#41
mike regish schrieb:
Well, what exactly are their reference datum(s?). GPS altitude and pressure altitude are completely different and, most important, *incompatible* systems. GPS altitude gives you a geometrically derived value above some reference surface. Mostly it's the WGS84 geoid. Of course this can be converted to MSL altitude if you wish. But this isn't the point. The point is that the pressure altimeter measures, well, a pressure, not an altitude. It displays a value in feet, but actually, this is wrong. It may be true in very specific conditions, but the real atmosphere very seldom matches the theoretical ISA atmosphere model on which the altimeter is based. And, most important, there is no way to calculate the real (geometric) altitude from the displayed pressure altitude. (Of course it could, if you knew the complete atmosphere profile, but you usually don't.) So the point is: GPS gives you the true altitude in reference to the earth, but this doesn't help you, because the whole aviatic system (airspace boundaries, ATC clearances, traffic separation) is based on pressure altitude, and there is no practical way to convert one into the other. If you are given an ATC clearance for a certain pressure altitude but fly GPS altitude instead, then you act exactly like that bozo who drives on the wrong side of the road. The only use for GPS altitude in aviation is to calculate the final glide of a glider. (Or an IFR approach, but I don't know enough about IFR flight to comment this.) But I'm sure you knew all this before, because after all, you've passed a written. Stefan |
#42
Above 18K feet, everybody is on pressure altitude. Down in the sewers, where
I fly, we're all on local pressure. mike "Mxsmanic" wrote in message ... Not true. Altimeters show substantial differences with geometric altitude as altitude increases. Air traffic control is based on pressure altitudes, not geometric altitudes. The altimeter is much more accurate. That's what I would assume with my particular GPS. |
#43
Do those amounts vary with location? How large a difference is there between
the 2? I remember reading about the 2 standards, but forget how the mean geoid is determined. But you're right. If that's true, and I don't doubt it is, GPS would be better suited to terrain avoidance and less so to aircraft separation. mike "Mxsmanic" wrote in message ... mike regish writes: My point is that they both are, basically, the same frame of reference-height above sea level. Nope. GPS is height above the mean surface of the geoid, altimeter is height above mean sea level. They can be hundreds of feet apart. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#44
Gee, that was actually a well thought out, well explained, and in my case
anyway, very informative post. It's been 9 years since my written, but I don't remember a whole lot about geoid reference in it. I do remember the WSG84 reference in my handheld (which I never use for altitude, BTW) though, so it must have been there. mike P.S. I got a 96 "Stefan" wrote in message ... mike regish schrieb: Well, what exactly are their reference datum(s?). GPS altitude and pressure altitude are completely different and, most important, *incompatible* systems. very knowledgeable post snipped But I'm sure you knew all this before, because after all, you've passed a written. Stefan |
#45
"TxSrv" wrote in message
. .. Mxsmanic wrote: You can find the answer in FAR 91.121(a)(iii). Found it, thanks. I'm surprised that just setting it at the airport would suffice--one could conceivably fly for hundreds of miles VFR, and the altimeter could change significantly along the way. That Reg does not apply to flight within 3,000 above the surface. You have to look at two other Regs to conclude that. The requirement stated in 91.121a1iii does not include any exception for flights under 3000' AGL. If you have an adjustable altimeter, you have to set it according to 91.121, regardless of your altitude. Therefore, under 3,000, an adjustable altimeter is not required per 91.205. According to 91.205, an adjustable altimeter is only required for IFR (regardless of altitude). --Gary |
#46
My filter failed and this message popped up... Not an issue of any
importance in itself and fixed again with two mouse clicks... However, seeing the list of you tripping over yourselves to answer his trolling have me howling with laughter... denny Mxsmanic wrote: Since it is possible to fly without voice radio equipment, and given that (if I understand correctly) pilots are supposed to have their altimeters set correctly to a reference located not more than 100 miles from their position, how does an aircraft without a radio keep its altimeter properly set as it travels? -- Transpose mxsmanic and gmail to reach me by e-mail. |
#47
![]() "TxSrv" wrote in message . .. For VFR, an adjustable altimeter is not required. Therefore, such a 100 mile rule doesn't exist. What aircraft altimeter is not adjustable? IFR flight requires a sensitive altimeter adjustable for barometric pressure, VFR flight simply requires an altimeter. But even altimeters that cannot be adjusted for barometric pressure are adjustable. My Champ' came with a single-needle altimeter, once around the dial was 10,000 feet. I hated it, the needle never seemed to move. But there was an adjustment knob that rotated the dial so the needle would point to field elevation. The regulation requires aircraft without radios to set the altimeter to the elevation of the departure airport or an appropriate altimeter setting available before departure. |
#48
![]() Mxsmanic wrote: Since it is possible to fly without voice radio equipment, and given that (if I understand correctly) pilots are supposed to have their altimeters set correctly to a reference located not more than 100 miles from their position, how does an aircraft without a radio keep its altimeter properly set as it travels? -- Transpose mxsmanic and gmail to reach me by e-mail. So MXsmanic, you strike again. For those who wonder why people give you the answers you get, there's a good reason. Now it's my turn to tell people about you. I also did some searching on your past postings too. You show up here pretending to be a pilot, and a lot of people who haven't fallen for the act try and give you helpful advice, to which you aren't thankful. What the heck is this game you are playing with everyone? I'm VERY grateful that I was tipped off to your game by some honest posters last week. If you were more grateful, I might feel differently. Or if you told people in your posts that you aren't a pilot, and don't ever intend to be one, that would be fine too. But all of your questions, and there are a lot of them, are worded so that people are misled. Could you please start including in your posts that you are looking for info for your MS flight simulator? Don't get me wrong, I like flight simulators, and there's nothing wrong with non-pilots asking questions- they deserve the same respect. But the way you decieve people here is disrespectful. Don't take advantage of the fact that pilots are inclined to help eachother. |
#49
"Cirrus" wrote in message
oups.com... If you were more grateful, I might feel differently. Or if you told people in your posts that you aren't a pilot, and don't ever intend to be one, that would be fine too. Sorry, but I think you're overreacting a bit. It's true that in a few of his posts, Mx misleadingly describes his simulator exploits as though they were real. But the vast majority of his posts don't do that, and many of them make it explicit that he's not a pilot. In any case, everyone participating in this thread so far is aware that Mx isn't a pilot. I think your impression of Mx's posts is probably skewed by the fact that your introduction to Mx happened to occur with one of the few posts of his that was phrased misleadingly with regard to his flight status. --Gary |
#50
Dang. I actually learned something from this post.
An' ah already gots one o them pilot licencse thingys. mike "Cirrus" wrote in message oups.com... So MXsmanic, you strike again. For those who wonder why people give you the answers you get, there's a good reason. |
terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 09:39 PM |
I Hate Radios | Ron Wanttaja | Home Built | 9 | June 6th 05 05:39 PM |
(sorta OT) Free Ham Radio Course | RST Engineering | Piloting | 43 | January 24th 05 08:05 PM |
1944 Aerial War Comes to Life in Radio Play | Otis Willie | Military Aviation | 0 | March 25th 04 10:57 PM |
Ham Radio In The Airplane | Cy Galley | Owning | 23 | July 8th 03 03:30 AM |
