Doors popping open in flight
Old June 1st 06, 10:00 AM posted to rec.aviation.piloting
Default Doors popping open in flight
Roger,
If you look, the door shape no longer matches that
of the opening.
Please, look again.
Thomas Borchert (EDDH)
  #43
Old June 1st 06, 12:16 PM posted to rec.aviation.piloting
Roger wrote:
Open the door in level flight. Now close the door in level flight. It
won't close. Why? If you look, the door shape no longer matches that
of the opening. As I recall on the Cherokee 180 the mismatch was on
the order of half an inch.
The (4) PA-28 airframes I've flown (mostly 160HP Warriors) will close
quite easily if you follow the POH in-flight door closing procedure.
With the storm window open, cabin vents closed, and the right airspeed,
the door is almost sucked closed.
Was there something wrong with the Cherokee you were flying? G
  #44
Old June 1st 06, 01:07 PM posted to rec.aviation.piloting
Roger wrote:
Consider this.
the order of half an inch. That means the fuselage flexed about a half
an inch. The door was providing additional, structural strength
albeit it's not critical.
I think you're making a wrong assumption. Look at the door, the hinges, and
the latches. There's nothing strong enough to be considered "structural".
The door frame flexes a bit. When you have the door latched securely, first,
the gap remains small. If the door frame flexes a bit, while the door is
open, there's little hope of getting the door to shut as securely.
--- Jay
Jay Masino "Home is where the critters are"
http://www.JayMasino.com
http://www.OceanCityAirport.com
http://www.oc-Adolfos.com
CFI without commercial? Jay Honeck Piloting 75 December 8th 10 04:17 PM
Dumb Reg question John Gaquin Piloting 67 May 4th 05 04:54 AM
12 Dec 2003 - Today’s Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 December 12th 03 11:01 PM
