#41
Mxsmanic wrote in
: mike Z writes: Picture of an E-4B being tested in an EMP generator (test facility). http://en.wikipedia.org/wiki/Image:E..._command_post_ EMP_sim.jpg Interesting. I see what looks like fuel being loaded into the aircraft. I wonder if they tried testing the EMP while the fuel was being taken on. You're an idiot. Bertie |
#42
#43
#44
In rec.aviation.piloting Mxsmanic wrote:
writes: If they were fueling, there would be a big ass truck next to the plane. There's something green attached to the wing. Fuel trucks don't attach themselves to wings. Are you talking about the building behind the airplane associated with the wire antenna system? -- Jim Pennino Remove .spam.sux to reply. |
#45
Mxsmanic wrote in
news ![]() writes: If they were fueling, there would be a big ass truck next to the plane. There's something green attached to the wing. Mayb e it's the USB port Bertie |
#46
#47
![]() wrote in message ... In rec.aviation.piloting Mxsmanic wrote: mike Z writes: Picture of an E-4B being tested in an EMP generator (test facility). http://en.wikipedia.org/wiki/Image:E...st_EMP_sim.jpg Interesting. I see what looks like fuel being loaded into the aircraft. I wonder if they tried testing the EMP while the fuel was being taken on. 747s aren't fueled by carrying 5 gal cans up the stairs. If they were fueling, there would be a big ass truck next to the plane. There would also be a small panel hanging down from the RH leading edge. This give you access to the refueling panel At most airports you don't need a big ass truck. The fuel lines run underground to where the aircraft is parked at the terminal. A large pick up with a lift is used to run the fuel line from the underground fuel head to the aircraft In this case though there would be a big ass truck. -- Jim Pennino Remove .spam.sux to reply. |
#48
![]() "Mxsmanic" wrote in message news ![]() writes: If they were fueling, there would be a big ass truck next to the plane. There's something green attached to the wing. Ground hydraulic units use green hoses But I've never seen one hooked up near the wing tip on a 747. Usually you use the hydrualic servicing panel in the gear wheel well. |
#49
Leadfoot wrote:
"Mxsmanic" wrote in message news ![]() writes: If they were fueling, there would be a big ass truck next to the plane. There's something green attached to the wing. Ground hydraulic units use green hoses I think the USAF uses green AC/heater hoses. I believe they replaced the yellow ones 20 years ago. Dan, U.S. Air Force, retired |
#50
Saw President Bush's plane (response to "Saw J.T.'s Plane") | Ricky | Piloting | 60 | September 1st 07 09:25 PM |
Jay's "Plane Crash Video Ubersite" | Peter Duniho | Piloting | 18 | August 14th 06 05:45 AM |
Have you created anything "home-made" for your plane? (or a low cost alternative?) | Andy | Piloting | 69 | April 29th 06 03:25 PM |
Have you created anything "home-made" for your plane? (or a low cost alternative?) | Andy | Owning | 61 | April 29th 06 03:25 PM |
