Another SR22
Old October 27th 06, 09:25 AM posted to rec.aviation.piloting
Stefan
Default Another SR22
Thomas Borchert schrieb:
Oh, I'm sure there is. It's just that the chute by itself doesn't make
the plane safer, as the quoted marketing blurb alluded.
Actually, it does. At least, I tend to believe so, after having lost
three friends in midairs (two events).
Stefan
  #42
Old October 27th 06, 01:51 PM posted to rec.aviation.piloting
Dave Stadt
"Thomas Borchert" wrote in message
Dave,
The size of the Cirrus fleet isn't even a flea on an elephant compared to
the Cessna fleet.
You're comparing apples and oranges. Try again with new Cessnas (since
1996
or whenever they started building their antiques again) and Cirruses.
Thomas Borchert (EDDH)
It's not me comparing apples to oranges it's those comparing Cessna
accidents to Cirrus accidents forgetting the Cessna fleet is near infinite
compared to the Cirrus fleet.
  #43
Old October 27th 06, 01:57 PM posted to rec.aviation.piloting
Thomas Borchert
Stefan,
Actually, that's the one situation the chute hasn't proven itself in
yet. Nobody knows if it will even work after your average mid-air. But
it's a hope, for sure. Still requires the pilot to pull, too.
  #44
Old October 27th 06, 02:36 PM posted to rec.aviation.piloting
Gig 601XL Builder
"Larry Dighera" wrote in message
On Thu, 26 Oct 2006 16:56:50 -0500, "Gig 601XL Builder"
wrDOTgiaconaATcox.net wrote in :
Does the POH mention when it may be appropriate to deploy the 'chute?
I thought it was for use in spin recovery.
From the manual
[excerpt deleted]
Thank you.
What does the POH say about CAPS deployment for spin recovery?
You know Larry the URL for the manual was in the upstream post but since I
downloaded the whole book.
Spins
The SR22 is not approved for spins, and has not been tested or
certified for spin recovery characteristics. The only approved and
demonstrated method of spin recovery is activation of the Cirrus
Airframe Parachute System (See CAPS Deployment, this section).
Because of this, if the aircraft "departs controlled flight," the CAPS
must be deployed.
While the stall characteristics of the SR22 make accidental entry into a
spin extremely unlikely, it is possible. Spin entry can be avoided by
using good airmanship: coordinated use of controls in turns, proper
airspeed control following the recommendations of this Handbook, and
never abusing the flight controls with accelerated inputs when close to
the stall (see Stalls, Section 4).
If, at the stall, the controls are misapplied and abused accelerated
inputs are made to the elevator, rudder and/or ailerons, an abrupt wing
drop may be felt and a spiral or spin may be entered. In some cases it
may be difficult to determine if the aircraft has entered a spiral or the
beginning of a spin.
.. WARNING .
In all cases, if the aircraft enters an unusual attitude from
which recovery is not expected before ground impact,
immediate deployment of the CAPS is required.
The minimum demonstrated altitude loss for a CAPS
deployment from a one-turn spin is 920 feet. Activation at
higher altitudes provides enhanced safety margins for
parachute recoveries. Do not waste time and altitude trying to
recover from a spiral/spin before activating CAPS.
Inadvertent Spin Entry
1.
CAPS.............................................. ...................................
Activate
  #45
Old October 27th 06, 02:55 PM posted to rec.aviation.piloting
Larry Dighera
On Fri, 27 Oct 2006 08:36:26 -0500, "Gig 601XL Builder"
From the manual
[excerpt deleted]
Thank you.
Thank you for the information.
Spins
must be deployed.
. WARNING .
That seems to confirm, that the CAPS was required to the meet spin
recovery requirements for FAA certification of the SR22.
But if the aircraft is below 1,000', the CAPS system is probably not
an option.
Thank you again for providing the SR22 POH quotes.
  #46
Old October 27th 06, 03:06 PM posted to rec.aviation.piloting
Thomas Borchert
Larry,
an option.
IF you are in a fully developed spin (1 full turn, as certification
requires and the handbook says), traditional spin recovery isn't an
option either at 1000 feet. There is a limit to altitude loss during
recovery to meet certification. The chute obviously qualifies.
  #47
Old October 27th 06, 03:33 PM posted to rec.aviation.piloting
Kingfish
No argument there, it really is apples & oranges. My point in making
the Piper and Cessna comparison is that the Cirruses (Cirri?) aren't
crashing any more often than other makes, it just seems that way
because of heightened interested in the type, (especially after the NYC
crash) thereby an accident involving a Cirrus stands out more. Maybe
it's a perception thing? With Cirrus cranking out so many planes now,
and surpassing Cessna in piston single sales/production, I'd expect
we'll hear of more accidents simply due to the rapidly expanding fleet.
I don't think it's an indictment of the safety of Cirrus aircraft,
though.
  #48
Old October 27th 06, 03:38 PM posted to rec.aviation.piloting
Matt Barrow
"Gig 601XL Builder" wrDOTgiaconaATcox.net wrote in message
While that has happened there have also been cases where non-pilots were
talked down when the exact same thing happened to the pilot. The
difference being that the plane was flyable again when landed without a
chute.
Airsafety had a report earlier this year of a non-pilot landing a Twin
Commander but the link is broken.
http://www.airsafety.com/reports/ROW060215A.pdf
http://www.ntsb.gov/ntsb/brief.asp?e...10X00588&key=1
  #49
Old October 27th 06, 03:46 PM posted to rec.aviation.piloting
Larry Dighera
On Fri, 27 Oct 2006 16:06:45 +0200, Thomas Borchert
wrote in
Larry,
an option.
Obviously.
However, if you have, for example, an engine failure at 400' on
departure, the CAPS is not an option.
My point is, that CAPS is not an option at the times it's needed most:
below 920'. So to characterize the SR22 CAPS as a safety enhancement
(for other than spin recovery, and possibly a MAC, structural failure,
loss of control, and landing in inhospitable terrain, *if* they occur
above 920') is inappropriate. (And CAPS use for recovery in the event
of pilot incapacitation is a judgment call specific to the incident.)
Personally, I would characterize the SR22 CAPS solely as a
certification requirement for spin recovery, with limited utility in a
few other emergency situations, and certainly not as a "panic-button"
capable of rescuing the flight from all perils.
  #50
Old October 27th 06, 04:18 PM posted to rec.aviation.piloting
Thomas Borchert
Larry,
How do you arrive at that conclusion?
below 920'.
That's not what your own quote says. It says it is not an option if you
arrive at less than 920 feet after one full turn in a spin.
Well, the people saved by it in different circumstances would probably
beg to differ.
Trip report: Cirrus SR-22 demo flight Jose Piloting 13 September 22nd 06 11:08 PM
Wing Loadings (was SR22 discussion) john smith Piloting 8 June 23rd 06 11:41 PM
SR22 Spin Recovery gwengler Piloting 9 September 24th 04 07:31 AM
Cirrus SR22 Purchase advice needed. Dennis Owning 170 May 19th 04 04:44 PM
New Cirrus SR22 Lead Time Lenny Sawyer Owning 4 March 6th 04 09:22 AM
