A REALLY bad joke
Old November 28th 06, 05:39 PM posted to rec.aviation.piloting
Mxsmanic
Default A REALLY bad joke
Judah writes:
Nope, they mostly talk about my most memorable reaction to the problem in
the plane...
"Oh SH-T!!"
Those are the final words on most CVRs, too.
  #42
Old November 28th 06, 08:37 PM posted to rec.aviation.piloting
Peter Dohm
THE first indication of an oil problem is a run-away prop on
a single-engine with a typical constant speed prop. The
prop governor is just a high pressure oil pump and control
valve that must be supplied with engine oil under pressure
and with adequate volume. If the engine oil galleries and
lines are not full of oil, the governor will not work. On a
multiengine airplane, the prop will feather.
The prop, on a single, becomes fixed pitch and the throttle
controls rpm just like it was a solid fixed pitch. The
engine will run just fine as long as it has oil, but a
ruptured line or gasket will dump the oil and you don't know
exactly what is happening, so land ASAP.
-----much snipped for brevity---------
Most, but certainly not all, hydraulically controlled constant speed props
will fail to their finest pitch position if oil pressure is lost. There
have been exceptions--there was a high performance kit plane (I forgot the
name) which had the prop spring loaded the other way, such that any governor
failure would leave the porp in coarse pitch.
I have no idea how any of the auto feathering props on turbo-prop engines
really work, and therefore I don't know whether they would require oil
pressure to feather. However, I have not personally heard of any feathering
prop on any reciprocating engine which does not require oil pressure to
feather.
Peter
  #43
Old November 28th 06, 08:46 PM posted to rec.aviation.piloting
Peter Dohm
How to Fly in Three Easy Lessons
A story used to circulate about an airline flight crew who had a little
routine based on a book with a similar title. As the story went: The
copilot would enter the aircraft from the rear door and then slowly make his
way forward--obviously cramming from the book that he was reading. Of
course, he would take his seat and the flight would depart without anything
ever being said.
Although the story was told to me as being on a Boeing 727, I suspect that
it was really a DC-3 story that just wouldn't die.
Peter
The Net's #1 Joke e-Book! Expert Humor Soaring 0 March 31st 06 03:25 PM
The Net's #1 Joke e-Book! Expert Humor Owning 0 March 31st 06 03:24 PM
The Net's #1 Joke e-Book! Expert Humor Home Built 0 March 31st 06 03:23 PM
The Net's #1 Joke e-Book! Expert Humor Piloting 0 March 31st 06 03:13 PM
American joke on the Brits ArtKramr Military Aviation 50 September 30th 03 10:52 PM
