#41
"Andrew Sarangan" wrote in message
ups.com... [...] This is rather surprising to me because it seems that runway slope is almost irrelevant to landing distance compared to the effects of wind. As I pointed out earlier, this makes perfect sense. Landing distance is a function of deceleration and of initial kinetic energy. Slope affects deceleration in a linear way, while wind affects the kinetic energy in an exponential way. Furthermore, the net effect of the wind is doubled when comparing headwind to tailwind operations. In the example I used, for a typical light airplane, a 10 knot wind produces a landing distance that is different by a factor of two, comparing headwind to tailwind. That is, it takes twice as much distance to come to a stop landing with a tailwind than landing with a headwind. It would take a pretty significant slope indeed to increase deceleration to the point that the landing distance was cut in half. Pete |
#42
"cjcampbell" wrote in message
oups.com... Actually, there was a reasonable mathematical treatment printed in one of the aviation magazines a couple years back. The upshot was that in anything less than a gale you should land uphill and take off downhill. And if it is a gale, maybe you should think about not flying. It takes an enormous amount of wind to overcome the effect of a sloping runway. This is a different conclusion to the emerging consensus here -- that slope really isn't that important and you should almost always take off into the wind. Do you have a reference? |
#43
Tony Cox wrote:
"cjcampbell" wrote in message oups.com... Actually, there was a reasonable mathematical treatment printed in one of the aviation magazines a couple years back. The upshot was that in anything less than a gale you should land uphill and take off downhill. And if it is a gale, maybe you should think about not flying. It takes an enormous amount of wind to overcome the effect of a sloping runway. This is a different conclusion to the emerging consensus here -- that slope really isn't that important and you should almost always take off into the wind. Do you have a reference? As Peter Duniho pointed out it makes intuitive sense that slope really isn't that important compared to wind. Slope affects the deceleration, while wind affects the touchdown speed. The rolling distance increases as the square of the speed, but only linearly with deceleration. One can do a more accurate modeling (as I did) but I think this explanation is enough to make a qualitative argument. Now I am curious about the mathematical analysis that is being referred to. |
#44
"Peter Duniho" wrote in message
... "Tony Cox" wrote in message oups.com... OK, if anyone is still following this thread with interest, I've just done the calculation myself and come up with Vbe = (s * d) / (7*V) You didn't post the derivation, so it's impossible for anyone to know whether you did it correctly or not. You're right. Do please have a look, since its important these things be done right. Analysis applies to take-off distance. v = velocity Vw = wind velocity Vt = take-off speed g = Acceleration due to gravity (32 ft/sec/sec) d = distance D = take-off distance for specific DA from POH on flat runway S = runway slope a = acceleration (assumed constant) A = Acceleration (assumed constant) during TO on flat runway v(t) = v0 + at (v0 start velocity, v(t) velocity at some arbitrary t) then distance travelled over time t will be d = Integral(0,t){ v(t).dt} = v0*t + a*t*t/2 So, if starting from rest, find d given final velocity and acceleration d = a*t*t/2 v = a*t so d = v**2 / (2*a) and in particular, if level and no wind D = Vt**2 / (2*A) or A = Vt**2 / (2*D) {Crosscheck my 182: Vt = 100ft/sec, D = 900ft, A=6.1ft/sec/sec, t to take-off = 17 secs. All seems reasonable} So lets compare uphill into headwind vs. downhill with tailwind. Uphill into headwind. The velocity we need to achieve is less -- only Vt - Vw -- but acceleration is less. Acceleration is A - sin( S) * (acceleration due to gravity), subtracting the component of "g" paralell to our take-off acceleration. Since S is small, sin(S) is approx S and so acceleration is A - gS. Downhill with tailwind The velocity we need to achieve is greater -- Vt + Vw -- but the acceleration is greater too. a = A + gS as we are accelerating downhill. Now, the cross-over point between TO in different directions is when the distance needed to take off is the same in each case. Greater headwind or lesser slope makes taking off uphill into a headwind the optimal & vice versa. This cross-over point is given when (Vt + Vw)**2 / (A + gS) = (Vt - Vw)**2 / (A - gS) or (Vt + Vw)**2 / (Vt**2/(2*D) +gS) = (Vt - Vw)**2 / ( Vt**2/(2*D) - gS) which reduces to Vt**3 * Vw / D = (Vt**2 + Vw**2) * g * S or Vt * Vw = gDS * ( 1 + (Vw**2/Vt**2)) in limit where Vw Vt Vw = gDS / Vt Converting from to ft/sec and "slope" to degrees & substituting for g Vw = 32*D*S / (57 * 3 * Vt) = D * S / ( 5 * Vt) (Looks like Sparky's formular is right -- I'd done the unit conversion improperly in the last step in my result above). which is pretty much the same. For Vbe = V/2 it underestimates by around 25%, being only truely accurate when Vbe V. No idea what Sparky's assumptions were, but for mine, I assumed that the acceleration during take-off is constant, which seems reasonable with a constant speed prop and ignoring the deceleration caused by the increase in parasitic drag with velocity (which is assumed to be much less that the acceleration the engine is giving). They seem like reasonable assumptions. Parasitic drag only starts to get really dramatic at L/D max speed, as induced drag falls off, so drag during the takeoff run (when both induced and parasitic are minimal) seems ignorable for the purpose of a rule of thumb. Note that this isn't really what I was expecting -- I'd have thought that wind would be more important. For my 182 on a 2degree grade on a hot summer day, I should take off downhill only if the tailwind is less than 4 knots. Otherwise, its best to take off uphill and into the wind. I'd really thought the break-even point ought to be higher! I don't understand what you mean. The lower the break-even point based on wind speed, the more important wind is. Expecting the break-even point to be higher implies that you expected wind to be less important, not more. I meant, but I wasn't clear, that I'd have expected the break event point to occur with a higher wind. Before doing this calculation, I'd have expected, for conditions mentioned, to have around 10-12 knots before switching runways, not 6. Part was influenced by Sparky's assertion that one should always take off downhill unless wind speed is 15 knots or greater. It would seem that this is dangerous nonsense, unless the grade is really excessive (6% or higher). Now for *landing*, the calculation is likely to be more involved. For a start, the deceleration profile is more complex. One has the parasitic drag (proportional to square of airspeed), and the deceleration due to brakes (which, when maximally applied, are proportional to the weight of the plane as it is transferred from the wings to the wheels). The former isn't by any means negligible. The latter depends highly upon pilot technique (how fast you can get the nose down) and runway surface. IMHO, the former is just as negligible during landing as it is during takeoff, assuming you are landing at a typical near-stall airspeed, and for the same reasons. Except that were it negligible, one would never be able to land! I agree that braking depends on pilot technique, but assuming you get the nosewheel down, the AoA is too low for the wings to be making a lot of lift. If you don't get the nosewheel down, then you've got induced drag helping to slow the airplane, offsetting the reduced brake performance. For most of the rollout, the weight on the ground is less than total weight, I agree...but again, for the purpose of a rule of thumb I think it's ignorable. Pete |
#45
oups.com... You're right. Do please have a look, since its important these things be done right. Analysis applies to take-off distance. Note: frankly, I don't consider myself entirely qualified to check your work. I simply meant that someone should. ![]() require some period of time without distractions, and a clear head, both of which are in short supply for me right now (I've been fighting off a somewhat tenacious cold, and even on a good day my environment is filled with outside interruptions). Indeed, if I had the ability to do a truly fair review, I think I'd be able to do the derivation myself. ![]() Anyway, that said I have some questions (which may indeed expose my lack of qualification ![]() then distance travelled over time t will be d = Integral(0,t){ v(t).dt} = v0*t + a*t*t/2 This part I agree with. So, if starting from rest, find d given final velocity and acceleration d = a*t*t/2 v = a*t As long as you restrict "d" and "v" to mean "d at time t" and "v at time t", I'll agree with this. so d = v**2 / (2*a) This part, I don't get. Using the two equations you provide previously, I get "d = v*t/2", which is consistent with my distant recollection of basic high school physics. That is, the final distance traveled accelerating from zero is half the distance one would travel had they been at the final speed the whole time. I don't see where you managed to make distance proportional to the square of the final speed, nor do I understand why it is that your final calculation for "d" no longer takes into account the time during the takeoff. I get some feeling that maybe this has to do with factoring "t" out of the equation, but I'm not sure about that, nor am I clear on why you'd want to (since it seems to me that later derivations would be easier with the simpler formula of "v*t/2"...if it's valid to remove "t" at this point, then it will just cancel out later in the other derivations anyway). and in particular, if level and no wind D = Vt**2 / (2*A) or A = Vt**2 / (2*D) {Crosscheck my 182: Vt = 100ft/sec, D = 900ft, A=6.1ft/sec/sec, t to take-off = 17 secs. All seems reasonable} How are you doing the cross-check? Are you calculating A from the second equation, or from the POH numbers? If from the second equation, I don't see how that's useful for checking the equation, and if from the POH numbers, I don't find that the equations check out. If I assume Vt as 100fps (or 101-1/3 fps, assuming 60 knot takeoff speed), and use 6.1 fps^2 as given for the accleration, I get 820 feet, rather than 900 feet for the takeoff distance. That's a pretty significant error, IMHO. I can do a variety of other calculations, making different assumptions regarding what numbers you've derived and what numbers you've pulled from the POH, and in each case I don't find the numbers consistent. So, perhaps you could be more explicit about what numbers you're taking from the POH, and how you apply those to do your cross-check. (Of course, as I mentioned, I'm not clear on how you got these equations in the first place...if they are incorrectly derived, then the cross-check here is obviously moot ![]() [...] Vw = gDS / Vt Converting from to ft/sec and "slope" to degrees & substituting for g Vw = 32*D*S / (57 * 3 * Vt) I've glossed over the actual derivation. I figure if I'm mistaken about the simpler reduction of the integral, I can't really expect to correctly check the break-even derivation. (And of course, if I'm not, the break-even derivation is moot, even if done correctly). I believe that the unit conversions are done correctly. You glossed over some steps, but in the end I come up with a similar number as you...in fact, the final denominator constant comes out closer to 5 using more precise conversions. So at this point, my intuition tells me that you've done the derivation correctly, but that you made it harder on yourself than was necessary. ![]() I also looked back on a previous comment I made about the intuitive nature of having the takeoff speed in the denominator, and I still am having trouble with that. This is relevant somewhat to this: Note that this isn't really what I was expecting -- I'd have thought that wind would be more important. For my 182 on a 2degree grade on a hot summer day, I should take off downhill only if the tailwind is less than 4 knots. Otherwise, its best to take off uphill and into the wind. I'd really thought the break-even point ought to be higher! I don't understand what you mean. The lower the break-even point based on wind speed, the more important wind is. Expecting the break-even point to be higher implies that you expected wind to be less important, not more. I meant, but I wasn't clear, that I'd have expected the break event point to occur with a higher wind. Before doing this calculation, I'd have expected, for conditions mentioned, to have around 10-12 knots before switching runways, not 6. IMHO, your original terminology was indeed unclear. ![]() break-even point is IMHO suggesting that wind is LESS important, not more. The more important something is, the less of it you need in order to make a difference. ![]() Which is why I still don't see how increasing the takeoff speed should cause the break-even point for the wind to go down as it does in this formula. Intuitively, it seems to me that as takeoff speed goes up, the influence of the wind on the takeoff performance goes down, and so the wind should be LESS important, meaning you need MORE of it before you need to takeoff into the wind rather than with it, not less of it. I'm wondering if this intuition is incorrect based on other aspects of the formula. That is, if derived correctly, the formula accounts not only for wind but also for acceleration performance. And perhaps the higher the takeoff speed, the more significant the acceleration performance is, and thus the slope factors in more heavily. That is, even as wind becomes less influential, for some reason the acceleration becomes even more so. This is all hand-waving, and I haven't convinced myself that it makes any sense. Still, it's the best I can come up with. ![]() [...] One has the parasitic drag (proportional to square of airspeed), and the deceleration due to brakes (which, when maximally applied, are proportional to the weight of the plane as it is transferred from the wings to the wheels). The former isn't by any means negligible. The latter depends highly upon pilot technique (how fast you can get the nose down) and runway surface. IMHO, the former is just as negligible during landing as it is during takeoff, assuming you are landing at a typical near-stall airspeed, and for the same reasons. Except that were it negligible, one would never be able to land! I disagree. It seems like you are asserting that if parasitic drag is negligible to the calculation, one couldn't slow down to land. But that ignores induced drag, which dominates at landing speeds (at the same time that parasitic drag does indeed become a negligible factor). I don't see any reason to think that for the purpose of an approximation, one cannot simply ignore parasitic drag. The formula you've derived ignores all sorts of similarly measurable-but-insignificant things, and I don't see the idea of ignoring parasitic drag any different. Pete |
#46
... "Tony Cox" wrote in message oups.com... You're right. Do please have a look, since its important these things be done right. Analysis applies to take-off distance. Note: frankly, I don't consider myself entirely qualified to check your work. I simply meant that someone should. ![]() require some period of time without distractions, and a clear head, both of which are in short supply for me right now (I've been fighting off a somewhat tenacious cold, and even on a good day my environment is filled with outside interruptions). Indeed, if I had the ability to do a truly fair review, I think I'd be able to do the derivation myself. ![]() No matter. I'm not submitting a "homework assignment" ! Its just that since this challenges "conventional" wisdom (Sparky's & at least one poster here) someone ought to look at it! It seems on the face of it that Sparky Imeson is dispensing dangerous snake oil by claiming that runway slope is by far the most significant -- its not, at least according to this calculation. Anyway, that said I have some questions (which may indeed expose my lack of qualification ![]() then distance travelled over time t will be d = Integral(0,t){ v(t).dt} = v0*t + a*t*t/2 This part I agree with. So, if starting from rest, find d given final velocity and acceleration d = a*t*t/2 v = a*t As long as you restrict "d" and "v" to mean "d at time t" and "v at time t", I'll agree with this. I think that was clear in the key, but you're right in your analysis. so d = v**2 / (2*a) This part, I don't get. Using the two equations you provide previously, I get "d = v*t/2", which is consistent with my distant recollection of basic high school physics. Look at it this way... d = a*t*t/2 = a*t*a*t/(2*a) = v*v/(2*a) That is, the final distance traveled accelerating from zero is half the distance one would travel had they been at the final speed the whole time. I don't see where you managed to make distance proportional to the square of the final speed, nor do I understand why it is that your final calculation for "d" no longer takes into account the time during the takeoff. I get some feeling that maybe this has to do with factoring "t" out of the equation, but I'm not sure about that, nor am I clear on why you'd want to (since it seems to me that later derivations would be easier with the simpler formula of "v*t/2"...if it's valid to remove "t" at this point, then it will just cancel out later in the other derivations anyway). I've factored it out. The POH doesn't give you "time for takeoff" but it *does* give you Vt and D. and in particular, if level and no wind D = Vt**2 / (2*A) or A = Vt**2 / (2*D) {Crosscheck my 182: Vt = 100ft/sec, D = 900ft, A=6.1ft/sec/sec, t to take-off = 17 secs. All seems reasonable} How are you doing the cross-check? Are you calculating A from the second equation, or from the POH numbers? If from the second equation, I don't see how that's useful for checking the equation, and if from the POH numbers, I don't find that the equations check out. Its just a consistency check to see if things are reasonable. D and Vt come from the POH, and A = g/5 is about what I feel when I push the throttle in. If I assume Vt as 100fps (or 101-1/3 fps, assuming 60 knot takeoff speed), and use 6.1 fps^2 as given for the accleration, I get 820 feet, rather than 900 feet for the takeoff distance. That's a pretty significant error, IMHO. Well, it was just a rough check. If A had turned out to be 3g or something outragous, then we'd know something was up. I can do a variety of other calculations, making different assumptions regarding what numbers you've derived and what numbers you've pulled from the POH, and in each case I don't find the numbers consistent. So, perhaps you could be more explicit about what numbers you're taking from the POH, and how you apply those to do your cross-check. (Of course, as I mentioned, I'm not clear on how you got these equations in the first place...if they are incorrectly derived, then the cross-check here is obviously moot ![]() [...] Vw = gDS / Vt Converting from to ft/sec and "slope" to degrees & substituting for g Vw = 32*D*S / (57 * 3 * Vt) I've glossed over the actual derivation. I figure if I'm mistaken about the simpler reduction of the integral, I can't really expect to correctly check the break-even derivation. (And of course, if I'm not, the break-even derivation is moot, even if done correctly). I believe that the unit conversions are done correctly. You glossed over some steps, but in the end I come up with a similar number as you...in fact, the final denominator constant comes out closer to 5 using more precise conversions. Thats good . I think it is right, and that's what Sparky claims anyway (even if it is only in the early revisions of the MFB) So at this point, my intuition tells me that you've done the derivation correctly, but that you made it harder on yourself than was necessary. ![]() Simplifications gladly accepted. I can't see an easier way. I also looked back on a previous comment I made about the intuitive nature of having the takeoff speed in the denominator, and I still am having trouble with that. This is relevant somewhat to this: Note that this isn't really what I was expecting -- I'd have thought that wind would be more important. For my 182 on a 2degree grade on a hot summer day, I should take off downhill only if the tailwind is less than 4 knots. Otherwise, its best to take off uphill and into the wind. I'd really thought the break-even point ought to be higher! I don't understand what you mean. The lower the break-even point based on wind speed, the more important wind is. Expecting the break-even point to be higher implies that you expected wind to be less important, not more. I meant, but I wasn't clear, that I'd have expected the break event point to occur with a higher wind. Before doing this calculation, I'd have expected, for conditions mentioned, to have around 10-12 knots before switching runways, not 6. IMHO, your original terminology was indeed unclear. ![]() higher break-even point is IMHO suggesting that wind is LESS important, not more. The more important something is, the less of it you need in order to make a difference. ![]() Which is why I still don't see how increasing the takeoff speed should cause the break-even point for the wind to go down as it does in this formula. Remember, its increasing TO speed *with the TO distance constant*. It means the energy gained/lost by going downhill/uphill is the same, but the effect of wind is less significant because you're accelerating more quickly through the range where windspeed *would* be significant. |
#47
oups.com... [...] d = v**2 / (2*a) This part, I don't get. Using the two equations you provide previously, I get "d = v*t/2", which is consistent with my distant recollection of basic high school physics. Look at it this way... d = a*t*t/2 = a*t*a*t/(2*a) = v*v/(2*a) Okay...not sure why I didn't see that earlier, since I had a suspicion that's what you had done. Still, I don't see the value in writing it that way. Probably if I had bothered to actually do the derivation, I'd understand. If I had to guess, I'd say it has something to do with keeping acceleration in the equation so you can include the gravity adjustment for the slope. But with "t" in the equation, I'd think you could do that as well, and with a slightly simpler starting equation. Oh well...doesn't really matter. In algebra, the whole point is that everything comes out the same, no matter how you "phrase the question". ![]() And since I'm too lazy to bother with redoing the derivation starting with the alternative equation, I don't have any business questioning which version is easier. [...] Remember, its increasing TO speed *with the TO distance constant*. It means the energy gained/lost by going downhill/uphill is the same, but the effect of wind is less significant because you're accelerating more quickly through the range where windspeed *would* be significant. Ahh, right. Thanks. I knew I must be missing something. I guess that does stand to reason, that an airplane with better thrust spends less time arguing with the wind. ![]() Okay...well, looks like Sparky's formula is right, and all his other advice is off-base. Good to know. ![]() Pete |
#48
Andrew Sarangan wrote:
Tony Cox wrote: "Andrew Sarangan" wrote in message oups.com... For a 2200 lb airplane with a normal landing distance of 1000 ft, landing speed of 50 knots, a 10 knot wind is equivalent to a downslope of 0.07-deg. In other words, you can land in 1000 ft if the downslope is 0.07-deg with a 10-knot headwind. A 20-knot wind is equivalent to 0.12-deg downslope. If you land on a 0.2-deg downslope with no wind, you will need 2000 ft of runway. That doesn't seem right to me. How much headwind do you need to land in the normal distance if the slope is 2 degrees when you need 20 knots for 0.12 degrees? You are correct, I had a typo when I computed the equations in Excel. The correct answer is a 10-knot wind is equivalent to 4-deg slope. 20-knot wind is equivalent to 8-deg slope. So it seems each knot is worth 0.4-deg of runway slope. Which, I should say, is pretty much in agreement with my analysis. A 2-degree slope is equivalent to 6 knots. This is rather surprising to me because it seems that runway slope is almost irrelevant to landing distance compared to the effects of wind. To me as well. This has been an interesting thread. |
Why not to land downwind | [email protected] | Piloting | 23 | September 6th 06 03:01 PM |
Cuban Missle Crisis - Ron Knott | Greasy Rider© @invalid.com | Naval Aviation | 0 | June 2nd 05 09:14 PM |
Pilot deviations and a new FAA reality | Chip Jones | Piloting | 125 | October 15th 04 07:42 PM |
Diamond DA-40 with G-1000 pirep | C J Campbell | Instrument Flight Rules | 117 | July 22nd 04 05:40 PM |
Off topic - Landing of a B-17 | Ghost | Home Built | 2 | October 28th 03 04:35 PM |
