Is every touchdown a stall?
Old September 29th 06, 07:09 PM posted to rec.aviation.piloting
Mxsmanic
Default Is every touchdown a stall?
Listening to the radio transmissions of a VFR pilot who had a panic
attack in a cloud of IMC, I heard him mention to a controller that
"the stall horn goes off every time I land." I thought that was
bizarre. Is a touchdown supposed to be a stall? My stall horn
doesn't sound on landing.
When I first started landing in the sim (after it had advanced enough
to allow realistic landings), I sometimes stalled the aircraft (but
without an alarm). Later I came to the conclusion that this might not
be good. If the aircraft stalls, you lose control of it right above
the runway. You can't pitch down to pick up speed and restore lift,
and the engines cannot speed up quickly enough to pull you out of the
stall, either. Unless you are inches above the runway, you come
banging down onto it, and in my case I've collapsed the gear many
times this way. So I figured that stalling on landing might not be
the way to do.
These days I try to stay above stall speed throughout the landing,
even during the flare. The flare arrests my descent, but does not
stall the aircraft. I reduce throttle at the same time as the flare
so that I naturally tend to begin a gentle descent, and this seems to
set me down very nicely on the runway, although it takes longer this
way (but small aircraft usually don't need the whole runway, anyway).
And if anything goes wrong, I can power up and pull away without
delay, since I haven't stalled.
So, which is the preferred way to land, and why?
Old September 29th 06, 07:23 PM posted to rec.aviation.piloting
Ron Natalie
Mxsmanic wrote:
You know, you might go out and get a book on actual flying (like
Stick and Rudder by Langewiesche or Kirschner's Student Pilot Manual)
rather than basing your entire view of aerodynamics on how a game
behaves.
The stall horn goes off BEFORE the stall. That's it's whole point.
It's a stall WARNING horn.
I thought that was
Most light aircraft are touched down as close to a stall
as you can manage. The idea is to bring the nose up until
the lift peters out about the time the wheels touch.
My stall horn
You need a better simulator.
the runway.
Stalling is NOT lost of control. You certainly can control
an aircraft in a stall. If you couldn't you would never be
able to recover. A stall is the breakdown in lift that occurs
when the angle of attach exceeds a critical angle. The airplane
is still flying, controllable, and even producing some lift during
a stall.
That's the whole point. You need neither speed nor lift at this
point. The idea is to land with the minimum energy. The wheels
are on the ground so you don't need lift, and any excess speed you
have will just have to be bled off with the brakes. This means you
need more runway, which you might not have.
stall, either.
Engines do not pull you out of a stall. Speed does not pull you out
of a stall. Getting the angle of attack below the critical angle
gets you out of a stall.
the way to do.
It's a good thing you aren't flying real airplanes. But the trick
in learning how to really land is getting close to that.
Aircraft can stall at any speed.
Old September 29th 06, 07:47 PM posted to rec.aviation.piloting
Robert M. Gary
No, you are landing too fast. A stall is not lose of control. In a real
plane you would go up and do all kinds of stalls with your instructor
before you soloed.
-Robert, CFII
Old September 30th 06, 02:32 AM posted to rec.aviation.piloting
houstondan
it might help if you were to specify what kind of airplane you're
asking about but here i'll guess light single.
stall at landing?
sorta depends on what the wind is doing. in chop i'll probably hold
more speed till i can get a wheel down then unload flap to firm it up.
in decent air i usually get just a squeek at touchdown. honestly, i
don't really like the horn as i trained a lot without one and got more
used to testing the control authority as i went along. you should be
able to feel it getting mushy as you get close.
i remember one day in my training, in a plane with a working horn, in
chop; i knew that i had some time after the horn started so i kept
dicking with it and kept listening to the horn till finally, it broke
hard. i doubt i was 6-inches but man!
i'm also not fond of the fact that the horn sounds like farting thru a
cheap clarinet and scares the passengers.
dan
the way to do.
Old September 30th 06, 05:14 AM posted to rec.aviation.piloting
Mxsmanic
houstondan writes:
The ones in the sim, mainly Beechcraft Baron 58 and A36, and a
737-800. I don't know if the principles are different for the
different types of aircraft.
That's what I worry about.
I think it's designed to do that.
Old September 30th 06, 09:37 AM posted to rec.aviation.piloting
Greg Farris
The question of the landing being a stall just inches above the runway has
been debated for decades. I believe it would be fair to say that the
"every landing should be a stall" theory is old school, and more modern
training eschews this belief. This may also have something to do with
today's reality, where there is a high chance you will be trying to make
the best time possible on approach, without getting in everyone's way, so
you will not be on two-mile finals at 60Kt with full flaps. As a result,
it is likely you will cross the threshold with a comfortable margin above
your Vso.
As for the stall horn, as posted above, it is set to sound above the
actual stall AoA. After thousands of landings in small planes, both by
myself and with other pilots, I'd say I hear it about one in three or four
landings. If you have it while you're in the flare, close to the ground,
it's a gooid indication you're at about the right speed. If you don't have
it, but everything else looks good, than so what....
GF
Old September 30th 06, 09:27 AM posted to rec.aviation.piloting
cjcampbell
I gather you are using a toy flight simulator.
Okay, in a real airplane the stall warning horn does not go off every
time, either, but many pilots consider it the ideal. It means that you
are landing at the slowest possible speed. Or it at least is supposed
to.
My opinion, that of most manufacturers, and of many commercial pilots,
is that the stall warning horn is a very poor indicator of proper
landing speed. Cessna does not say in their operating handbooks to land
with the stall warning horn blaring. It does not say it on their
checklists. Cessna says to land at, say, 50 KIAS. No mention is made of
the stall warning horn except in the section on stalls. There. I said
it. I know it goes against the deepest heart of hearts of some people
here, including those I greatly respect or even admire, but there it
is. They are wrong. And we would have a lot fewer Cessnas and other
airplanes with broken tail cones if they would admit it. You would not
believe the number of tail strikes I have seen generated by these guys.
And I also think Langewische was wrong about some things. He was not
God. Some of the things he asserts in "Stick and Rudder" are downright
idiotic. Among other things, he advocates a "stall-proof" airplane,
which may not be possible and which certainly is not desirable. He
perpetuates certain myths about the cause of lift. I simply cannot
recommend this book for the student pilot, although it is a step above
"Junior Birdman" kits. Langewische should be used judiciously by flight
instructors who have a thorough grounding in the principles of flight,
if at all.
The ONLY time you should consider it absolutely necessary to land at
the slowest possible airspeed is when you are performing short field
landings. Higher airspeeds are helpful, and possibly even necessary, in
crosswinds, gusty conditions, soft field operations, or when you just
want an especially gentle landing and you have a long runway.
The best speed at which to land the airplane is the one recommended
(adjusted for local conditions) by the manufacturer, who presumably
knows something about the airplane's envelope. The manufacturer, after
all, designed the plane, did the engineering, and flew the
certification tests. The manufacturer knows what angle of attack will
cause you to bang the tail on the runway. The manufacturer knows what
rate of descent will smash the gear. The manufacturer knows what angle
of attack will lift the nose enough to keep you from banging the nose
wheel.
Old September 30th 06, 10:08 AM posted to rec.aviation.piloting
Mxsmanic
cjcampbell writes:
It's a program that simulates a toy plane (i.e., a Baron 58).
Well, then, I'm not so far off the mark.
idiotic.
I haven't been able to find his book yet, anyway. It may not be
findable in Paris.
Years ago I read of NASA having developed a stall-proof wing, but I
don't know what became of that, or if it ever was incorporated into an
aircraft.
He perpetuates certain myths about the cause of lift.
About the same time ago, I recall reading that NASA had found that the
standard theory of lift in an airfoil was incorrect (after they came
up with a wing that generated the same lift both in its normal
position and when flying inverted).
I simply cannot
if at all.
I've never heard of Junior Birdman kits.
That's kind of what I figured. With 11,000 feet of runway and only
3000 necessary to touchdown, what's the rush?
wheel.
I don't have the manual for a Baron 58, although the sim model manual
includes extracts from it.
Old September 30th 06, 01:05 PM posted to rec.aviation.piloting
Mxsmanic
Greg Farris writes:
Toy plane - Baron 58?
Yes. You see, real planes have jet engines, and carry 100 or more
passengers, and can fly above 30,000 feet. Anything else is a toy.
I think some real flying, in a real plane (try a C-152 for starters) would
be helpful in correcting your attitude problem.
A C152 is no more a real plane than a Baron 58.
Tamed by the Tailwheel [email protected] Piloting 84 January 18th 05 04:08 PM
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) Rich Stowell Piloting 25 September 11th 03 01:27 PM
Wing Extensions Jay Home Built 22 July 27th 03 12:23 PM
