I'll take a few flights between Rochester, NY and the Detroit area this
summer. Going through the Canadian airspace just seems so much shorter. I can go IFR. My questions is: * I don't need to deal with customs at all, as long as I don't stop at Canada, right? * Do I need to use the ICAO flight plan for the IFR, or is the FAA domestic flight plan sufficient for these flights? * Since I'll use Canadian ATC service during the overflight, will I get a bill from NavCanada when I get home? * Is it easier to do this IFR or VFR? I assume doing this IFR would make the Canadian overflight easier, but I'm very open to suggestions. Thanks! |
![]() M wrote: I'll take a few flights between Rochester, NY and the Detroit area this summer. Going through the Canadian airspace just seems so much shorter. I can go IFR. I did this a couple of years ago. * I don't need to deal with customs at all, as long as I don't stop at Canada, right? No customs. * Do I need to use the ICAO flight plan for the IFR, or is the FAA domestic flight plan sufficient for these flights? Domestic flight plan worked for me (through FSS, didn't try duats). * Since I'll use Canadian ATC service during the overflight, will I get a bill from NavCanada when I get home? Don't know this one, as I was flying a friend's plane and NavCanada changed how they do user fees since then, I think. * Is it easier to do this IFR or VFR? I assume doing this IFR would make the Canadian overflight easier, but I'm very open to suggestions. IFR made it transparent. Don't know about VFR, you'd need to go through the rigamarole of a DVFR flight plan on the way back into the US or something? |
![]() Great view of Niagara Falls, I should add. Bring your camera. (although we were routed around the Detroit area to the North, so you may not fly right over it) |
(although we were routed around the Detroit area to the North, so you may not fly right over it) What good is a flight over Niagara Falls, if you can't fly over it? (We're planning on flying that way this summer, VFR.) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
"Jay Honeck" wrote:
Great view of Niagara Falls, I should add. Bring your camera. (although we were routed around the Detroit area to the North, so you may not fly right over it) What good is a flight over Niagara Falls, if you can't fly over it? (We're planning on flying that way this summer, VFR.) It appears that ATC might be flexible when traffic is light. I flew out of Buffalo on United on the first flight out in the morning, and the pilot did a 360 over the falls before continuing to Chicago. |
Jay Honeck wrote:
Great view of Niagara Falls, I should add. Bring your camera. (although we were routed around the Detroit area to the North, so you may not fly right over it) What good is a flight over Niagara Falls, if you can't fly over it? (We're planning on flying that way this summer, VFR.) There's some stuff in the Airport/Facilities book about frequencies, directions and altitudes to use when flying over the falls. |
In a previous article, Dave Butler said:
Jay Honeck wrote: Great view of Niagara Falls, I should add. Bring your camera. (although we were routed around the Detroit area to the North, so you may not fly right over it) What good is a flight over Niagara Falls, if you can't fly over it? (We're planning on flying that way this summer, VFR.) There's some stuff in the Airport/Facilities book about frequencies, directions and altitudes to use when flying over the falls. That's true, and that's good for VFR traffic. But I've seen airliners at higher altitudes, presumably on an IFR clearance, doing a lap or two above the falls at a much higher altitude. -- Paul Tomblin http://xcski.com/blogs/pt/ Recursion: n., see Recursion. |
![]() "Paul Tomblin" wrote That's true, and that's good for VFR traffic. But I've seen airliners at higher altitudes, presumably on an IFR clearance, doing a lap or two above the falls at a much higher altitude. Wow, and double WoW! Never before, have I heard of an airliner taking the time to do some sightseeing! I wonder how much that cost the company? g -- Jim in NC |
Let me know when you are coming my way. |
Let me know when you are coming my way. Roger that. Just remember, our habit is to plan three separate vacations, in three different directions -- and then, on the morning of our departure, pick one based on the best weather forecast. We like to tell people that GA gives them a 33.3% chance of seeing us on any assigned date... ;-) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
The Impossibility of Flying Heavy Aircraft Without Training | Immanuel Goldstein | Piloting | 365 | March 16th 06 01:15 AM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
Must the PLANE be IFR-equipped to fly over17,500? | john smith | Home Built | 11 | August 27th 04 02:29 AM |
ADV: CPA Mountain Flying Course 2004 Dates | [email protected] | Piloting | 0 | February 13th 04 04:30 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
