Govt Plates
Old November 22nd 06, 11:38 PM posted to rec.aviation.ifr
Sam Spade
Default Govt Plates
Jim Macklin wrote:
The FAA and ATC exist to serve the military. The airlines
are a justification on the budget. GA is forced to use ATC
because in the past 50-60 years the FAA expanded the scope
of controlled airspace to be everywhere. 25 years ago there
were large areas that were uncontrolled below 14.500 feet.
Your not the only one to make the argument that the FAA exists to serve
the military. The last time that was factually correct was during World
War II.
It is all about the airlines.
As to controlled airspace, what adverse impact does lowering Class E
airspace below 14,500 (known at one time as the Continental Control
Area) have on GA? What imposition does Class E impose upon the VFR
pilot, other than to have the transponder turned on?
As to IFR operations, light aircraft would be precluded from using the
system without Class E airspace below 14,500.
I started flying IFR in 1956. We didn't even have to have a radio to go
into most towered airports then. But, the folks I flew for in the early
days didn't think that was very smart so we had radios.
Airways were far more limited then and direct routing off airways was
usually impossible because of the lack of controlled airspace beyond the
limits of the airways. We have a lot more flexible system today for IFR
operations because of large areas of Class E airspace.
Class B and C airspace comprises a very small percentage of the total
airspace in the country. Those classes were not established to enhance
IFR operations; rather, they were enacted to mitigate collision risk.
Most of the world had some type of restrictive terminal control areas
before the FAA went there.
  #42
Old November 22nd 06, 11:45 PM posted to rec.aviation.ifr
Sam Spade
Default Govt Plates
Newps wrote:
That's funny. The military couldn't care less about the FAA.
Since you enjoy funny stories about the FAA ;-) here is one for you:
A few years ago when El Toro Marine Air Station closed, John Wayne
(Orange, County, CA KSNA) lost the eastern half of its Class C airspace.
The airspace was bifurcated like that because of a giant screw up
years ago. Some regional FAA grunt thought El Toro would be there
forever, so they did it that way. The entire area was needed for John
Wayne Airport; not so for El Toro.
So, in the rucus that ensued to get the Class C back the way it was
meant to be there were more than a couple of conference calls. The
airspace lady in the Western Pacific Region made the following
outrageous statement on a phone call with union reps, airline managers,
ATC managers, and ATA folks, "The FAA is subserviant to the military.
The FAA does not own any airspace. All airspace in the United States is
owned by the military."
  #43
Old November 22nd 06, 11:46 PM posted to rec.aviation.ifr
Sam Spade
Default Govt Plates
Mike Granby wrote:
Sam Spade wrote:
I doubt AOPA's bean counters have
even considered NACO chart services.
Remember that any product of the federal government is free of
copyright by law, and is therefore in the public domain. They'd have to
spin the NACO service into a private agency if they wanted to stop
other people distributing the charting data.
And, you think NACO would not go private in the event ATC goes there?
  #44
Old November 23rd 06, 12:13 AM posted to rec.aviation.ifr
Newps
Default Govt Plates
That's not true either. That flies in the face of civilian control of
the military. The military doesn't demand anything in a national
emergency. They do what they're told, as it should be.
  #45
Old November 23rd 06, 02:01 AM posted to rec.aviation.ifr
Sam Spade
Default Govt Plates
is owned by the military."
I was passing it on to you because it is absurb; as in you will find
this humorous.
Gee wiz, I guess you didn't find it funndy.
  #46
Old November 23rd 06, 03:29 AM posted to rec.aviation.ifr
Jim Macklin
Default Govt Plates
Wichita, Kansas tower was removed from terminal building and
located in a secure building with no place to hide a bomb.
Topeka, Kansas, the tower was moved into the center of the
airport behind the fences.
All over the country, towers are being relocated, still on
the airport, but in a secure new building.
"karl gruber" wrote in message
| "Jim Macklin" wrote
in message
| All ATC facilities were moved to remote locations [as
much
| as possible] including airport towers.
| OK, I'll bite. Name ONE remote tower.
| Karl
  #47
Old November 23rd 06, 03:30 AM posted to rec.aviation.ifr
Jim Macklin
Default Govt Plates
You can fly under IFR rules in uncontrolled airspace Class
G.
"Sam Spade" wrote in message
airlines
ATC
scope
there
feet.
exists to serve
was during World
| War II.
lowering Class E
Continental Control
upon the VFR
from using the
a radio to go
for in the early
airways was
airspace beyond the
today for IFR
of the total
collision risk.
control areas
  #48
Old November 23rd 06, 04:07 AM posted to rec.aviation.ifr
Doug[_1_]
Default Govt Plates
Federal construction money. PORK!!!
  #49
Old November 23rd 06, 05:06 AM posted to rec.aviation.ifr
Newps
Default Govt Plates
G.
Sure, but nobody does because it is too impractical.
  #50
Old November 23rd 06, 05:07 AM posted to rec.aviation.ifr
Newps
Default Govt Plates
Towers are being built on a pretty standard schedule. We just went thru
this process here. No tower is being built simply for security reasons.
RUTHLESSLY KILL TERRORIST PSYCHOPATHS BUSH, CHENEY, RUMSFELD, Robert Mueller, Keith Alexander, Mathew Hayden and John Negroponte AmerGovtPsychopathsExposer Home Built 17 November 20th 06 12:01 AM
RUTHLESSLY KILL TERRORIST PSYCHOPATHS BUSH, CHENEY, RUMSFELD, Robert Mueller, Keith Alexander, Mathew Hayden and John Negroponte AmerGovtPsychopathsExposer Owning 0 November 17th 06 11:41 PM
Using free online approach plates mvgossman Instrument Flight Rules 22 November 1st 06 12:24 AM
legal to use home-printed IFR plates? Marty Ross Instrument Flight Rules 29 January 4th 06 05:25 PM
Approach Plates on PDA (PIREP) Stan Prevost Instrument Flight Rules 10 December 18th 04 04:21 AM
