![]() wrote in message ... Ah... Well... I just through some random numbers in there... Of course, one would not try and pull a 57G turn as cool as it sounds... Thanks for the lesson! I learned something new today... The calculator is correct by my reckoning. 80mph and 89 degree bank gives 8 ft radius turning circle which is correct in theory. it sounds ridiculous but really the 89 degree angle of bank is what is ridiculous .. such a turn if possible would pull 57 g. the calculation is not that difficult. radius= v squared / g tan ( bank angle) terry I should add that this calulation assumes all the lift is coming from the wing , but that theory would imply that an aircraft cant hold altitude in a 90 degree bank, and of course we have all seen aerobatic aircraft do this. For this to occur the lift must be coming from the fuselage of the aircraft and so the equation will not be strictly correct. But for the type of turns that mere mortals like me will do I think it tells the story. I have heard guys on this group regulary mention 60 degree or 2 g turns, but in my training steep turns were 45 degrees maximum. terry |
There's an NTSB update about Lidle's crash:
http://www.ntsb.gov/pressrel/2006/061103.htm. Unsurprisingly, they conclude that the plane didn't bank enough for the turn. --Gary |
Gary Drescher wrote:
Unsurprisingly, they conclude that the plane didn't bank enough for the turn. Duhhh! Kind of the definition of a too wide turn, isn't it? |
Grumman-581 wrote:
Gary Drescher wrote: Unsurprisingly, they conclude that the plane didn't bank enough for the turn. Duhhh! Kind of the definition of a too wide turn, isn't it? Or they did not roll out of the bank soon enough. Busting airspace (go AROUND the building) or violating altitude above a populated area is far better than what they did. Ron Lee |
Ron Lee wrote:
Or they did not roll out of the bank soon enough. Busting airspace (go AROUND the building) or violating altitude above a populated area is far better than what they did. Oh, I think that if they were still around, they would agree that just about *anything* is better than what they did do... sick-grin |
On Sat, 04 Nov 2006 20:54:26 +0000, Grumman-581 wrote:
Oh, I think that if they were still around, they would agree that just about *anything* is better than what they did do Indeed. I was at a dinner last night where someone asked me whether or not those flying that airplane had made a mistake. - Andrew |
Ron Lee wrote:
Grumman-581 wrote: Gary Drescher wrote: Unsurprisingly, they conclude that the plane didn't bank enough for the turn. Duhhh! Kind of the definition of a too wide turn, isn't it? Or they did not roll out of the bank soon enough. Busting airspace (go AROUND the building) or violating altitude above a populated area is far better than what they did. Ron Lee If they were in a steep bank and high AOA, I wonder if they could even see the building over the nose? Matt |
It would have been high in the windshield, the roof would
have blocked it until the last 1/2 of the turn. But I doubt they were experienced acro pilots trained to look out all of the windows. They also probably did not bank even 45°, let alone the 53-55° they needed to complete the turn. They didn't plan the turn well, where they needed to be when they started or what they would have done if the weather or other traffic had blocked them, had they been prepared to call for a Class B clearance, in other words the CFI screwed up because he did not plan ahead, Casey Lidle screwed up because he didn't act like the PIC, they both screwed up because they expected the other pilot "did the planning" so two dead pilots for no good reason. "Matt Whiting" wrote in message ... | Ron Lee wrote: | | Grumman-581 wrote: | | | Gary Drescher wrote: | | Unsurprisingly, they conclude that the plane didn't bank enough for the | turn. | | Duhhh! | | Kind of the definition of a too wide turn, isn't it? | | | Or they did not roll out of the bank soon enough. Busting airspace | (go AROUND the building) or violating altitude above a populated area | is far better than what they did. | | Ron Lee | | If they were in a steep bank and high AOA, I wonder if they could even | see the building over the nose? | | Matt |
"Grumman-581" wrote in message
... Gary Drescher wrote: Unsurprisingly, they conclude that the plane didn't bank enough for the turn. Duhhh! Kind of the definition of a too wide turn, isn't it? Kind of the definition of 'unsurprisingly', too. |
There's an NTSB update about Lidle's crash: http://www.ntsb.gov/pressrel/2006/061103.htm. Unsurprisingly, they conclude that the plane didn't bank enough for the turn. --Gary I'm a little surprised there seems to be no mention of reducing speed before beginning the turn as something to be learned from this accident. Do pilots flying this corridor use this technique? -- Frank....H |
Second Helicopter Crash into the East River | Bob Chilcoat | Piloting | 2 | June 21st 05 08:50 AM |
No US soldier should have 2 die for Israel 4 oil | Ewe n0 who | Military Aviation | 1 | April 9th 04 11:25 PM |
No US soldier should have 2 die for Israel 4 oil | Ewe n0 who | Naval Aviation | 0 | April 7th 04 07:31 PM |
Coordinated turning stall and spins | Chris OCallaghan | Soaring | 20 | November 18th 03 08:46 PM |
How I got to Oshkosh (long) | Doug | Owning | 2 | August 18th 03 12:05 AM |
