airfoils, but at the
pressure drops we're talking about in any kind of airplane I'm likely to
fly is very small. How small is very small? I'm not sure, but I can't
imagine more than a degree or two.
Yes, you in the back? What's that?
Have you been sleeping in class *again* Dr Smith? :-)
http://groups.google.com/groups?selm...erver.ntli.net
(Actually Roy, you're correct.)
The summary was:
1) I assert that airframe icing can only occur at points on the airframe
where the static temperature is below freezing.
2) Since the pressure over the top surface of a wing is less than the
freestream pressure, the associated reduction in temperature can cause the
airframe to be cooler than the temperature indicated on an OAT probe.
3) I find that the difference in temperature between indicated OAT and the
coolest part of the wing is proportional to the wing loading of the aircraft
divided by the freestream pressure, and varies a little with AOA.
4) For light aircraft, the difference in temperature between indicated OAT
and the coolest part of the wing is unlikely to exceed about 1 degC. For
big jets, the difference in temperature is unlikely to exceed about 10 degC.
Mike suggests (and I think he suggested in Dec 2002 when I wrote the article
cited above) that the rate of cooling of water droplets is such that water
droplets above 0 degC will not freeze on running back on a wing that has a
part of it that is sub-zero. I haven't done that particular sum, so won't
comment on that until I have.
Julian Scarfe
Descending through a thin icing layer Wyatt Emmerich Instrument Flight Rules 70 December 31st 03 05:17 AM
FAA letter on flight into known icing C J Campbell Instrument Flight Rules 78 December 22nd 03 07:44 PM
Supercooled Water - More on Icing O. Sami Saydjari Instrument Flight Rules 50 December 11th 03 01:20 PM
FAR 91.157 Operating in icing conditions O. Sami Saydjari Instrument Flight Rules 98 December 11th 03 06:58 AM
snow and icing Teacherjh Instrument Flight Rules 10 December 10th 03 04:00 AM
