Checklist exchange
Old January 18th 07, 07:52 PM posted to rec.aviation.piloting
Andrey Serbinenko
Default Checklist exchange
Everybody's using checklists. I've started with the stuff from POH, plus
whatever my instructor recommended, and then over time more and more little
things got added to them out of experience. Yet more things got added as I
started my instrument training. The basic stuff is probably not so interesting
since it is everywhere. What is indeed interesting, I think, is those little
things that other people may have in their checklists that I don't have --
stuff that's grown out of individual mistakes. Often you can arrange things in
such a way that it makes making a mistake more difficult and so on.
I'm going to proceed and publish here some of my C172 checklists. If that
turns out to be interesting, I also have my RG/complex checklists for Cutlass.
Hope this is going to result in a fruitful exchange of information...
Andrey
C172
PRE-FLIGHT
1. hobbs record
2. inspections check
3. ARROW check
4. windows check clean
5. control lock remove
6. parking brake set
7. avionics verify off
8. master on
9. fuel gauges check indication
10. flaps down
11. turn coordinator check no flag
12. pitot heat check
13. lights check
14. master off
15. trim visually check
16. fuel selector both
17. key verify removed
POST-FLIGHT
1. avionics off
2. ignition ground check
3. mixture cut-off
4. landing light check
5. master off
6. key remove
7. fuel selector left
8. trim for take-off
9. control lock set
10. all lights verify off
11. hobbs record
12. flight plan close
ENGINE START
1. pre-flight complete
2. pax briefed
3. seat belts secure
4. brakes check pressure
5. mixture rich
7. throttle 1/8
8. carb heat off
9. nav light & beacon on
10. avionics verify off
11. prime as required
12. master on
13. clear prop call
14. ignition engage
15. throttle 800-1000 rpm
16. oil pressure/temp check
17. vacuum check
18. ammeter check
19. lights on
20. circuit breakers check
21. avionics on
PRE-TAXI
1. altimeter set
2. ATIS receive
3. altimeter reset
4. DG align with compass
5. AI set level
6. alt static/VSI check
7. comm 1,2 check
8. mkr lights check
9. transponder test
10. vor 1,2 test
11. adf test
12. comm/nav set as required
13. transponder standby VFR
14. trim verify for t/o
15. flaps up
16. fuel selector left
17. clearance receive
18. transponder set as required
19. taxi light on
20. parking brake release
21. brakes check
TAXI
1. turn coordinator verify
2. DG verify
3. compass verify
4. AI verify
5. controls position for wind
RUNUP
1. nose straight
2. parking brake set
3. taxi light off
4. controls free and correct
5. 6-pack check
6. avionics set as required
7. mixture rich
8. fuel selector right
9. throttle 1700 rpm
10. oil pressure/temp check
11. vacuum check
12. ammeter check under load
13. magnetos check
14. carb heat check
15. idle check
17. primer verify locked
PRE-TAKE-OFF
1. mixture as required
2. fuel selector both
3. carb heat off
4. primer locked
5. flaps as required
6. trim for t/o
7. take-off briefing complete
BRIEFING:
1. rotation speed
2. best glide speed
3. runway required
4. runway available
5. engine quits: a. before rotation - abort take-off
b. below 800' agl - land straigt ahead +/- 30deg
c. above 800' agl - turn (which way) for
landing on (which) runway
8. seat belts secure
9. doors & windows locked
TAKE-OFF
1. landing light on
2. strobes on
3. transponder mode C
4. DG verify runway heading
5. time note
6. engine rpm verify full power
7. oil pressure/temp in the green
8. airspeed alive
PRE-LANDING
1. mixture rich
3. primer locked
4. landing light on
5. seat belts secure
6. brakes check pressure
7. carb heat as required
8. flaps as required
POST-LANDING
1. carb heat off
2. flaps up
4. landing light off
5. strobes off
6. time note
Checkride Checklist Question Gary G Piloting 78 September 1st 05 12:53 AM
Pointer please; test checklist Michael Horowitz Owning 1 February 19th 05 05:22 PM
747-100 Checklist Bartscher General Aviation 0 December 18th 04 08:20 PM
IFR Checkride Checklist BTIZ Instrument Flight Rules 0 April 18th 04 01:06 AM
Checklist binder? dougdrivr Restoration 0 November 5th 03 04:55 PM
