NTSB final report on Hendrick crash
Old November 14th 06, 05:17 PM posted to rec.aviation.ifr
Ron Lee
Default NTSB final report on Hendrick crash
Sam Spade wrote:
Maule Driver wrote:
Huh? "How to use and not use a GPS' lessons seems to be written all
over it. But if you just want to knock the pilots, then nothing will be
learned. My personal conclusion and lesson is that you need to stick
with your primary navigation instruments and use the backup as backup.
But that's me.
There are no new lessons to be learned from this accident. Because of
the lack of a CVR the NTSB is being speculative about the use of the GPS.
Sam that is perhaps the case with most accidents. I hear "We must
learn from this." In most cases yet the mistakes are recurring ones.
Maybe a listing of pilot screwups would help yet I suspect that you
won't reduce accidents much.
Technology can help in some cases. Even a simple Garmin with terrain
functionality, especially if there is an audible alert, may prevent
some accidents yet not flying in those conditions works 100%.
Personally, I would prefer to quit hearing about "We can all learn
from this fatality" and have those experts determine how to prevent
them in the first place.
Ron Lee
  #42
Old November 14th 06, 06:08 PM posted to rec.aviation.ifr
Don Poitras
pgbnh wrote:
Not clear (to me at least) is WHY they so clearly lost situational
awareness. Based on when they descended to MDA,and when and how they flew
the missed, they obviously thought they were someplace other than where they
were.
But why? Missing the fact that they autosequenced over the NDB might have
caused some confusion when flying the hold, but once inbound, both the GPS
(if they were using it) and the primary nav (presumedly tuned to the LOC
frequency) would both be showing dme to MAP. The gps would count down to
zero, the primary nav would go down to 1. How could either relying on a
potentially unreliable GPS OR missing the autosequencing have caused them to
to fly several miles PAST the MAP thinking that they had not yet reached it?
IIRC, they descended to MDA several miles PAST the MAP. They used the MAP as
the FAF, and seemed to fly a picture perfect approach thereafter. How could
misreading the GPS or NAV cause this??
I'd guess they weren't looking at the DME. The countdown to the FAF and the
countdown to the MAP don't look any different except for the waypoint name.
Once past what they thought was the FAF, they probably set a normal descent
rate, looked at the localizer needle for course, altimeter for MDA and out
the window for the runway and never looked at the GPS again.
Don Poitras
  #43
Old November 14th 06, 06:54 PM posted to rec.aviation.ifr
Jose[_1_]
Um... that's what we're trying to learn from them.
Jose
"Never trust anything that can think for itself, if you can't see where
it keeps its brain." (chapter 10 of book 3 - Harry Potter).
  #44
Old November 14th 06, 07:06 PM posted to rec.aviation.ifr
Ron Lee
Jose
Um, do you have to have people fly into buildings to know that it is
not a good thing to do?
Fly into Class 5 (?) thunderstorms?
Scud run in the mountains?
Run out of fuel?
Take off on a runway that is too short?
How many unforeseen accident causes do we really see that a competent
pilot with good judgement should know to avoid?
Ron Lee
  #45
Old November 14th 06, 08:26 PM posted to rec.aviation.ifr
Jose[_1_]
I'm glad I read the newsgroups. I just learned that crashing is a Bad
Thing.
The question is =why= an otherwise good pilot made a bad mistake. Or
sometimes, why a small mistake turned out really bad this time.
Jose
  #46
Old November 14th 06, 08:59 PM posted to rec.aviation.ifr
pgbnh
I thought about it some more and went back and reread the NTSB report. It
would appear that they were relying on the INFORMATION (CDI & DME) from the
GPS, but were not looking at the positional display. If they missed the fact
that they had passed the FAF as part of their aborted hold, AND they missed
the fact that the GPS had sequenced to the MAP, then they flew inbound on
the localizer course thinking they were still outside the FAF. The GPS would
be giving them distance information to MAP - they were seeing it as distance
to FAF. They then flew a pretty good approach - just displaced by 5-6 miles.
They also were pretty obviously navigating by the GPS and not using the
primary NAV - or they were at least depending on GPS for DME and not using
an independent DME. I am not familiar with the King GPS - the Garmin 530 has
a big identifier up on top which shows the waypoint being flown to.
The really scary thing is if two pilots with these qualifications can make
such a mistake, what hope is there for me?
"Don Poitras" wrote in message
they
were.
GPS
to
it?
as
could
name.
descent
Don Poitras
  #47
Old November 14th 06, 10:58 PM posted to rec.aviation.ifr
Matt Whiting
Mark Hansen wrote:
By the way, I can't take the unit home to practice (or even practice
in the plane while on the ramp) because these are club planes, and
they don't allow that. Also, there is no PC-based simulator (good
thinking B/K!).
Same here ... club plane and no sim. I'll buy a Garmin given the chance.
Matt
  #48
Old November 15th 06, 12:19 AM posted to rec.aviation.ifr
Don Poitras
thinking B/K!).
89/B simulator can be found he http://www.bendixking.com/static/simulators/
Matt
Don Poitras
  #49
Old November 15th 06, 02:25 PM posted to rec.aviation.ifr
Sam Spade
were.
Why would they disregard the DME unless it wasn't working?
  #50
Old November 15th 06, 02:27 PM posted to rec.aviation.ifr
Sam Spade
Don't beat yourself up.
Their operation that day was very incompetent.
NTSB final reports Tony Piloting 15 January 5th 06 09:07 PM
Wellston Crash Report Quote EDR Piloting 26 November 21st 03 10:50 PM
Air Force Museum Working Group to release final report Otis Willie Military Aviation 0 November 18th 03 12:28 AM
