#41
"swag" wrote in
ups.com: This is actually a maneuver that's demonstrated and practiced very early in flight training, so I'm sure all pilots and student pilots have experienced this. But your calculations are fairly correnct--a 2 minute turn won't cut it. It's usually demonstrated with a 60 degree bank turn. I'm not sure of the timing, but i'd guess 30 sec or less. You meant 45 degree bank. A 60 degree steep turn would require a parachute. |
#42
swag writes:
This is actually a maneuver that's demonstrated and practiced very early in flight training, so I'm sure all pilots and student pilots have experienced this. But your calculations are fairly correnct--a 2 minute turn won't cut it. It's usually demonstrated with a 60 degree bank turn. I'm not sure of the timing, but i'd guess 30 sec or less. Don't you have to descend to catch the wake? Downwash should be moving downward at a few knots and IIRC the vortices do as well, so after two minutes at, say, 12 knots, the turbulence would be almost 2500 feet below you, if you are staying at altitude. I don't see how you could run into it. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#43
swag writes:
This is actually a maneuver that's demonstrated and practiced very early in flight training, so I'm sure all pilots and student pilots have experienced this. But your calculations are fairly correnct--a 2 minute turn won't cut it. It's usually demonstrated with a 60 degree bank turn. I'm not sure of the timing, but i'd guess 30 sec or less. Sorry, I didn't notice the 60-degree part. Sixty degrees would be 2.7 Gs, which seems high for a GA aircraft. If I'm not mistaken, this would allow a 360-degree turn in about one minute at 100 kts. Still, the wake would be a thousand feet lower or so by then (assuming a 12-kt downwash). -- Transpose mxsmanic and gmail to reach me by e-mail. |
#44
Snowbird writes:
Tip vortices is not the only form of turbulence behind an aircraft. And an airliner on approach has a different type of wake than a trainer at altitude. All of them should be moving downward, though. Which means that if you try to catch your own wake at constant altitude, you should miss it, as it will have drifted downward. Or am I missing something? The best value of a good simulator is that it enables training of situations that would be unsafe to do in a real aircraft.Flying into wake turbulence is a good example. But flying into wake turbulence can flip your aircraft onto the ground. Is that really worth practicing? You should be avoiding it instead. Rather like the logic that says that it's better to train at avoiding spins than to train at recovering from them. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#45
In rec.aviation.piloting Mxsmanic wrote:
swag writes: This is actually a maneuver that's demonstrated and practiced very early in flight training, so I'm sure all pilots and student pilots have experienced this. But your calculations are fairly correnct--a 2 minute turn won't cut it. It's usually demonstrated with a 60 degree bank turn. I'm not sure of the timing, but i'd guess 30 sec or less. Don't you have to descend to catch the wake? Downwash should be moving downward at a few knots and IIRC the vortices do as well, so after two minutes at, say, 12 knots, the turbulence would be almost 2500 feet below you, if you are staying at altitude. I don't see how you could run into it. Real people in real airplanes training to become real pilots do real 45 degree bank, constant altitude turns on a regular basis and run into their real wake. It is just another thing you don't understand because you have no context. -- Jim Pennino Remove .spam.sux to reply. |
#46
![]() "Mxsmanic" wrote .. Tip vortices is not the only form of turbulence behind an aircraft. And an airliner on approach has a different type of wake than a trainer at altitude. All of them should be moving downward, though. Do you have a reference saying this is always the case? Which means that if you try to catch your own wake at constant altitude, you should miss it, as it will have drifted downward. Or am I missing something? Maybe the propwash? The best value of a good simulator is that it enables training of situations that would be unsafe to do in a real aircraft.Flying into wake turbulence is a good example. But flying into wake turbulence can flip your aircraft onto the ground. Is that really worth practicing? You should be avoiding it instead. Rather like the logic that says that it's better to train at avoiding spins than to train at recovering from them. The opposite logic is quite popular too. In fact this has been debated almost as long as aviation. Personally, I'd welcome a simulator accurate enough to practice recovery from a wake encounter. The same goes for spin recovery. |
#47
In rec.aviation.piloting swag wrote:
This is actually a maneuver that's demonstrated and practiced very early in flight training, so I'm sure all pilots and student pilots have experienced this. But your calculations are fairly correnct--a 2 minute turn won't cut it. It's usually demonstrated with a 60 degree bank turn. I'm not sure of the timing, but i'd guess 30 sec or less. It is 45 degrees +/- 5 for private, 50 +/- 5 for commercial. -- Jim Pennino Remove .spam.sux to reply. |
#48
no it wouldn't
mike You meant 45 degree bank. A 60 degree steep turn would require a parachute. |
#49
![]() "Mxsmanic" wrote in message ... swag writes: This is actually a maneuver that's demonstrated and practiced very early in flight training, so I'm sure all pilots and student pilots have experienced this. But your calculations are fairly correnct--a 2 minute turn won't cut it. It's usually demonstrated with a 60 degree bank turn. I'm not sure of the timing, but i'd guess 30 sec or less. Sorry, I didn't notice the 60-degree part. Sixty degrees would be 2.7 Gs, which seems high for a GA aircraft. If I'm not mistaken, this would allow a 360-degree turn in about one minute at 100 kts. Still, the wake would be a thousand feet lower or so by then (assuming a 12-kt downwash). Your calculations are as insane as you are, guess again. What you are MISSING is well beyond the scope this newsgroup, much less this topic. Sixty degrees turns are part of routine PPL training, without a parachute. Check the regs you so often quote with implied authority. Finding your own wake turbulence while doing 60/360s happens every day, and is most often demonstrated by every CFI. Descending 360 turns are executed routinely by pilots needing to descend without leaving an area, such as descending to land after crossing high mountains. You demonstrate daily that you are incompetent to comprehend the answers to the questions you pose, and regardless of your motives, based on your own lack of experience, you serve no more purpose here than a common troll. Get a life,,, or make time and money for a few measly flight hours. |
#50
mike regish writes:
no it wouldn't If it's exactly 60 degrees, it wouldn't. Beyond 60 degrees, however, a parachute is required. See FAR 91.307(c)(1). -- Transpose mxsmanic and gmail to reach me by e-mail. |
I want to ask you the most important question of your life. The question is: Are you saved? It is no | gasman | Soaring | 0 | August 26th 05 06:39 PM |
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 01:26 AM |
