That's wrong, too. Flying at minimum sink will get you the longest time in
the air-like you'd want if you had a tailwind and needed the distance. Minimum sink is slower than best glide. mike ----- Original Message ----- From: "Dave Doe" Newsgroups: rec.aviation.piloting Sent: Thursday, November 02, 2006 4:02 AM Subject: How to tell my instructor to increase glidespeed with headwind? Yes, the greatest *distance* - if you *need* it. Otherwise, I think he's right - fly at 65kts, and you get the longest time in the air (something you're short of usually, when the fan dies). But yep, you're right, *if* you need to get the distance to make the field. -- Duncan |
To prove the point to your instructor.
Ask him/her to consider a headwind of 65kts. What are the chances of reaching the field with a GS=0 ?? What are the chances if GS0 ?? "Nik" wrote in message ups.com... Ok, my instructor did a simulated engine failure in the pattern; winds were around 20kts in the air and 13kts on the ground. Did everything perfectly; however after we took off again, he told me to maintain 65 kts next time, and I totally disagreed. The manual says 65 kts for best glide speed; however that is in calm air. As a glider person, I know adding about 1/2 the headwind component will give the greatest distance. After the flight I pulled up the Glider Flying handbook online and it says: "...it is apparent that flying a faster airspeed as the headwind increases will result in the greatest distance over the ground. If this is done for the polar curves from many gliders, a general rule of thumb is found, namely, add half the headwind component to the best L/D for the maximum distance." But even after telling him that he said that doesn't apply to power planes, also saying that manuals never give best glide, and there has to be a reason for that. Do you guys have any ideas on how I can really convince him? Any good sources? Thanks! -Nik |
Ask him if 65kts is the best glide speed to get to the airport into a
65kt head wind. I myself would use at least 90 as I am sure you would as well. Brian CFIIG/ASEL Nik wrote: Ok, my instructor did a simulated engine failure in the pattern; winds were around 20kts in the air and 13kts on the ground. Did everything perfectly; however after we took off again, he told me to maintain 65 kts next time, and I totally disagreed. The manual says 65 kts for best glide speed; however that is in calm air. As a glider person, I know adding about 1/2 the headwind component will give the greatest distance. After the flight I pulled up the Glider Flying handbook online and it says: "...it is apparent that flying a faster airspeed as the headwind increases will result in the greatest distance over the ground. If this is done for the polar curves from many gliders, a general rule of thumb is found, namely, add half the headwind component to the best L/D for the maximum distance." But even after telling him that he said that doesn't apply to power planes, also saying that manuals never give best glide, and there has to be a reason for that. Do you guys have any ideas on how I can really convince him? Any good sources? Thanks! -Nik |
![]() "Nik" wrote in message ups.com... Ok, my instructor did a simulated engine failure in the pattern; winds were around 20kts in the air and 13kts on the ground. Did everything perfectly; however after we took off again, he told me to maintain 65 kts next time, and I totally disagreed. The manual says 65 kts for best glide speed; however that is in calm air. As a glider person, I know adding about 1/2 the headwind component will give the greatest distance. After the flight I pulled up the Glider Flying handbook online and it says: "...it is apparent that flying a faster airspeed as the headwind increases will result in the greatest distance over the ground. If this is done for the polar curves from many gliders, a general rule of thumb is found, namely, add half the headwind component to the best L/D for the maximum distance." But even after telling him that he said that doesn't apply to power planes, also saying that manuals never give best glide, and there has to be a reason for that. Do you guys have any ideas on how I can really convince him? Any good sources? Thanks! -Nik Give your instructor the benefit of your background. As an instructor for thirty years, I can say that i have learned a lot from my students. Some of them had Mach 2+ experience and I was to solo them in a C-150. Bet him a beer that you can outglide him under those circumstances. Get him an introductory ride at a glider port... Al G |
![]() "Nik" wrote in message ups.com... Ok, my instructor did a simulated engine failure in the pattern; winds were around 20kts in the air and 13kts on the ground. Did everything perfectly; however after we took off again, he told me to maintain 65 kts next time, and I totally disagreed. The manual says 65 kts for best glide speed; however that is in calm air. As a glider person, I know adding about 1/2 the headwind component will give the greatest distance. After the flight I pulled up the Glider Flying handbook online and it says: "...it is apparent that flying a faster airspeed as the headwind increases will result in the greatest distance over the ground. If this is done for the polar curves from many gliders, a general rule of thumb is found, namely, add half the headwind component to the best L/D for the maximum distance." But even after telling him that he said that doesn't apply to power planes, also saying that manuals never give best glide, and there has to be a reason for that. Do you guys have any ideas on how I can really convince him? Any good sources? I found this link very helpful http://www.auf.asn.au/emergencies/aircraft.html terry |
Washington DC airspace closing for good? | tony roberts | Piloting | 153 | August 11th 05 12:56 AM |
Air Force seeks to increase military participation in 8th annual . | Otis Willie | Military Aviation | 0 | June 18th 04 10:53 PM |
