G1000 vs Steam guages initial thoughts...
Old September 5th 06, 07:35 PM posted to rec.aviation.ifr
Robert M. Gary
Default G1000 vs Steam guages initial thoughts...
Jim Macklin wrote:
You're missing the point, the G1000 displays some much
information in picture form, the pilot WILL almost certainly
come to rely on the system to work and stop doing that
"basic IFR" thinking. Sort of like pilots forget to check
the runway heading. With steam gauges, the pilot is forced
to THINK about the navigation situation, with the G1000
thinking is done by the machine.
Fair enough, but what is the goal? Is the student "thinking" to second
guess the computer or is the student "thinking" in order to handle a
situation where both computers shut down? Second guessing the PFD is
not as necessary as old gauges because the computer shows a red X for
any fault (vs. the slow death roll of the old gauges). However, the
student still has 3 steam gauges to look at if he wishes (airspeed,
altimeter, attitude).
If the student is "thinking" in case the system shuts down, I think the
proper answer to that is always to carry a portable GPS when flying
IFR. The days of keep track of an emergency heading and time to head
towards an airport in IMC are probably gone. Flying against a portable
GPS is much safer. That applies equally to steam and glass. A full
electrical failure in my steam Mooney is much more likely than in the
glass so a 296 sits right on my yoke.
-Robert
  #42
Old September 9th 06, 01:07 AM posted to rec.aviation.ifr
Judah
"Jim Macklin" wrote in news:1_9Kg.6638
$SZ3.4096@dukeread04:
The same could pretty much be said for a plane with Steam Guages and any
modern full screen GPS...
  #43
Old September 9th 06, 07:20 AM posted to rec.aviation.ifr
Roger[_4_]
Yup and there are a *lot* of pilots who end up depending on the GPS
without realizing it. The same is true for a good autopilot in IFR
versus hand flying. If you spend a lot of time in the soup you spend
a lot of time on autopilot. Enough time that if it fails it can be a
shock. Still, the competent pilot practices hand flying in IFR,
flying by map, watch and compass, and flying the back up instruments.
I wonder what the percentages are of dependent pilots versus those who
stay competent on the backups?
www.rogerhalstead.com
  #44
Old September 9th 06, 08:59 AM posted to rec.aviation.ifr
Jim Macklin
"Roger" wrote in message
news | On Sat, 09 Sep 2006 00:07:38 GMT, Judah
| "Jim Macklin"
certainly
check
forced
Guages and any
on the GPS
autopilot in IFR
soup you spend
it can be a
in IFR,
instruments.
versus those who
  #45
Old September 9th 06, 09:00 AM posted to rec.aviation.ifr
Jim Macklin
Higher than it should be [zero percent], probably 20-30%
| "Jim Macklin"
certainly
check
forced
Guages and any
on the GPS
autopilot in IFR
soup you spend
it can be a
in IFR,
instruments.
versus those who
  #46
Old September 9th 06, 06:46 PM posted to rec.aviation.ifr
Robert M. Gary
Sure, and there is nothing wrong with that. Today most pilots would say
a moving map is MEL for serious IFR (more than just local approaches).
Sure you can fly IFR with a compass and a cat ala the 1930's but who
wants to do that. A handheld, self powered, back up moving map GPS
(296, etc) should be carried aboard any GA IFR flight.
-Robert, CFII
  #47
Old September 9th 06, 11:54 PM posted to rec.aviation.ifr
Judah
"Robert M. Gary" wrote in
oups.com:
news:1_9Kg.6638 $SZ3.4096@dukeread04:
any modern full screen GPS...
-Robert, CFII
I agree with you completely - there's nothing "macho" (or more safe, for that
matter) about not taking advantage of the equipment available to you, but it
is important to have a backup plan and be proficient enough to be able to
excercise the backup plan if an emergency comes up.
Admittedly, though, my backup GPS is not a 296, it's just a low-cost Magellan
with all the fixes as POIs - certainly enough to get by in an emergency in
combination with my ICOM A23. I also carry an extra set of AA batteries in
the flight bag...
  #48
Old September 11th 06, 05:35 PM posted to rec.aviation.ifr
Robert M. Gary
oups.com:
the flight bag...
For my backup's backup I installed PocketFMS on my PDA that is always
in my pocket and I keep a little CF GPS unit in my flight bag for it. I
travel down into Mexico a lot where there isn't much ATC or VORs. A
lose of my GPS would leave me with just my Loran (which doesn't have
good coverage in lower Baja). So I have my PDA. Even in a super
emergency I could use it to navigate over an airport or spiral down
through a layer just off shore.
The best part is that once I land I switch to MS Streets and Trips my
PDA because a street navigator.
-Robert
  #49
Old September 12th 06, 12:33 AM posted to rec.aviation.ifr
Judah
oups.com:
oups.com:
Magellan with all the fixes as POIs - certainly enough to get by in an
emergency in combination with my ICOM A23. I also carry an extra set of
AA batteries in the flight bag...
-Robert
Ooooh.. That's a VERY cool idea now that I got a Treo! I might have to look
into that... Certainly worth lightening my flight bag...
IPC G1000 [email protected] Instrument Flight Rules 38 September 3rd 06 12:22 AM
Steam guages [email protected] Instrument Flight Rules 14 February 5th 05 04:58 AM
