#41
T o d d P a t t i s t wrote:
Marc Ramsey wrote: But, I fly with the electrical system I have, not the one I might want, so the transponder usually goes off in the boonies... Which would apparently put you in violation of 91.215(c) (requires transponder on) when your transponder is OFF if it meets the requirements of 91.413 and in violation of 91.413(a) when your transponder is ON if it does not meet those requirements. No good deed goes unpunished. So far, I believe it has gone unpunished: does anyone know of a glider pilot cited for turning off his transponder? I couldn't find anyone that knew of that when I wrote my article for Soaring (Feb 2002), and I haven't heard of anyone since then, either. FAA officials have told SSA officials, unofficially of course, that they are happy to have glider pilots put transponders in their gliders, even if they don't have them on all the time. I don't think we should be discouraging transponder use, even unintentionally, by bringing up the "always on" requirement. The FAA understands that requirement makes sense for airplanes but not gliders, and that someone willing to spend the money and effort to install safety equipment that is not required of them should be commended (at least off the record), not scolded. Todd, I know you may not have intended it that way, but some people do take it that way, and that is one of the reasons/excuses I hear for not installing a transponder. -- Change "netto" to "net" to email me directly Eric Greenwell - Washington State, USA www.motorglider.org - Download "A Guide to Self-launching Sailplane Operation" |
#42
On Wed, 30 Aug 2006 13:57:47 +0000, Mike Schumann wrote:
Why in the world would you leave a transponder off if you have the luxury of having one???? Transponder installations in gliders are not as reliable as we would like them to be. These are some of the reasons I know of for transponders not being operational in VFR airspace that I have experienced by myself or by other pilots I know personally: - Battery failed unexpectedly and no backup installed. - Battery failed unexpectedly and backup battery also failed unexpectedly. - Transponder display faulty and spares unavailable (a common problem with old Terra's). - Loose connection between the altitude encoder and transponder resulted in wild altitudes indications and ATC getting upset and requesting the pilot to switch off the transponder. ATC also not happy with pilot squawking mode A. - Antenna located a little too close to pilot for comfort and pilot elects to leave transponder switched off to protect the family jewels from radiation when not in controlled airspace. - Transponder operating but transmissions shielded by poorly located antenna. - Antenna damaged by earlier ground handling mishap and transponder switched off. - Transponder turned on but the pilot is unaware that it is non-functional because it has not been ground checked for a long time and the glider has not been in controlled airspace recently and hence the pilot has not had confirmation from ATC that they can see him. - Transponder is turned off because the pilot suspects it is not working but has not had a chance to get it checked either on the ground, or by talking to ATC. - Transponder removed for repairs and sent to repair facility and it takes many weeks to get it back. And a couple of other reasons reported on RAS: - Glider pilots requested to switch off transponders in certain areas after false TCAS warnings triggered at nearby airports. - Transponder set to squawk code that is filtered on ATC radar. (Please note, I don't fly in the USA, none of the above occurred in the USA so please don't quote me USA regulations.) From my experience, it is feasible to fit transponders in a few privately owned gliders for use during occasional flights in controlled airspace (or other airspace with active communication with ATC). However, it is not practical to equip an entire fleet of gliders with transponders, instruct the pilots to squawk "blind" and expect this to allow IFR traffic to be routed safely through the same airspace. This is a recipe for disaster. Ian |
#43
16 seconds is a long time to make an avoidance manuver.
raulb wrote: I am sure that Chip Gardner is thinking that it is deja vu all over again. He had a Navy jet (A-4? A-6?) eat 3 feet of his wingtip near Mt. Palomar about 20 years ago. Gardner managed to fy back and land at the gliderport at Hemet and the jet limped back to Miramar NAS with a fiberglass wingtip lodged in one of his engines. I remember at the time that Chip said that at the speeds they fly, we go from being a speck on the windshield to a full target in less than 16 seconds. |
#44
But quite a short time to make one turn in a thermal. Author: Jodom Date/Time: 12:10 31 August 2006 ------------------------------------------------------------ 16 seconds is a long time to make an avoidance manuver. raulb wrote: I remember at the time that Chip said that at the speeds they fly, we go from being a speck on the windshield to a full target in less than 16 seconds. ------------------------------------------------------------ |
#45
Euro experience from hang glide list
Bizjet collides with glider in Nevada Posted by: "Bart Doets" bart.doets@ Wed Aug 30, 2006 12:31 am (PST) ----- Original Message ----- From: "xcnick4" xcnick4@ The fear is that gliding will be considered unsafe without Mode S transponders and they will make us all buy these gismos. Great Britain is facing this realty right now. Who is next? Hang gliders? Paragliders? Geese? Dunno how this is going in the USA, but in Europe it has already been decided that HGs and PGs (and ULs etc.) must have mode S transponders. The only thing that has postponed the actual effectuation of the decision is, that there were no transponders on the market that would do the job working on battery power. Seems right now there are transponders in a range from 1350 to 2000 Euros ($1627-2410) that are supposed to work 4-5 hours. (Remember how the first useable GPS's would not work by far as long as they were supposed to?) I am a bit worried about the seemingly waiting mode that the European HG orgs are in. As far as I know only the British org has sort of called up its members, but it might be far too late anyway - the decision is cast years ago. The only thing that really might help us out is the marketing of a mode S transponder at a price of just a couple of hundred euros max, like the first GPS's that really hit big (Garmin 38). A couple of weeks ago, a colleague of mine took me on a flight in a motorglider, from Hilversum airfield in the centre of Holland. Hilversum is close to the edge of Schiphol(Amsterdam airport) CTR. My colleague told me: "This plane is equipped with a transponder, but following a request from Schiphol tower we keep it switched off most of the time. Seems all those tiny bleeps and bloops along the edge of their CTR are unnecessarily complicating their work." I'm really worried that the transponder obligation will effectively kill all but the most expensive non-motorized flying. To a glass glider it may only be a small raise in cost, but for many hanggliders it will be out of proportion. And... would it really help? Bart Doets Holland T o d d P a t t i s t wrote: Eric Greenwell wrote: Todd, I know you may not have intended it that way, but some people do take it that way, and that is one of the reasons/excuses I hear for not installing a transponder. I certainly did not intend it as a discouragement for installation of transponders, but it's a concern I've heard expressed too. I'd like to see the FAA make it legal for the transponder to be turned off in gliders to remove this excuse/concern. I consider anyone who buys a transponder and installs it, but turns it off when needed to save batteries, to be someone who is concerned about improving safety. That's why I called it a "good deed" but having a midair with it off is a scary possibility given the current FARs. -- T o d d P a t t i s t - "WH" Ventus C (Remove DONTSPAMME from address to email reply.) |
#46
Doug Haluza wrote: snoop wrote: snip The one item, I'm curious to hear about, if, this item, is on the Reno/Minden Jeppesen IFR charts. I know it's on the VFR sectionals, but is there a glider icon on the IFR charts in that region? Good point about getting the glider symbol on the IFR charts. Most jet jocks use these almost exclusively. The more we do to raise awareness the better. Another way to raise awareness of glider trafiic is to make Pireps. I try to do this at least once on every good soaring day, especially if there is wave. Report your aircraft type as simply a Glider (nobody else will know or care what make/model you are flying). You can just report clear and 50 mi visibility, or give detailed (and useful) info on cloud layers and winds aloft. Pireps get wide dissemination to pilots, ATC and dispatchers, so this is a good way to remind them that we are out there too. Glider pilots who also fly commercially will appreciate hearing your Pirep when they are working (try to make them as jealous as possible by reporting from the top of the climb!). You can give Pireps to Flight Watch on 122.0 MHz, or you can contact a FSS or ATC facility on a discrete frequency. Check the AIM for more info on Pireps. Another thing you can do is to get VFR flight following if you have a transponder. Again, just give your aircraft type as a Glider. This lets pilots and controllers in the section know we are out there. It also gets you a discrete transponder code. Most ATC sections filter out 1200 VFR codes, and only view aircraft with discrete codes. So in this case, even if the glider's transponder was on, there is no guarantee that the controller even saw it, much less gave a traffic warning--they are not required to warn IFR aircraft of VFR targets anyway. I know a lot of glider pilots like to stay out of the system. But out of sight is out of mind. Doug: Clearly my article in the July issue of SOARING on transponders fell shy of the mark I had hoped to hit as far as educating glider pilots regarding transponders. There are four symbols generated by ATC computers for transponder equipped aircraft. One: transponder, no encoder, non discrete, (like the basic VFR squwak of 1200.) Two: transponder and encoder, non discrete - again, like the basic VFR squwak of 1200. Three: transponder, no encoder, (dam few of these out there any more), discrete as in talking to ATC. and Four: transponder and encoder, discrete. That is talking to or about to talk to ATC. Each controller is required by virtue of the ATC handbook, (7110.65 and the management handbook 7110.3), to display ALL transponder equipped aircraft. What the controller does have the option to do is adjust the filter limits at his scope to exclude the encoded altitude of aircraft which are not in his assigned airspace. Had the transponder been turned on by the pilot involved in the mid-air, the jet would have seen the glider on it's TCAS, and ATC would have been issuing the glider as traffic to the jet. In the Reno area, most glider pilots are squawking an non discrete code which indicates to ATC that they are a glider. |
#47
jodom wrote:
16 seconds is a long time to make an avoidance manuver. Effective clearing is a lot harder than it looks. You might even be able to do a complete loop in 16 seconds in your aircraft, but that doesn't mean you can find the traffic in 16 sec., especially if there is more than one target to deal with, let alone avoid it safely. Sixteen seconds is not a long time to scan the inner surface of a globe whose diameter is measured in miles and from which threats are emerging at closing speeds of from 200 to 500 kts below 10,000' msl. Above that level you can raise potential closing speeds to nearly 600 kts, and still be below Class A. By the way, with a closing speed of only 300 kts, you have just 12 seconds to close from a mile out. The inner surface of a two-mile diameter globe cannot be fully scanned in less than 12 seconds, leaving you less than zero time to react and to maneuver to avoid. Think of how many aircraft you have seen and subsequently you took some evasive action (e.g., ten)-- now think of how many of those took no action to evade you (e.g., seven), presumably because they did not see you. In this example 70% of the other pilots were unaware of potential midair collisions. How does that apply to you? Could we assume that you were also unaware of 70% of potential traffic conflicts? No, because you are, of course, twice as effective as the average pilot. Therefore you only missed slightly more than one third of those potentially fatal conflicts. To what do we attribute your continued survival? The big-sky concept works, but not forever. Is today's flight your last? Could be, unless all of us get serious about the BIG PICTURE of traffic awareness and avoidance. Jack |
#48
Why would you spend $2K on a transponder, and not another $50 on a dedicated
battery so you can run it for the duration of your maximum flight? Mike Schumann "T o d d P a t t i s t" wrote in message ... Eric Greenwell wrote: Todd, I know you may not have intended it that way, but some people do take it that way, and that is one of the reasons/excuses I hear for not installing a transponder. I certainly did not intend it as a discouragement for installation of transponders, but it's a concern I've heard expressed too. I'd like to see the FAA make it legal for the transponder to be turned off in gliders to remove this excuse/concern. I consider anyone who buys a transponder and installs it, but turns it off when needed to save batteries, to be someone who is concerned about improving safety. That's why I called it a "good deed" but having a midair with it off is a scary possibility given the current FARs. -- T o d d P a t t i s t - "WH" Ventus C (Remove DONTSPAMME from address to email reply.) |
#49
Why would you spend $2K on a transponder, and not another $50 on a dedicated battery so you can run it for the duration of your maximum flight? Because, there may be no place to put it. In my case, I tried for several weeks to find two smaller batteries (preferred) or a single larger one that would fit in an available space, without eliminating much of the remaining luggage space, or resorting to a Sawzall. In the end, geometry won... |
#50
There's a huge variety of gell cell battery configurations. You couldn't
find anything that you could fit into your glider? Most of the gliders I have seen have tons of air around the battery box(es). Mike Schumann "Marc Ramsey" wrote in message ... Mike Schumann wrote: Why would you spend $2K on a transponder, and not another $50 on a dedicated battery so you can run it for the duration of your maximum flight? Because, there may be no place to put it. In my case, I tried for several weeks to find two smaller batteries (preferred) or a single larger one that would fit in an available space, without eliminating much of the remaining luggage space, or resorting to a Sawzall. In the end, geometry won... |
| Thread Tools | |
| Display Modes | |
| Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 05:40 AM |
| Minden Vote - Results | [email protected] | Soaring | 1 | November 20th 05 07:01 PM |
| Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 03:37 AM |
| Minden In Two Weeks | ADP | Soaring | 3 | August 10th 04 02:51 AM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
