AUTOPILOT PROS & CONS
Old May 15th 06, 09:28 PM posted to rec.aviation.ifr
Default AUTOPILOT PROS & CONS
I've never seen a Bonanza without electric trim and an
autopilot installed. What you have seems to be just a wing
leveler with heading and [maybe] tracking.
James H. Macklin
ATP,CFI,A&P
"Roy Smith" wrote in message
| In article 5u4ag.20816$ZW3.8687@dukeread04,
| Jim Macklin wrote:
| The auto-pilot should be running the trim, the
annunciation
| is intended to be advisory. Using the electric trim will
| disengage the auto-pilot. I'm guessing that you have a
bad
| relay.
| There is no electric trim. I believe it's an option, but
our boxes
| don't have it.
  #42
Old May 15th 06, 10:00 PM posted to rec.aviation.ifr
In article PG5ag.20818$ZW3.19044@dukeread04,
Apparently not :-)
What you have seems to be just a wing leveler with heading and
[maybe] tracking.
Nope. It does heading, tracks nav, altitude hold, course intercepts,
and coupled ILS approaches. Once we get the kinks worked out of the
new add-on box, it'll be doing GPS roll steering too. We've got one
driven from a CDI, another with an HSI. It just doesn't have electric
trim. It's an option, and we don't have that option. Wish we did,
but we don't.
  #43
Old May 15th 06, 10:30 PM posted to rec.aviation.ifr
I would skip the fancy nav steering and coupling, you can
always use the heading bug to track the needle and get the
pitch trim ASAP. But, it isn't my airplane. A wing leveler
like Mooney installed is a big aid, but real altitude hold
and trim is just as important.
If you want to get spoiled, fly a $500,000 Sperry autopilot
in a King Air. I've flown a few hundred different Bonanzas,
from late 1940 models to the B36TC, if they had an
autopilot, [all the ones built after about 1965 that I flew
did] they had electric trim.
We did a Category II certification on the Beechjet and
encountered a problem caused by a poorly written flight test
schedule. The DER that was hired wrote a schedule that
called for the coupled approaches to be flown at a
stabilized speed of 1.3 Vso from the OM to landing or missed
approach. We could hand fly within the tolerances, but the
autopilot could not. We had to do extreme fore and aft CG
and the autopilot would get wild on the ILS. Came to find
out several things... FAR 25 requires that the airplane trim
function to 1.4 Vso, so 1.3 Vso might not be a trimable
speed, depending on CG. Also the autopilot was certified at
1.3 Vso +10, as far as those who did the original
certification could remember.
So we re-wrote the flight test schedule and the autopilot
flew well within the 95% 1 dot on all the approaches because
it was in trim at 1.3 Vso+10.
James H. Macklin
ATP,CFI,A&P
some support
| Apparently not :-)
heading and
| [maybe] tracking.
intercepts,
out of the
We've got one
have electric
Wish we did,
| but we don't.
  #44
Old May 16th 06, 02:16 AM posted to rec.aviation.ifr
Try the autoflight in the 767 or L-1011, and would never look back at
the King Air.
  #45
Old May 16th 06, 02:29 AM posted to rec.aviation.ifr
But a J-3 or PA 18-150 is more fun than either.
"Sam Spade" wrote in message
news:LJ9ag.177039$bm6.20988@fed1read04...
autopilot
Bonanzas,
flew
look back at
| the King Air.
  #46
Old May 16th 06, 05:09 PM posted to rec.aviation.ifr
Now you're talking!! ;-)
A Super Cub with a Garmin 296.~
  #47
Old May 16th 06, 05:15 PM posted to rec.aviation.ifr
And a comfortable seat!
And a heater that heats both seats equally.
Karl
"Curator" N185KG
news:OOmag.177086$bm6.21618@fed1read04...
  #48
Old May 16th 06, 07:21 PM posted to rec.aviation.ifr
Even better, www.cubcrafters.com
  #49
Old May 16th 06, 07:24 PM posted to rec.aviation.ifr
RefrigiWear makes the heater redundant.
http://www.refrigiwear.com/
Good boots and socks, thick wool. Think winter motorcycle
gear.
"karl gruber" wrote in message
| Karl
| "Curator" N185KG
  #50
Old May 16th 06, 11:18 PM posted to rec.aviation.ifr
I've owned two Super Cubs. One that I bought brand new in 1966 and picked it
up in Lock Haven.
It cost just under $12,000.
I prefer to fly in shirtsleeves, and certainly would never climb into a
space suit to fly. The PA-18-150, as delivered from the factory has an
excellent front set heater. It's the PAX that freezes. Although a little
tape around the doors makes it more bearable.
There are some things that Cubcrafters do to make the situation better, but
Piper never cared to change the airplane much.
Karl
ATP CFI ETC
"Curator" N185KG
"Jim Macklin" wrote in message
news:WToag.21671$ZW3.19218@dukeread04...
gear.
| Karl
| "Curator" N185KG
Experimental Catagory: Pros and Cons? [email protected] Soaring 18 April 16th 06 10:56 PM
Long Tow Rope Pros & Cons chris Soaring 7 December 10th 03 02:30 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 1 November 24th 03 02:46 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 2 November 24th 03 05:23 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 0 November 24th 03 03:52 AM
