tailwheel endorsement
Old April 21st 06, 10:39 PM posted to rec.aviation.piloting
Default tailwheel endorsement
If a student pilot takes all his training in a tailwheel aircraft
(including solo), but takes his flight test in a nosedragger, does the
newly minted private pilot need a separate tailwheel endorsement?
Jose
The price of freedom is... well... freedom.
Old April 22nd 06, 01:29 AM posted to rec.aviation.piloting
The endorsement for solo specifies the type of aircraft and should
suffice for the specific tailwheel endorsement.
Old April 22nd 06, 03:30 AM posted to rec.aviation.piloting
I do not think that is correct.. a "student" pilot does not need all the
funny endorsements while a student.. but once graduated.. he does..
we run into this with glider students... the student endorsement does not
specify type of launch procedure.. but after the check ride.. he needs the
endorsement
BT
Old April 22nd 06, 06:16 AM posted to rec.aviation.piloting
"BTIZ" wrote in message
news:kzg2g.8412$Qz.914@fed1read11...
The endorsement is required when acting as PIC. A student pilot flying solo
is acting as PIC. Ergo, the endorsement is required by a student pilot
flying solo.
Old April 22nd 06, 01:41 AM posted to rec.aviation.piloting
"Jose" wrote in message
om...
Why wouldn't he?
The student pilot needs the endorsement just to solo. But even if he
didn't, there's no exception allowing a pilot taking the practical flight
exam in a tailwheel airplane to get away without the endorsement. A pilot
taking the exam in a nosewheel airplane would require the same endorsement.
Pete
Old April 22nd 06, 03:44 AM posted to rec.aviation.piloting
Student pilots are exempt from the endorsement requirement since they
are "type rated" to that aircraft.
-Robert, CFI
What FAR grants that exemption?
Old April 22nd 06, 08:00 PM posted to rec.aviation.piloting
61.31(k)(2)(ii)
Old April 23rd 06, 12:29 AM posted to rec.aviation.piloting
61.31(k)(2)(ii)
Thanks. I did see that (later). I also saw someone else state that the
tailwheel restriction isn't a rating limitation.
I personally don't see why it's not a rating limitation, but do you have an
official definition of "rating limitation" to use to properly understand
61.31(k)(2)(ii)?
Pete
Old April 22nd 06, 01:54 AM posted to rec.aviation.piloting
The student solo endorsement is for the specific make and
model, which may be a tailwheel [conventional] airplane.
But just to be on the safe side, as part of the long list of
endorsements required by FAR 61.31, I would make the 61.31
entry and any other that applied, such as complex, high
performance or high altitude. A few lines of hand written
text and a signature don't take much time or cost very much
and could save a lot of questions later.
James H. Macklin
ATP,CFI,A&P
some support
om...
aircraft
endorsement?
| Jose
Tailwheel units on ebay Victor Bravo Home Built 1 July 24th 05 09:47 AM
Tailwheel Crosswind Landing Piloting 32 December 6th 04 02:42 AM
Advice on flying Pitts with Haigh Locking Tailwheel Ditch Home Built 19 January 4th 04 10:18 PM
Tailwheel endorsement John Harper Piloting 58 December 12th 03 01:48 PM
