Winds A Factor In Lidle Crash
Old November 7th 06, 05:13 PM posted to rec.aviation.piloting
Larry Dighera
Default Winds A Factor In Lidle Crash
http://ntsb.gov/Pressrel/2006/061103.htm
UPDATE ON CIRRUS PLANE CRASH IN MANHATTAN, NEW YORK
The National Transportation Safety Board today released the following
update on its investigation into the accident involving a Cirrus
Design SR-20 N929CD that crashed into an apartment building while
maneuvering above Manhattan, New York on October 11, 2006.
The accident occurred about 2:42 pm eastern daylight time. The
airplane was destroyed by impact forces and a post crash fire. The
certificated private pilot owner of the airplane, New York Yankees
pitcher Cory Lidle, and a certified flight instructor were fatally
injured. Marginal Visual Flight rules conditions prevailed, and no
flight plan was filed for the flight that departed Teterboro Airport
(TEB), Teterboro, New Jersey. The personal sightseeing flight was
conducted under the provisions of 14 Code of Federal Regulations Part
91. There were 1 severe and 2 minor injuries on the ground.
The Safety Board go-team was composed of four teams: Airworthiness,
Powerplants, Operations, and Witnesses. The Weather, Air Traffic
Control and Aircraft Performance group chairmen gathered data from
NTSB headquarters. Parties to the investigation are Cirrus Design,
Federal Aviation Administration, Teledyne Continental Motors, and
Ballistic Recovery System.
The on-scene examination of the wreckage has shown that there was no
sign of an in-flight fire or damage to the airplane. The airplane
impacted the 30th floor of the apartment building, bounced off, then
fell to the street below, where it came to rest inverted and was
engulfed in a severe post crash fire. The engine was ejected from the
airplane and entered the building through an apartment window on the
30th floor.
The New York Central Park Automated Observation System reported that
at the time of the accident, that the winds were from 060 degrees at 6
knots, visibility at 7 statute miles, ceiling overcast at 1800 feet
above ground level, the temperature was 17 degrees Celsius, the
dewpoint was 13 degrees Celsius and the altimeter was 29.90 inches of
Mercury (Hg). No visibility restrictions were reported at any of the
surrounding airport weather stations. An aircraft that was landing at
Newark Liberty International Airport (KEWR) at the time of the
accident was equipped with a weather reporting capability that
indicated that the winds at 700 feet altitude were from 095 degrees at
13 knots.
Over fifty witnesses to the accident were identified and many
interview summaries were obtained from the New York Police Department.
Eleven of those witnesses saw the airplane before it impacted the
building.
Radar data indicate that the airplane was flying over the east side of
Roosevelt Island prior to initiating a 180 degree turn. At this
location, there would have been a maximum of 2100 feet clearance from
buildings, if the full width of the river had been used. However, from
the airplane's mid-river position over Roosevelt Island, the available
turning width was only 1700 feet. The prevailing wind from the east
would have caused the airplane to drift 400 feet toward the building
during the turn, reducing the available turning width to about 1300
feet. At an airspeed of 97 knots, this turn would have required a
constant bank angle of 53 degrees and a loading of 1.7 Gs on the
airplane. If the initial portion of the turn was not this aggressive,
a sufficiently greater bank angle would have been needed as the turn
progressed, which would have placed the airplane dangerously close to
an aerodynamic stall.
Since the accident, The FAA issued a Notice to Airman prohibiting
fixed wing aircraft such as the accident flight from operating in the
East River Class B Exclusion area where the accident occurred unless
authorized and controlled by ATC. This will prevent pilots from
encountering a situation in which they must attempt a complete u turn
in order to avoid entry into controlled airspace.
Maintenance records for the accident airplane indicated that all
Airworthiness Directives and Service Bulletins had been complied with.
The propeller and engine have been examined by Safety Board
investigators at their respective manufacturers and they indicated
that they were operating normally.
Additional work continues in the investigation. Two damaged portable
GPS units were recovered from the wreckage and sent to the
manufacturer to try to recover additional data. The memory chip
associated with the airplane's Multifunctional Display was retrieved
and sent to NTSB headquarters to try to recover any stored data. A
damaged laptop computer that was found in the wreckage and may contain
flight log information, is being examined at NTSB headquarters.
Several cockpit instruments are being examined in the Safety Board
laboratories, and work is underway to enhance a video obtained from
the Coast Guard that shows the airplane's impact with the building.
A graphic depicting radar tracks from several local radar facilities
may be found at the following link on the Board's website:
http://ntsb.gov/Pressrel/2006/N929CD...rn_3radars.pdf
Media Contact: Keith Holloway, 202-314-6100
Old November 7th 06, 05:26 PM posted to rec.aviation.piloting
Doug[_1_]
I think there is a lesson here for all of us pilots. When in close
quarters, consider the wind. Even better allow DOUBLE (or some other
amount you are comfortable with) the turning room for a 180 degree turn
around. Also, go out and practice a "minimum radius turnaround" (hint,
generally the slower you go the smaller the radius, the steeper you go
the smaller the radius etc). We learn a chandelle in commercial
manuevers, which is not really a minimum radius turnaround. I wonder if
the FAA would consider modifying the chandelle to BECOME a minimum
radius turnaround manuever? At any rate, try and learn from these
pilots mistakes. I know I have been in some tight mountain canyons and
not really considered the effects of the wind as I probably should
have. I just looked and there was room so I executed the turn. So far I
have been served well by my eyes and distant estimates, but perhaps I
should allow a little more room for error if there is any signifigant
tailwind during the turn.
Old November 7th 06, 11:25 PM posted to rec.aviation.piloting
Matt Whiting
The nice thing about a chandelle in this circumstance is the altitude
that it would have gained them.
Matt
Old November 9th 06, 04:15 AM posted to rec.aviation.piloting
K l e i n
Matt
I think the appropriate maneuver for this situation from the Commercial
Pilot syllabus would be half of a lazy-8. This provides a minimum
lateral displacement 180 degree reversal but does require some vertical
space to execute, also a reasonable airspeed. Perhaps the safest
execution would be to first lower the nose to gain speed, then do the
half lazy-8 into the wind. Another way of describing this is that it
is a mild wingover with only a 60 degree bank instead of 90 degree in a
full wingover.
Klein
Old November 9th 06, 11:40 PM posted to rec.aviation.piloting
Alan Gerber
What about an Immelman? (Granted, not from the Commercial syllabus.) Or
would it require too much altitude?
.... Alan
Alan Gerber
PP-ASEL
gerber AT panix DOT com
Old November 10th 06, 11:00 AM posted to rec.aviation.piloting
Gary Drescher
"Alan Gerber" wrote in message
Why not a simple steep turn? It's easy to pre-calculate the turn radius for
a given airspeed, bank angle, and crosswind component. In this case, they
had plenty of room if they'd planned and executed the turn properly.
--Gary
Old November 8th 06, 12:34 AM posted to rec.aviation.piloting
Jose[_1_]
(hint, generally the slower you
.... and the slower =and= steeper you go, the more the risk of a stall/spin.
Jose
"Never trust anything that can think for itself, if you can't see where
it keeps its brain." (chapter 10 of book 3 - Harry Potter).
Old November 7th 06, 07:41 PM posted to rec.aviation.piloting
Steven P. McNicoll[_1_]
"Larry Dighera" wrote in message
Has there been an update on the Comair crash that I missed? Anyone heard
the status of the copilot?
Old November 7th 06, 07:45 PM posted to rec.aviation.piloting
Gig 601XL Builder
ink.net...
Nothing other than he is being sued.
COMAIR FIRST OFFICER NAMED IN CRASH SUIT
(http://www.avweb.com/eletter/archive...ll.html#193638)
First Officer James Polehinke, the lone survivor of the Comair Flight
5191 crash, is among those named in a lawsuit filed on behalf of the
family of a Florida man who died in the crash. In a news release,
lawyer Stephen Marks, who has won a number of multimillion-dollar
settlements in airplane crash suits, said he tried to keep Polehinke
out of the case directly but he was unable to come to terms with his
insurance company. The suit also names Comair, and Marks says it's
clear that the pilot and airline are to blame. "Comair has
acknowledged publicly that its pilots were using an outdated airport
map in an attempt to make excuses for departing from the wrong
runway," he said. "Therefore, both the airline and its pilots are
clearly responsible for this tragedy despite what we are sure will be
efforts by their insurer and lawyers to blame others."
Old November 7th 06, 08:09 PM posted to rec.aviation.piloting
Ron Lee
The real cause was he was an idiotic and inept pilot that day who
left his wife without a husband and kids fatherless.
Ron Lee
Lidle crash: who is wrong? Blasto Piloting 57 October 20th 06 08:05 AM
VQ-1's P4M-1Q crash off China - 1956 Mike Naval Aviation 0 May 6th 06 11:13 PM
Four Winds 192 Crash into the Miami Federal Reserve Building, a year ago today Billgran Home Built 3 December 6th 03 03:22 PM
