Cabin Class?
Old May 7th 06, 09:06 PM posted to rec.aviation.piloting
Default Cabin Class?
Sure does.
"Newps" wrote in message
| Jim Macklin wrote:
| If you can stand up, it is cabin class.
| That eliminates a large number of biz jets.
  #42
Old May 7th 06, 09:50 PM posted to rec.aviation.piloting
"Morgans" wrote in message news:jlq7g.84
That is interesting. Where are they, and how do they work?
One is a small door on the right side equipped with a slide. When deployed,
the slide is very long and narrow, and often, I'm told, gets blown askew,
rendering it unusable. Even when used as designed, I'm told, it is a very
long run, resulting in a fairly high speed descent and a strong probability
of skin burns and other injuries.
The other is a roof hatch, slightly left of centerline and directly behind
the FE, used in conjunction with a body harness and inertia reel. Climb out
and just slide on down the side, trusting that the inertia reel will slow
your descent at the bottom as designed. If the aircraft is sitting on its
belly, sans gear, its about a 35 foot drop from the roof to the ground. My
guess is that the real trick would be to avoid all the probes, sensors, and
other pieces of metal projecting from the side of the craft on the way down.
Ouch!
  #43
Old May 7th 06, 10:04 PM posted to rec.aviation.piloting
"B A R R Y" wrote in message
Then again, if the 747 was crashed intact, catching the cayoones on an
antenna or pitot tube seems relatively minor. G
No, never relatively minor, but still better than death. I guess. g
Class E or Class G - another one of those that makes you go 'hmmmmm' JT Piloting 10 February 27th 06 06:41 PM
Carrying flight gear on the airlines Peter MacPherson Piloting 20 November 25th 04 12:29 AM
