Paul kgyy writes:
For serious climbing, use power and rich mixture, then reduce MP, prop, and mixture as needed at desired altitude. _Always_ rich for a climb? At altitudes above a few thousand feet MSL, it seems that a rich mixture just slows me down. -- Transpose mxsmanic and gmail to reach me by e-mail. |
![]() "Mxsmanic" wrote in message ... Paul kgyy writes: For serious climbing, use power and rich mixture, then reduce MP, prop, and mixture as needed at desired altitude. _Always_ rich for a climb? At altitudes above a few thousand feet MSL, it seems that a rich mixture just slows me down. When was the last time you cleaned the plugs in your DESK? |
In rec.aviation.piloting Mxsmanic wrote:
Paul kgyy writes: For serious climbing, use power and rich mixture, then reduce MP, prop, and mixture as needed at desired altitude. _Always_ rich for a climb? At altitudes above a few thousand feet MSL, it seems that a rich mixture just slows me down. In a real airplane with a real engine that generates real heat and costs real money to overhaul there are conciderations beyond how fast you go. -- Jim Pennino Remove .spam.sux to reply. |
Mxsmanic wrote in
: writes: In a real airplane with a real engine that generates real heat and costs real money to overhaul there are conciderations beyond how fast you go. I guess that's a problem for real pilots. It's not a problem for me. you're not even an unreal, pilot, djikkhedd. Bertie |
writes: In a real airplane with a real engine that generates real heat and costs real money to overhaul there are conciderations beyond how fast you go. I guess that's a problem for real pilots. It's not a problem for me. Then why bother asking how real airplanes fly? Just go play with your simulator and do what you want. Flying a real airplane requires concidering a pile of factors such as aircraft performance, equipment and condition, weather, temperature, density altitude, center of gravity, airspace types, pilot health and general disposition, maneuvering speed, fuel burn, costs, engine health, etc. -- Jim Pennino Remove .spam.sux to reply. |
![]() _Always_ rich for a climb? At altitudes above a few thousand feet MSL, it seems that a rich mixture just slows me down. When you're climbing, airspeed is less and engine power is higher, generating more heat in the air cooled cylinders. A rich mixture helps keep cylinder temps under control because more fuel is evaporated than is burned. Nothing is automatic with these old engines, though Teledyne has developed a single lever Fadec system that supposedly takes care of this with electronic monitoring. Still, even Fadec should enrich the mixture in climb. Pilots with engine monitors (JPI, EI) may not go to full rich when climbing since they can monitor cylinder temps in real time. If you want a good education on piston engine management, read through John Deakin's articles in Avweb. |
Paul kgyy wrote:
Nothing is automatic with these old engines, Many carbs actually go beyond the mixture lever's full rich at wide open throttle. |
Paul kgyy writes:
When you're climbing, airspeed is less and engine power is higher, generating more heat in the air cooled cylinders. A rich mixture helps keep cylinder temps under control because more fuel is evaporated than is burned. But if you are, say, at 9000 or 10000 feet, don't you risk losing a lot of power just when you need it most if you set a rich mixture? The POH for the Baron I fly in the sim says "full rich or as required for altitude," IIRC. Unfortunately it's not very specific about exactly how to determine the correct mixture at higher altitudes. If you want a good education on piston engine management, read through John Deakin's articles in Avweb. I think I have; I recall it being quite good, albeit complicated. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Paul kgyy writes: When you're climbing, airspeed is less and engine power is higher, generating more heat in the air cooled cylinders. A rich mixture helps keep cylinder temps under control because more fuel is evaporated than is burned. But if you are, say, at 9000 or 10000 feet, don't you risk losing a lot of power just when you need it most if you set a rich mixture? The POH for the Baron I fly in the sim says "full rich or as required for altitude," IIRC. Unfortunately it's not very specific about exactly how to determine the correct mixture at higher altitudes. That's because it is one of the things all real pilots have to learn early in their training to fly real airplanes. Real pilots are also trained to know that "as required for altitude" means density altitude performance. If you want a good education on piston engine management, read through John Deakin's articles in Avweb. I think I have; I recall it being quite good, albeit complicated. And yet another difference between simulated by Microsoft and real flying... -- Jim Pennino Remove .spam.sux to reply. |
Methods of launch | Jim Culp | Soaring | 0 | November 20th 06 07:39 AM |
Methods of Launch | Nigel Baker | Soaring | 3 | November 17th 06 04:35 PM |
methods of lauch | Robert Gaines | Soaring | 0 | November 16th 06 01:17 AM |
Vector altitude for ILS below GS intercept altitude? | M | Instrument Flight Rules | 23 | May 20th 06 07:41 PM |
Pressure Altitude or Density Altitude | john smith | Piloting | 3 | July 22nd 04 10:48 AM |
