Flight Watch is intended for weather and PIREPS, although in
an emergency, they will talk to you about the impending crash or the other condition. But they are setup as weather specialists. For the real student pilots out there, position reports are often a life saver. In areas of mountains, swamps, oceans and deserts, even your slow trainer can get you many miles away from your last known position in just a few minutes. A flight plan files with a 90 minute ETE will often require a search over several hundred square miles unless you have either made accurate position reports, or received radar service/flight following from ATC. Although VFR position reports are usually given directly to FSS Radio on one of the frequencies publish on the sectional chart or in the AFD, you can give a VFR position report to ATC even if you are not in radar contact, just call Center [call sign] VFR position report. They will be able to record the report and are happy to do so, particularly in remote areas. Learn the format for a position report and don't waste their time stammering. When you start IFR training, you'll be ahead of the class. -- James H. Macklin ATP,CFI,A&P "Bob Gardner" wrote in message ... | They all work in the same building and get paid from the same pool of money, | but the last time I visited the Seattle AFSS there was one person at the | Flight Watch position whose sole responsibility it was to answer queries | about the weather on 122.0...s/he worked no other frequency. And his scope | did not have a flight plan screen, as did the other scopes in the room. | | Bob Gardner | | "Andrew Gideon" wrote in message | news ![]() | | Uh... Andrew, you do realize that Flight Watch is a purely weather | position with no other responsibilities, right? Call FSS, yes, call | Flight | Watch, no. | | I've often wondered: why the distinction? Isn't Flight Watch the same set | of people? | | - Andrew (a different Andrew) | | | |
On Mon, 20 Nov 2006 14:17:20 -0800, Bob Gardner wrote:
the last time I visited the Seattle AFSS How does one locate a local FSS? I'd like to visit one. -- Dallas |
They all work in the same building and get paid from the same pool of money, but the last time I visited the Seattle AFSS there was one person at the Flight Watch position whose sole responsibility it was to answer queries about the weather on 122.0...s/he worked no other frequency. And his scope did not have a flight plan screen, as did the other scopes in the room. That's informative to me (ie. I didn't know this {8^), but I still don't know why the separation of the two services? Thanks... - Andrew |
On Mon, 20 Nov 2006 11:08:01 +0100, Mxsmanic wrote:
I'm still not clear on the exact procedure for position reports if you are flying VFR over long distances without flight following. To whom do you report your position, and what information should it include? Which positions do you report and how often? Flying in southern British Columbia (outside the radar environment around Vancouver-Victoria), I will use flight following if I am high enough. This is not always practical (there are areas where 10500 feet is too low) so I will call FSS whenever I come near another FSS or RCO with a position report. I always file a flight plan. There is a lot of remote territory around here. randall g =%^) PPASEL+Night 1974 Cardinal RG http://www.telemark.net/randallg Lots of aerial photographs of British Columbia at: http://www.telemark.net/randallg/photos.htm Vancouver's famous Kat Kam: http://www.katkam.ca |
Mxsmanic wrote:
I'm still not clear on the exact procedure for position reports if you are flying VFR over long distances without flight following. To whom do you report your position, and what information should it include? Which positions do you report and how often? 1) No one. 2) None. 3) Not ever. Unless you are on flight following or in airspace that requires radio contact, there is no obligation to talk to anyone. |
![]() "Blanche" wrote in message ... Mxsmanic wrote: I'm still not clear on the exact procedure for position reports if you are flying VFR over long distances without flight following. To whom do you report your position, and what information should it include? Which positions do you report and how often? 1) No one. 2) None. 3) Not ever. Unless you are on flight following or in airspace that requires radio contact, there is no obligation to talk to anyone. Even Flight Following is not going to ask you for position reports, as they already know where you're at, except on initial call up, you should provide your approximate position. I know some people will include position when they check-in with a controller they have been handed off to, but isn't necessary. |
"Wade Hasbrouck" wrote in
news:RfOdnVwDSesXqf_YnZ2dnUVZ_oCdnZ2d@cablespeedwa .com: I know some people will include position when they check-in with a controller they have been handed off to, but isn't necessary. Interesting as I have never heard anybody give their position when handed off? What do they say for their position. Only thing I report on hand offs is my altitude and read back the altimeter if center acknowleges me with a altimeter setting. I.E. Memphis Center Sundowner one niner four three lima 7000 I have never heard anything any different other then an initial callup where they give location, altitude and request VFR flight following or an IFR picking up their clearance. Allen |
"A Lieberma" wrote in message
. 18... "Wade Hasbrouck" wrote in news:RfOdnVwDSesXqf_YnZ2dnUVZ_oCdnZ2d@cablespeedwa .com: I know some people will include position when they check-in with a controller they have been handed off to, but isn't necessary. Interesting as I have never heard anybody give their position when handed off? What do they say for their position. Only thing I report on hand offs is my altitude and read back the altimeter if center acknowleges me with a altimeter setting. I.E. Memphis Center Sundowner one niner four three lima 7000 I have never heard anything any different other then an initial callup where they give location, altitude and request VFR flight following or an IFR picking up their clearance. I don't include position in a handoff, but there was discussion on the pilots alias at work about a month ago and some did say they included their position... |
Blanche writes:
1) No one. 2) None. 3) Not ever. Unless you are on flight following or in airspace that requires radio contact, there is no obligation to talk to anyone. I wasn't asking about obligations, I was asking about safe practices and the procedures in place that allow them. -- Transpose mxsmanic and gmail to reach me by e-mail. |
if you are making position reports
do you not then have flight following? BT "Mxsmanic" wrote in message ... I'm still not clear on the exact procedure for position reports if you are flying VFR over long distances without flight following. To whom do you report your position, and what information should it include? Which positions do you report and how often? -- Transpose mxsmanic and gmail to reach me by e-mail. |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
GPS and old-fashioned thinking? | G Farris | Instrument Flight Rules | 92 | December 22nd 05 05:39 PM |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
ASRS/ASAP reporting systems - how confidential? | Tim Epstein | Piloting | 7 | August 4th 05 05:20 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
