#41
AT Parowan last June, one supper conversation with three owners of
powered single seaters detailed two propeller problems (manufacturer took a season to sort out) and one battery failure (expensive) -- unusual, I suppose. But not engine problems, eh? Ruud wrote: On Mon, 05 Jun 2006 09:12:12 -0600, Shawn sdotherecurry@bresnannextdotnet wrote: Andor Holtsmark wrote: Why are these two stroke engines so notoriously unreliable? I have been flying with sustainer engines (Solo 2350) for more than 10 years in a Discus bT, Ventus2cT and DuoDiscusT and never had a problem with it. Most of the times engine problems are the cause of bad maintenance or incorrect use of the engine. |
#42
"Greg Arnold" wrote in message news:m76hg.11350$KB.6912@fed1read08... 2cernauta2 wrote: On Mon, 05 Jun 2006 09:12:12 -0600, Shawn sdotherecurry@bresnannextdotnet wrote: Why are these two stroke engines so notoriously unreliable? Thoughts? Experience? My personal perception of 2strokes as installed on a DG400 and a DG600M, is of very good to excellent reliability. Never a problem with the single cylinder 600, a few problems with the 400 (carb needle valves, HT wires). aldo cernezzi I have no first hand experience, but I was under the impression that the simplicity of the sustainer engines (no starter, etc) means that they are quite reliable, if only because there is not much that can break. Small 2-stroke engines which require oil mixed with the fuel will often have startng problems after long periods of inactivity. The fuel/oil mix forms gum in the small passages inside the carburator blocking them. I understand there are spicific 2-stroke oils that reduce but do not eliminate this problem. The cure is to dismantle the fuel system and clean it with solvent. I wouldn't expect a weed eater, snow blower, or lawn mower that has sat with fuel in it for 6 months or so to start easily. Sustainer engines are no different. Bill Daniels |
#43
Charles Yeates wrote:
AT Parowan last June, one supper conversation with three owners of powered single seaters detailed two propeller problems (manufacturer took a season to sort out) and one battery failure (expensive) -- unusual, I suppose. But not engine problems, eh? Were these all two stroke engines? And I'm very curious how a battery failure could be expensive, given the low cost of batteries. -- Change "netto" to "net" to email me directly Eric Greenwell - Washington State, USA www.motorglider.org - Download "A Guide to Self-launching Sailplane Operation" |
#44
Bill Daniels wrote:
"Greg Arnold" wrote in message news:m76hg.11350$KB.6912@fed1read08... 2cernauta2 wrote: On Mon, 05 Jun 2006 09:12:12 -0600, Shawn sdotherecurry@bresnannextdotnet wrote: Why are these two stroke engines so notoriously unreliable? Thoughts? Experience? My personal perception of 2strokes as installed on a DG400 and a DG600M, is of very good to excellent reliability. Never a problem with the single cylinder 600, a few problems with the 400 (carb needle valves, HT wires). aldo cernezzi I have no first hand experience, but I was under the impression that the simplicity of the sustainer engines (no starter, etc) means that they are quite reliable, if only because there is not much that can break. Small 2-stroke engines which require oil mixed with the fuel will often have startng problems after long periods of inactivity. The fuel/oil mix forms gum in the small passages inside the carburator blocking them. I understand there are spicific 2-stroke oils that reduce but do not eliminate this problem. The cure is to dismantle the fuel system and clean it with solvent. I wouldn't expect a weed eater, snow blower, or lawn mower that has sat with fuel in it for 6 months or so to start easily. Sustainer engines are no different. Guess I picked up on a few out-of-the-norm complaints and assumed they were typical. Seems like a preflight run-up of the engine would reveal/mitigate many starting problems in flight. BTW, my string trimmer was a pill to start this spring :-p Shawn |
#45
At 11:30 06 June 2006, Ruud wrote:
On Mon, 05 Jun 2006 09:12:12 -0600, Shawn wrote: Andor Holtsmark wrote: Why are these two stroke engines so notoriously unreliable? -I just want to clarify that I did not ask this question. I asked about how many self sustainers used regularily hour after hour suffers from engine trouble. I hope the difference is clear. I am not trying to imply that this must happen, I am curious about what the experiences are. Andor |
#46
I was told the engine start battery replacement cost $1,000
Eric Greenwell wrote: AT Parowan last June, one supper conversation with three owners of powered single seaters detailed two propeller problems (manufacturer took a season to sort out) and one battery failure (expensive) -- unusual, I suppose. But not engine problems, eh? Were these all two stroke engines? And I'm very curious how a battery failure could be expensive, given the low cost of batteries. |
#47
Eric Greenwell wrote: AT Parowan last June, one supper conversation with three owners of powered single seaters detailed two propeller problems (manufacturer took a season to sort out) and one battery failure (expensive) -- unusual, I suppose. But not engine problems, eh? Were these all two stroke engines? And I'm very curious how a battery failure could be expensive, given the low cost of batteries. I was told the engine start battery replacement cost $1,000 Wow! What glider was it? And is that the price of the battery, or is there a terrific amount of labor involved in changing it? -- Change "netto" to "net" to email me directly Eric Greenwell - Washington State, USA www.motorglider.org - Download "A Guide to Self-launching Sailplane Operation" |
#48
My DG808B self-launcher uses 4 sealed batteries and
they all can be replaced for less than $80 which I believe is typical. The batteries are cheap enough that I replace them every two years regardless of condition. There is no gas powered glider that I know of with a $1000 battery but perhaps an electric self-launcher battery could be that expensive. Reliability and maintenance on any powered glider is going to be significantly more of an issue than a pure glider. It isn't like buying a Chevrolet where the various systems have been refined over a long period of time. The fuel/electrical systems used today are pretty crude compared to modern automotive design but given enough attention and preventive maintenance they perform pretty well. Routine operation is a very good idea regardless if it’s a self-launcher or sustainer. With the exception of one loss of electrical power mine has never failed to start or in flight after 325 frame and 25 engine hours. In that same period I have experienced 4 rope breaks on tow so the self-launcher reliability looks pretty good to me. At 17:48 06 June 2006, Charles Yeates wrote: I was told the engine start battery replacement cost $1,000 Eric Greenwell wrote: AT Parowan last June, one supper conversation with three owners of powered single seaters detailed two propeller problems (manufacturer took a season to sort out) and one battery failure (expensive) -- unusual, I suppose. But not engine problems, eh? Were these all two stroke engines? And I'm very curious how a battery failure could be expensive, given the low cost of batteries. |
#49
Maybe the high figure is what he told his wife??
Gary Evans wrote: My DG808B self-launcher uses 4 sealed batteries and they all can be replaced for less than $80 which I believe is typical. The batteries are cheap enough that I replace them every two years regardless of condition. There is no gas powered glider that I know of with a $1000 battery but perhaps an electric self-launcher battery could be that expensive. Reliability and maintenance on any powered glider is going to be significantly more of an issue than a pure glider. It isn't like buying a Chevrolet where the various systems have been refined over a long period of time. The fuel/electrical systems used today are pretty crude compared to modern automotive design but given enough attention and preventive maintenance they perform pretty well. Routine operation is a very good idea regardless if it’s a self-launcher or sustainer. With the exception of one loss of electrical power mine has never failed to start or in flight after 325 frame and 25 engine hours. In that same period I have experienced 4 rope breaks on tow so the self-launcher reliability looks pretty good to me. |
#50
At 16:18 06 June 2006, Shawn wrote:
Seems like a preflight run-up of the engine would reveal/mitigate many starting problems in flight. My thought exactly. There have been some comments here that sustainers generally are not run up prior to flights (presumably including flights where use of the engine is a distinct possibility) AND that periods of inactivity significantly up the odds of the engine failing to start. If both of these statements are true it seems that flying a sustainer-equipped sailplane cross-country without a preflight engine runup is a bit of a roll of the dice. It also raises in my mind two somewhat related questions: 1) Is there a good reason why one shouldn't do a runup prior to every (cross-country) flight? 2) Do many pilots flying sustainer-equipped sailplanes presume that the engine is unlikely to start and not care, do they presume that the engine IS likely to start (correctly or incorrectly), or do they believe a preflight runup doesn't help the odds anyway. Thoughts? 9B |
| Thread Tools | |
| Display Modes | |
| RAF Blind/Beam Approach Training flights | Geoffrey Sinclair | Military Aviation | 3 | September 4th 09 07:31 PM |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 07:58 PM |
| us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk | Jehad Internet | Military Aviation | 0 | February 7th 04 05:24 AM |
| "I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 10th 04 12:35 AM |
