#41
Jim Macklin wrote:
The slaved compass is corrected so as many errors (deviation) are corrected and variation is also corrected as much as possible too, so the slaved compass may be reading different from the whiskey compass unless you apply the compass correction card FOR-Steer to get a more accurate setting for the HI. But the whiskey compass is not supposed to have any error greater than 10 on any heading. Often the compass is swung with the electrical and radios running. It seems that swinging the compass should be done with the electrical system dead and the radios off, that is when I'd want the most accurate magnetic compass. Why do you want your compass to be most accurate when your airplane isn't being used? Matt |
#42
Tony wrote:
Dudley Henriques wrote: "Matt Whiting" wrote in message ... I also hope everyone is checking their power indications, vacuum, alternator, etc. as they commence the takeoff roll, especially if launching into IMC. Matt First 10 feet into the takeoff roll as power comes up....always!! Dudley And a final look around just before rotation. Somehow a long time ago my checklist had an item added: "Is this airplane OK to fly?" to be answered just before applying backpressure. For what it's worth, I keep one ear free of the headset until aloft, I want to hear that the engine and wind noises sound normal while still on the ground. 3000 feet of runway gives my Mooney enough space to get to lift off speed, then down to taxi speed, without breaking anything, and twice in my 2500 tt hours found a reason well into the takeoff roll to abort the flight. Taking off should NOT be automatic, it should be a concious decision made as late in the process as is safe. I actually do my final vacuum check just before I enter the clouds. And one time several years ago, I caught that my vacuum was low. I started an immediate descent to stay out of the layer and returned to the airport. Turns out that a hose had come loose on the standby vacuum system! The irony in that... Matt |
#43
Jay Beckman wrote:
The key to waht Emily said was in the fact that her employer sent her on business...the golden rule. Them with the gold, makes the rules. If your employer is buying, you stay where you're put. With regards to a quiet(er) room, who is paying or who made the arrangements shouldn't matter. You (rhetorical) are the one staying at the hotel. At a minimum, you have power when you check in so assert yourself at that point. If you notice the hotel is next to the highway when you are being dropped off/driving up in a rental car, request a room away from the highway at check-in. If you didn't notice and suffer a lousy night's sleep, complain the next morning and demand a new room. If the hotel is surrounded by a highway and there are no quiet rooms or the place is sold out, complain to your company travel agent or employee who handles the travel arrangements so that next time they might look elsewhere. As part of a very large group of travelers all going to a location where hundreds of thousands of spectators are also visiting, you are somewhat of a unique case of business traveler, Jay. ![]() phrase, "you get what you get." -- Peter |
#44
Morgans wrote:
"Ross Richardson" wrote Ross, check your settings. Is it possible that you are not posting with plain text? Did I do something wrong? I unclicked "send in HTML". My computer forgot who I was a week ago Monday and I have been resetting everything back. Some net etiquette that I was unaware of? -- Regards, Ross C-172F 180HP KSWI |
#45
"Dudley Henriques" writes:
It can happen and has happened and will happen again as long as pilots don't remember to physically check the runway heading by glancing at the DG or HSI, or even the magnetic compass EVERY time they line up for takeoff. This should be an automatic reflex action for a pilot, especially at busy airports where runways are 30 degrees or less apart in direction. That was my first thought too, especially after the news kept reporting that the flight data was consistent with taking off from the short runway. I usually check my compass and reset my DG when I line up on the runway. ("usually" == "not when rolling onto a short soft strip") It'd be hard to miss a 30 degree difference then. I wonder if we'll see calls for scheduled service to require active tower controllers. --kyler |
#46
If your employer is buying, you stay where you're put. OTOH your employer's gold is good leverage against the hotel, since it represents repeat business. Your own gold ain't. Jose -- The monkey turns the crank and thinks he's making the music. for Email, make the obvious change in the address. |
#47
Why do you want your compass to be most accurate when your airplane isn't being used? I think he means that when all the electrical systems (& DG) go south but you're still "up there, wishing you were down here", is when you want the mag compass to be dead on. Jose -- The monkey turns the crank and thinks he's making the music. for Email, make the obvious change in the address. |
#48
If your computer is messing with your settings, you get a pass while you figure it out and put the OS in its place. Posting should be in plain text. HTML foists too much crap on users. But you are already aware of this, as you unclicked "send in HTML". Maybe the OS overruled you again? Jose -- The monkey turns the crank and thinks he's making the music. for Email, make the obvious change in the address. |
#49
![]() "Kyler Laird" wrote in message ... I wonder if we'll see calls for scheduled service to require active tower controllers. Active tower controllers? |
#50
Because it is in flight and has had a total electrical
failure, all I have to navigate with is my wrist watch and the magnetic compass. In that case, I want the compass to be the most accurate as possible. When the radios work, I can use the VOR/GPS and even radar vectors, when all that is dead, the compass will get you there IF it is accurate. A 10 degree error will but you off course 10 miles every 60 [57.3] miles you fly. If visibility is 5 miles an inaccurate compass will leave you lost at sea. Maybe you will find the coastline of the continent, but if you're hope is land fall on an island, you need an accurate compass. "Matt Whiting" wrote in message ... | Jim Macklin wrote: | The slaved compass is corrected so as many errors | (deviation) are corrected and variation is also corrected as | much as possible too, so the slaved compass may be reading | different from the whiskey compass unless you apply the | compass correction card FOR-Steer to get a more accurate | setting for the HI. But the whiskey compass is not supposed | to have any error greater than 10 on any heading. Often the | compass is swung with the electrical and radios running. It | seems that swinging the compass should be done with the | electrical system dead and the radios off, that is when I'd | want the most accurate magnetic compass. | | Why do you want your compass to be most accurate when your airplane | isn't being used? | | Matt |
VQ-1's P4M-1Q crash off China - 1956 | Mike | Naval Aviation | 0 | May 6th 06 11:13 PM |
Pilot claims no blame in July crash | Mortimer Schnerd, RN | Piloting | 48 | March 15th 06 09:00 PM |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
Doubts raised in jet crash | Dave Butler | Piloting | 8 | July 26th 05 01:25 AM |
Yet another A36 crash | H.P. | Piloting | 10 | April 23rd 05 05:58 PM |
