Is that always true? I know I hear this pattern sometimes, but I thought
it wasn't necessarily true. Not i my experience. I have actually heard the controller's transmission stop midway thru as he was talking to an airplane on another freq....switched to the freq he was talking to the other airplane on and hear him finish his transmission. Most of the time they will broadcast on all the freqs they are working, but not always. -John *You are nothing until you have flown a Douglas, Lockheed, Grumman or North American* |
![]() "Snowbird" wrote in message om... Is that always true? I know I hear this pattern sometimes, but I thought it wasn't necessarily true. Always true? I don't know, but if it's not it's certainly the norm. I try to stay from absolutes because there are almost always exceptions. Note that in another response I said "When controllers are working many frequencies they typically broadcast on all of them simultaneously." I recall working with a former Denver Center controller nearly twenty years ago who described working a sector with multiple transceiver sites using the same frequency. He had to select which site to use depending on the location of the aircraft. In any event, if he's spending time on the 'phone coordinating, we won't hear that. No, but if you don't hear him broadcasting to any aircraft he's probably got nothing to coordinate. |
![]() "Steven P. McNicoll" wrote in message = ink.net... =20 =20 =20 I recall working with a former Denver Center controller nearly twenty = years ago who described working a sector with multiple transceiver sites = using the same frequency. He had to select which site to use depending on the location of the aircraft. =20 =20 I've run into that with Centers covering mountainous areas, too. The first time, I thought I was losing coverage because I could barely hear the controller talking to other aircraft on the frequency. When I asked if he could copy me, he replied loud and clear to my area, and explained what I'd just experienced was exactly as Steven described. I wouldn't try to guess whether Phoenix Tracon might have a similar = setup. ---JRC--- |
"Steven P. McNicoll" wrote:
I recall working with a former Denver Center controller nearly twenty years ago who described working a sector with multiple transceiver sites using the same frequency. He had to select which site to use depending on the location of the aircraft. I've experienced that very situation also, in Denver and ABQ airspace. It got so confusing one time, that the controller had to make a broadcast to explain it to all us VFR flight following types, that he had multiple transmitters on the same frequency, and not to worry if you don't hear every transmission. What I've always wondered, is why do they bother? Are they just trying to save a little electricity? It seems like this switching of transmitters on and off is just extra workload for them with no particular advantage. No one else is using the frequency in that area except him. What am I missing? Mike |
he may have been working multiple freqs. Sounds like you are the one with
the problem, not him. Don't blame him for anything - next time file IFR the whole trip. "Jeff" wrote in message ... Just a quick note to any of you guys flying IFR into the phoenix area. I just got back from a trip to phoenix from vegas, I had filed a composit flgiht plan, VFR untill I was by phoenix then I would request my IFR if it was needed since FSS reported overcast at 2700 and few at 600. freezing level was 7000-8000, MEA was 9000 in some parts and 10,000 during other parts of route. I chose VFR the first part of the flight so I could have the latitude to dodge clouds to prevent icing. all went fine, I got handed off to phoenix approach, I was at 12,000 ft on top of the layer, no way into phoenix except through that mess either. So I asked phoenix for my IFR and he said I was cleared into class B and to decend to 7000 and he would look for my clearence. I start my decent, between some clouds and he comes back and says to turn toward carefree if I want to pick up my IFR because he was to busy. no one was talking except me. then he told me to stay clear of class B. so here I am now down from my safe altitude above the clouds, a nitwit controller, I zig zag between some clouds and call him again, he says he cant see me on radar and to turn towards carefree, so I figured I would follow the valley under some clouds, then my wife says dont turn that way, that mountain is covered by clouds, so I get back on the radio and tell the controller he got me down here, I amnow stuck and I needed my clearence or I would be in trouble. He finally said, ok, and gave it to me. man that guy ****ed me off. there was another guy trying to do the same thing as me in a cessna, right after I got my clearence, and the controller told him to stay at 2500 ft and turn towards carefree because he was "saturated" with IFR departures. Yet no one else was talking. then here I am in these nasty clouds, outside temp about -2, he gives me to decend to 6000, then right after that screams at me traffic alert decend to 5000 ...so I am in total IMC diving down to 5000 ft.. then he does not want me to do the ILS, he tells me to decend to 2700 ft and to be prepared for the visual. man what a crappy flight - and I didnt even tell you about the 1500 fpm downdraft or when my engine started losing power. that controller still has me ****ed off and its 2 days later. |
dont blame him for anything?
who was controlling that other plane? I sure was not. there is no reason to have to file IFR the entire trip. Richard Hertz wrote: he may have been working multiple freqs. Sounds like you are the one with the problem, not him. Don't blame him for anything - next time file IFR the whole trip. "Jeff" wrote in message ... Just a quick note to any of you guys flying IFR into the phoenix area. I just got back from a trip to phoenix from vegas, I had filed a composit flgiht plan, VFR untill I was by phoenix then I would request my IFR if it was needed since FSS reported overcast at 2700 and few at 600. freezing level was 7000-8000, MEA was 9000 in some parts and 10,000 during other parts of route. I chose VFR the first part of the flight so I could have the latitude to dodge clouds to prevent icing. all went fine, I got handed off to phoenix approach, I was at 12,000 ft on top of the layer, no way into phoenix except through that mess either. So I asked phoenix for my IFR and he said I was cleared into class B and to decend to 7000 and he would look for my clearence. I start my decent, between some clouds and he comes back and says to turn toward carefree if I want to pick up my IFR because he was to busy. no one was talking except me. then he told me to stay clear of class B. so here I am now down from my safe altitude above the clouds, a nitwit controller, I zig zag between some clouds and call him again, he says he cant see me on radar and to turn towards carefree, so I figured I would follow the valley under some clouds, then my wife says dont turn that way, that mountain is covered by clouds, so I get back on the radio and tell the controller he got me down here, I amnow stuck and I needed my clearence or I would be in trouble. He finally said, ok, and gave it to me. man that guy ****ed me off. there was another guy trying to do the same thing as me in a cessna, right after I got my clearence, and the controller told him to stay at 2500 ft and turn towards carefree because he was "saturated" with IFR departures. Yet no one else was talking. then here I am in these nasty clouds, outside temp about -2, he gives me to decend to 6000, then right after that screams at me traffic alert decend to 5000 ...so I am in total IMC diving down to 5000 ft.. then he does not want me to do the ILS, he tells me to decend to 2700 ft and to be prepared for the visual. man what a crappy flight - and I didnt even tell you about the 1500 fpm downdraft or when my engine started losing power. that controller still has me ****ed off and its 2 days later. |
Jeff,
A couple things.. I think out of fairness to the controller the only thing which you can say is that he was not busy on your freqency. It is possible that he was busy on another freqency which you were unable to hear, or he could have been busy coordinating your clearance, or maybe even coordinating departures, so you would not create a problem for them. You just never know without seeing the other side. The thing to remember here is that you were VFR, and asked to pickup your IFR clearance in the air. That by definition gives you less priority in the system compared to other already IFR aircraft. Maybe the lesson here is not to pickup your clearance in a terminal area, but rather do it from the center prior to entering the TRACON's airspace. I can assure you that the controller wasn't blaming the delay on saturation for no reason.. there was obviously saturation either in his sector, or in a sector which was ahead, and/or below you. Doug Jeff wrote in message ... Just a quick note to any of you guys flying IFR into the phoenix area. I just got back from a trip to phoenix from vegas, I had filed a composit flgiht plan, VFR untill I was by phoenix then I would request my IFR if it was needed since FSS reported overcast at 2700 and few at 600. freezing level was 7000-8000, MEA was 9000 in some parts and 10,000 during other parts of route. I chose VFR the first part of the flight so I could have the latitude to dodge clouds to prevent icing. all went fine, I got handed off to phoenix approach, I was at 12,000 ft on top of the layer, no way into phoenix except through that mess either. So I asked phoenix for my IFR and he said I was cleared into class B and to decend to 7000 and he would look for my clearence. I start my decent, between some clouds and he comes back and says to turn toward carefree if I want to pick up my IFR because he was to busy. no one was talking except me. then he told me to stay clear of class B. so here I am now down from my safe altitude above the clouds, a nitwit controller, I zig zag between some clouds and call him again, he says he cant see me on radar and to turn towards carefree, so I figured I would follow the valley under some clouds, then my wife says dont turn that way, that mountain is covered by clouds, so I get back on the radio and tell the controller he got me down here, I amnow stuck and I needed my clearence or I would be in trouble. He finally said, ok, and gave it to me. man that guy ****ed me off. there was another guy trying to do the same thing as me in a cessna, right after I got my clearence, and the controller told him to stay at 2500 ft and turn towards carefree because he was "saturated" with IFR departures. Yet no one else was talking. then here I am in these nasty clouds, outside temp about -2, he gives me to decend to 6000, then right after that screams at me traffic alert decend to 5000 ...so I am in total IMC diving down to 5000 ft.. then he does not want me to do the ILS, he tells me to decend to 2700 ft and to be prepared for the visual. man what a crappy flight - and I didnt even tell you about the 1500 fpm downdraft or when my engine started losing power. that controller still has me ****ed off and its 2 days later. |
ya your right, thats why I received the traffic alert, the air was so saturated with traffic
that I was just in the way of that other plane. Doug Rinks wrote: Jeff, I can assure you that the controller wasn't blaming the delay on saturation for no reason.. there was obviously saturation either in his sector, or in a sector which was ahead, and/or below you. Doug Jeff wrote in message ... Just a quick note to any of you guys flying IFR into the phoenix area. I just got back from a trip to phoenix from vegas, I had filed a composit flgiht plan, VFR untill I was by phoenix then I would request my IFR if it was needed since FSS reported overcast at 2700 and few at 600. freezing level was 7000-8000, MEA was 9000 in some parts and 10,000 during other parts of route. I chose VFR the first part of the flight so I could have the latitude to dodge clouds to prevent icing. all went fine, I got handed off to phoenix approach, I was at 12,000 ft on top of the layer, no way into phoenix except through that mess either. So I asked phoenix for my IFR and he said I was cleared into class B and to decend to 7000 and he would look for my clearence. I start my decent, between some clouds and he comes back and says to turn toward carefree if I want to pick up my IFR because he was to busy. no one was talking except me. then he told me to stay clear of class B. so here I am now down from my safe altitude above the clouds, a nitwit controller, I zig zag between some clouds and call him again, he says he cant see me on radar and to turn towards carefree, so I figured I would follow the valley under some clouds, then my wife says dont turn that way, that mountain is covered by clouds, so I get back on the radio and tell the controller he got me down here, I amnow stuck and I needed my clearence or I would be in trouble. He finally said, ok, and gave it to me. man that guy ****ed me off. there was another guy trying to do the same thing as me in a cessna, right after I got my clearence, and the controller told him to stay at 2500 ft and turn towards carefree because he was "saturated" with IFR departures. Yet no one else was talking. then here I am in these nasty clouds, outside temp about -2, he gives me to decend to 6000, then right after that screams at me traffic alert decend to 5000 ...so I am in total IMC diving down to 5000 ft.. then he does not want me to do the ILS, he tells me to decend to 2700 ft and to be prepared for the visual. man what a crappy flight - and I didnt even tell you about the 1500 fpm downdraft or when my engine started losing power. that controller still has me ****ed off and its 2 days later. |
![]() Doug Rinks wrote: Jeff, A couple things.. I think out of fairness to the controller the only thing which you can say is that he was not busy on your freqency. It is possible that he was busy on another freqency which you were unable to hear, No, it's not possible. If you cannot hear the controller then he is not saying anything. |
"cleared to ... when direct ..." | John Harper | Instrument Flight Rules | 21 | February 11th 04 04:00 PM |
Practical IFR Question (for centre controllers) | David Megginson | Instrument Flight Rules | 10 | December 4th 03 11:26 PM |
AOPA and ATC Privatization | Chip Jones | Instrument Flight Rules | 139 | November 12th 03 08:26 PM |
Follow up Alright, All You Dashing, Swaggering Bush Pilots | wmbjk | Home Built | 135 | September 8th 03 06:09 AM |
Riddle me this, pilots | Chip Jones | Instrument Flight Rules | 137 | August 30th 03 04:02 AM |
